2014 Polaris RZR 800 Specs - Polaris RZR Forum - RZR Forums.net
post #1 of 18 Old July 29th, 2013, 05:37 PM Thread Starter
4Nines's Avatar
My RZR: 09 RZR S
Member #5322
View 4Nines's Photo Gallery(1029)
RZRŽ 800
EngineEngine Type4-Stroke Twin Cylinder
Displacement760cc High Output (H.O.)
Fuel SystemElectronic Fuel Injection
CoolingLiquid
Drive TrainTransmission/Final DriveAutomatic PVT P/R/N/L/H; Shaft
Drive SystemOn-Demand True AWD/2WD
Engine Braking System/ Active Descent ControlNot Equipped
SuspensionFront SuspensionDual A-Arm with Anti-Sway Bar 9' (22.9 cm) Travel
Rear SuspensionDual A-Arm, Rolled with Anti-Sway Bar 9.5' (24 cm) Travel
BrakesFront/Rear Brakes4-Wheel Hydraulic Disc with Dual-Bore Front Calipers
Parking BrakePark in Transmission
Tires And WheelsFront Tires25 x 8-12; Ancla
Rear Tires25 x 10-12; Ancla
WheelsStamped Steel / Cast Alu. on LE's
Dimensions / CapacitiesWheelbase77' (196 cm)
Dry Weight993 lb (450 kg)
Overall Vehicle Size (L x W x H)103 x 50 x 69' (261.6 x 127 x 175.2 cm)
Ground Clearance10.6' (26.9 cm)*
Seat HeightN.A.
Fuel Capacity7.25 gal (27.4 L)
Bed Box Dimensions (L x W x H)22 x 42 x 10' (56 x 107 x 25 cm)
Front/Rear Rack or Box CapacityN.A./300 lb (136.1 kg)
Payload Capacity740 lb (335.6 kg)
Hitch Towing Rating1,500 lb (680.4 kg)
Unbraked Trailer Towing CapacityN.A.
Hitch/TypeStandard/1.25' Receiver
FeaturesCargo SystemLock & Ride
LightingHalogen, 55W low/ 60W high
Electronic Power SteeringAvailable on Limited Edition
InstrumentationDigital Gauge: Speedometer, Odometer, Tripmeter, Tachometer, Coolant Temperature, Volt Meter, Hour Meter, Service Indicator, Clock, Gear Indicator, Fuel Gauge, Hi-Temp Light, Seatbelt Reminder Light; DC Outlet
ColorsColorsIndy Red|Polaris Pursuit Camo|Blue Fire LE|Gloss Black/Orange Madness LE|Matte Black - XC Edition
4Nines is offline
post #2 of 18 Old July 29th, 2013, 05:46 PM
Dascrow's Avatar
Member #5856
View Dascrow's Photo Gallery(0)
Re: 2014 Polaris RZR 800 Specs
And a few more photos!
Dascrow is offline
post #3 of 18 Old July 29th, 2013, 07:31 PM
mister's Avatar
Member #4899
View mister's Photo Gallery(0)
Basically...same old, same old!
2015 RZR 900 EPS
>Polaris 3500 HD Winch
>Bandit Trail shocks
>CST Stag radial tires/Superatv wheel spacers
>Factory UTV full skids
>DesertCraft suspension seat brackets
>EVO stage 1.5 ECU
mister is offline
post #4 of 18 Old July 29th, 2013, 07:36 PM
sandblster's Avatar
Member #46247
And that is not a bad thing as it is the best 50" trail machine as is.
sandblster is offline
post #5 of 18 Old July 29th, 2013, 07:42 PM
razed's Avatar
First Name: tom
My RZR: 50" 800
Member #56794
View razed's Photo Gallery(0)
That xc one looks cool, different seats, led lights, cool wheels
disturbing the peace since 1975
Disturbing the peace since 1975
razed is offline
post #6 of 18 Old July 29th, 2013, 07:58 PM
Hobojon's Avatar
My RZR: 2012 800 le
Member #56466
View Hobojon's Photo Gallery(0)
The voltmeter is new I think.
I like the new color schemes too.
I see a XC headlight conversion in the future....
The rear springs look like they are progressive , is that new or is that the same as the 13 models?
2012 800 LE, eps, 27x11x12 HTR's, SATV 1.5" fwd control a-arms (which suck) , hl springs, rear cab divider, cooter roof, moto heater, winch/remote, brushguards, aluminum skids, uhmw sliders, utvgiant doors, air raid intake w/snorkel, rear cage support, 1.5" rear spacers and 1" front, lunatec 30" led light bar, superdave bushings, boss stereo
Hobojon is offline
post #7 of 18 Old July 29th, 2013, 08:17 PM
OHIOHELLRAISER's Avatar
First Name: Brain
My RZR: 2013 800 EPS LE
Member #55833
View OHIOHELLRAISER's Photo Gallery(0)
Seatbelt Reminder Light is new and should be annoying. Yep believe same springs as `13.
OHIOHELLRAISER is offline
post #8 of 18 Old July 30th, 2013, 07:39 AM
Wisers Deluxe
WHISKEY's Avatar
My RZR: 2013 Rzr S
Member #52345
View WHISKEY's Photo Gallery(0)
Guys, head light part # 2878275 and the harness needed is 2878533
WHISKEY is offline
post #9 of 18 Old July 30th, 2013, 07:57 AM
oldtotegoat's Avatar
My RZR: 2013 RZR 800 LE Blue Fire or is it VooDoo Blue?
Member #56641
View oldtotegoat's Photo Gallery(0)
Mine has the seat-belt reminder, so I don't know any better.....Was kind of concerned about buying a '13 so close to the '14 release. So far, so good.
oldtotegoat is offline
post #10 of 18 Old July 30th, 2013, 08:35 AM
RMR Man's Avatar
First Name: Steve
Member #11566
The XC is 55" Wide!
RMR Man is offline
post #11 of 18 Old July 30th, 2013, 09:53 AM
yellow1000's Avatar
Member #32335
View yellow1000's Photo Gallery(0)
Anyone know how the width was achieved ? Different A arms possibly?
2012 xp900 stealth black
yellow1000 is offline
post #12 of 18 Old July 30th, 2013, 09:56 AM
razed's Avatar
First Name: tom
My RZR: 50" 800
Member #56794
I'm guessing wheel offset
razed is offline
post #13 of 18 Old July 30th, 2013, 10:02 AM
yellow1000's Avatar
Member #32335
Your probably correct, but from the pics it looks like slightly longer arms.
post #14 of 18 Old July 30th, 2013, 12:28 PM
IARZR's Avatar
First Name: Adam
My RZR: 2008 RZR 800
Member #44193
Feedback Score: 31 reviews
View IARZR's Photo Gallery(0)
Im digging the XC!
IARZR is offline
post #15 of 18 Old July 30th, 2013, 12:47 PM
RacerSam's Avatar
My RZR: 2009 Nuclear Orange LE, 2012 Walker Evans
Member #7858
View RacerSam's Photo Gallery(0)
XC looks cool.... Sure it's extra width is do to the polaris accs. 14" Wheels are more offset. Also looks like above the rear tire what looks to be W/E shocks possibly?
Don't recall polaris making a W/E 50" in 2013, maybe his is like a 14 W/E...
'16 Graphite Crystal turboXP
'14 Black Stealth 900XP
'12 Walker Evans 800
'09 Nuclear Orange 800LE SOLD
'11 rzr170 SOLD
'05 YFZ450 SOLD
RacerSam is offline
2014 Polaris RZR XP 1000 Specs and Information 4Nines Polaris RZR News 536 September 13th, 2013 10:21 AM
2014 Polaris RZR 570 Specs 4Nines RZR 570 Specific Discussion 11 August 31st, 2013 06:54 AM
2014 Polaris RZR 4 900 Specs 4Nines RZR XP 4 900 Specific Discussion 10 August 1st, 2013 10:01 PM
2014 Polaris RZR 4 800 Specs 4Nines RZR 4 Specific Discussion 0 July 29th, 2013 05:34 PM
Pic of the Polaris new 2014 RZR? jmart233 General RZR Discussion 1 July 16th, 2013 08:29 PM
