2013 RZR 800 Clutch Belt Change How To? - Polaris RZR Forum - RZR Forums.net
post #1 of 7 Old May 18th, 2013, 02:07 PM Thread Starter
ten1234's Avatar
My RZR: RZR 800 50"
Member #53336
View ten1234's Photo Gallery(0)
I have a new 2013 RZR 800, and I don't understand how to change the clutch belt. I watched the online video. However, the 2013 secondary clutch is different from the 2009 clutch shown in the video. The 2013 does not seem to have any way to open the sheaves to create slack in the belt for removal. There is nothing wrong with my belt. I just like to learn how to fix things before they break on the trail.
How are 2013 owners changing out belts?
Thanks!
ten1234 is offline
post #2 of 7 Old May 18th, 2013, 02:29 PM
BarRZR's Avatar
My RZR: 2012 RZR 800-S L/E
Member #32278
Re: 2013 RZR 800 Clutch Belt Change How To?
How are 2013 owners changing out belts?Thanks!
Check the previous thread: "removing 800s belt cove/box help needed ". You'll find your answer/s there.
Cheers
BarRZR is offline
post #3 of 7 Old May 18th, 2013, 09:39 PM
Go Big or Go Home!
Mud-and-Guts's Avatar
First Name: Neil
My RZR: 2015 RZR S 900
Member #47784
View Mud-and-Guts's Photo Gallery(0)
I would think you could just roll on a new belt.. Most likely on the trail if you are going to change it you will not have to worry about removing the old belt it will probably take care of that its self.. I have had mine off in the shop but I always pull the sheaves..
2015 RZR S 900 (currently in the process of "Making it Mine")
Mud-and-Guts is offline
post #4 of 7 Old May 19th, 2013, 12:10 AM
switzomatic's Avatar
Member #38370
View switzomatic's Photo Gallery(0)
Just need a little muscle. Pull towards the secondary and start it off the pulley(secondary). Keep rotating/pulling to the side and it will come off. Installation is the same. Other way is to romove the retaining bolt on the secondary and give it a tug. Once it pops off belt removal is simple.
09 RZR 800 Camo J-Strong Roof/Light Bar
3" Roktek Lift/12" STI beadlocks w/ 30" Mambas
Walker Evans shocks Big Gun exhaust/EPI clutch
UTV tilting windshield/rear roll-up shield
Full two-piece doors UTV airbox w/snorkels
Too many other odds and ends
2010 Scrambler 500 HO
Lifted 07 Ram Big Horn Hemi Crew 4x4 to haul 'em
switzomatic is offline
post #5 of 7 Old May 19th, 2013, 12:34 AM
N0OSV's Avatar
First Name: Jim
My RZR: 2010 RZR
Member #29795
View N0OSV's Photo Gallery(0)
Rzr Icon Re: 2013 RZR 800 Clutch Belt Change How To?
Here is a video showing how to change the belt it for both types of secondary clutchs.
N0OSV is offline
post #6 of 7 Old July 21st, 2013, 07:07 AM
rvndave's Avatar
Member #33660
View rvndave's Photo Gallery(0)
Originally Posted by N0OSV View Post
Here is a video showing how to change the belt it for both types of secondary clutchs. How to change a RZR clutch belt 2009 (short version) - YouTube
Thanks for the link to this video!
rvndave is offline
post #7 of 7 Old July 22nd, 2013, 05:23 AM
IdahoRenegade's Avatar
My RZR: 2013 LE, Orange
Member #43939
View IdahoRenegade's Photo Gallery(0)
I just did mine yesterday, piece of cake. I just "rolled" it off/on the driven clutch. It's easier than it sounds, really. There are a few things I wasn't too impressed by, though. First, I'd sucked water into my CVT housing a couple times. I've never been in deep water, barely over the floorboards, not even close to the seats. Still, some dried muddy water in there. I think it's due to the lack of any kind of shield over the air intake, if you hit puddles fast, it splashes up there and can get sucked in. I think that's what happened anyway.
I cleaned up the clutches/housing with the pressure washer and then dried with compressed air. Also washed the new belt in dish soap to get any mold release off. Everything seemed to go fine, clutch engagement was smoother after the job.
One other disappointment-the clutch cover is pretty flimsy, nothing like a Yamaha or Can-Am one. Also, it's just held on with self tapping screws into plastic. Every other ATV I've worked on has thread inserts in the rear housing, and used quality machine screws. Polaris cheaped out here, use care not to strip the screws.
2013 LE, Nuclear Sunset Orange
25X10X12 Bighorns, EMP bumper, Tusk Cage Extension
IdahoRenegade is offline
How to change a RZR clutch belt VIDEO Tuf-Skin Engine and Drivetrain 133 November 5th, 2016 09:15 AM
Will anything change for 2013???? PUP1979 General RZR Discussion 34 July 21st, 2013 07:01 AM
2013 First Oil Change darthintel RZR XP 900 12 May 4th, 2013 09:49 PM
2013 rzr xp 900 Broke belt with 30hrs and 250 miles. Is there a upgrade belt? ajnew79 Engine and Drivetrain 19 March 26th, 2013 08:35 AM
Oil change on a 2013 xp4, filter? inki RZR XP 4 900 Specific Discussion 1 September 12th, 2012 04:43 PM
