2013 Rear Diff explosion(s) Why..? - Polaris RZR Forum - RZR Forums.net
post #1 of 160 Old September 11th, 2013, 08:36 PM Thread Starter
true520's Avatar
My RZR: 900, 570
Member #47555
Feedback Score: 5 reviews
View true520's Photo Gallery(0)
Ok, This is getting a little odd. My 2103 exploded the rear diff at 470 miles... then the 2nd one at 700 miles... and now the 3rd one at 960 miles.
Since I have other Rzrs, And the rear ends have let go on two different drivers, I think we can safely rule out driver error.
Believe it or not, Warranty stepped up in both the first replacements. I am waiting to hear about the 3rd time.
Tires are 26" Cerros, and I removed the braking clutch before the 3rd diff went in.
We do not moto cross, mud sling, or rock crawl... some tight trails, but mostly just going fast on fire roads.
I keep taking it to the dealer and thus far they have just replaced the broken parts. No one has looked for anything that could be causing this problem.
So, my question is... what could be out of alignment ? OR, can alignment be an issue at all ? The last time I was told something "may be out of align in the transmission"... so they replaced BOTH. It only lasted 260 miles.
What else could be causing stress on the rear end ??
true520 is offline
post #2 of 160 Old September 11th, 2013, 08:41 PM
BarRZR's Avatar
My RZR: 2012 RZR 800-S L/E
Member #32278
Re: 2013 Rear Diff explosion(s) Why..?
Your 2013 what (i.e., which model)???
Cheers
BarRZR is offline
post #3 of 160 Old September 11th, 2013, 08:49 PM Thread Starter
true520's Avatar
My RZR: 900, 570
Member #47555
50" blue fire.
true520 is offline
post #4 of 160 Old September 11th, 2013, 09:55 PM
PhiberOptik's Avatar
Member #36019
View PhiberOptik's Photo Gallery(0)
What is it doing? Splitting the stock case at the pinion?
Got pics?
RZR Z1 Turbo + Everything
PhiberOptik is offline
post #5 of 160 Old September 12th, 2013, 05:01 AM Thread Starter
true520's Avatar
My RZR: 900, 570
Member #47555
Got pics?
Yep. Then it locks down tight in the rear end. Front wheels won't move it at all.
All 3 times it has been making a clicking noise in the rear end while in reverse.
I usually hear it when backing it off the trailer. I have called the dealer before it exploded
All 3 times.. even took it by there one time and showed him the noise. All three times
He has said it has to be the axle making the noise.
true520 is offline
post #6 of 160 Old September 12th, 2013, 09:34 AM
oldtotegoat's Avatar
My RZR: 2013 RZR 800 LE Blue Fire or is it VooDoo Blue?
Member #56641
View oldtotegoat's Photo Gallery(0)
Mostly 2-wheel or 4-wheel engaged?
oldtotegoat is offline
post #7 of 160 Old September 12th, 2013, 10:18 AM Thread Starter
true520's Avatar
My RZR: 900, 570
Member #47555
I would say 50/50. We mainly used 2wd up til a few months ago and then we
Figured out the front wheels help control.the slides.
true520 is offline
post #8 of 160 Old September 13th, 2013, 06:41 PM
rzr 2010's Avatar
First Name: RANDY
My RZR: 2017 XP 4 1000
Member #15970
View rzr 2010's Photo Gallery(0)
I don't like to here problems on the 2013 I just bought one I now have 288 miles on it. I'm getting ready to go to the rocky mtn. jamboree sunday and that is making me nervous . I will put about 500 miles on it in the next week.
rzr 2010 is offline
post #9 of 160 Old September 13th, 2013, 06:56 PM Thread Starter
true520's Avatar
My RZR: 900, 570
Member #47555
I really think it is just my buggy. That is why I posted on here... hoping someone with
More knowledge than I ciuld help lead me in the right direction.
I know plenty of people who havent had this problem too.
And, I just traded a 2011 in that was going great with over 5000 miles on it.
true520 is offline
post #10 of 160 Old September 13th, 2013, 07:03 PM
wolfpack783's Avatar
My RZR: Can am X3 RS Max, 2013 XP 4 900 LE Sold
Member #15068
View wolfpack783's Photo Gallery(0)
Yep, same thing here (2012 rzr S) but 1600 miles so I got some more miles out of it. All fluids changed before rec's. Fire roads and mountain trails, never abused at all. We carry a lot of weight on steep mountain trails though so we thought that was why it happened. Locked up the rear end and split the rear diff case and leaked gear oil on the ground. Thankfully, warranty covered it as well.
wolfpack783 is offline
post #11 of 160 Old September 13th, 2013, 07:14 PM
Member #15068
Got pics?
Same clicking noise, but not in reverse, it was at moderate speeds on flat ground from 10-25 mph. After reading the forums I just thought is was the brake pads, but now, I don't think it was........if you have a clicking noise, check your rear diff main bearing(if you don't have a warranty). If you do, ride with a buddy who can give you a ride out when it breaks like I had to do!
post #12 of 160 Old September 14th, 2013, 04:00 AM
brad101's Avatar
First Name: Brad
My RZR: 2013 RZR 800S
Member #48957
View brad101's Photo Gallery(0)
my rear diff bearing failed and exploded the rear diff, warrenty covered it.... roughly 1200 kms at that point!
Sent from my iPhone using Tapatalk - now Free
brad101 is offline
post #13 of 160 Old September 14th, 2013, 07:29 AM
Goose2222's Avatar
My RZR: 2015 XP 1000
Member #34094
View Goose2222's Photo Gallery(0)
It sounds like the dealer has not got to the root of the problem and continues to just fix the broken parts.
Goose2222 is offline
post #14 of 160 Old September 14th, 2013, 07:42 AM Thread Starter
true520's Avatar
My RZR: 900, 570
Member #47555
That's what we are hoping to find out this time.
I actually hate hearing other people are having the same issue. I have spoken
to several other owners who havent had any rear diff issues...And all have a lot more miles than mine.
I was even considering just trading this one for another 2013 570 because I have a buddy
who put 2800 miles of hard driving on his 2012 with out one issue.
Our 570 only has a few miles thus far so I am hoping this is not an ongoing
Problem for the 2012 and up models.
true520 is offline
post #15 of 160 Old September 14th, 2013, 09:23 AM
Member #56641
Curious what the build dates are on the failed units.......Mine says SCHAFER 3-26-13. Also has a serial #. I hate worrying about a differential blowing up.
RZR trans/rear diff/front diff for sale dpcustomfab Polaris RZR Parts For Sale 30 September 9th, 2014 01:14 PM
Rear Diff/ Trans Fluid 2013 rzr xp4 Redmoomba RZR XP 4 900 Specific Discussion 2 August 14th, 2013 09:11 AM
2013 RZR 900 Rear Diff swap to Intl Turf mode?? towny RZR XP 900 0 August 1st, 2013 11:45 AM
Rear Diff, Front Diff, S Transmission mnibusa Polaris RZR Parts For Sale 9 April 20th, 2013 11:31 AM
