which is better 2013 front springs or highlifter - Polaris RZR Forum - RZR Forums.net
This is a discussion on which is better 2013 front springs or highlifter within the RZR 800 Specific Discussion forums, part of the General RZR category; I have a 2012 50" rzr has a little over 500 miles front shocks are on stiffest setting and sag badly. I want to change ...
Old April 14th, 2013, 07:21 PM   #1
randy74's Avatar
My RZR: 2012 50" rzr
Member #24174
View randy74's Photo Gallery(0)
I have a 2012 50" rzr has a little over 500 miles front shocks are on stiffest setting and sag badly. I want to change to better springs are the 2013 oem progressive springs holding up or do they sag fast too. Which would be better the oem 2013 or highlifter? I have heard good things about the makin trax but it does not look like they sell them anymore. What would be the best replacement springs that will hold there height.
randy74 is offline   Reply With Quote
Old April 14th, 2013, 07:28 PM   #2
kaiserstatt's Avatar
First Name: Craig
My RZR: 2012RZR 800S , 2012 RZR 800
Member #40874
View kaiserstatt's Photo Gallery(0)
Re: which is better 2013 front springs or highlifter
Interested in this also..
Sent from my Nexus 7 using Tapatalk 2
kaiserstatt is offline   Reply With Quote
Old April 15th, 2013, 09:25 AM   #3
olddognewtrick's Avatar
First Name: Jim
Member #18785
Got 2013 owners working on that question right now.
http://www.rzrforums.net/rzr-800-spe...e-springs.html
2011 Pursuit Camo
olddognewtrick is offline   Reply With Quote
Old April 22nd, 2013, 02:59 AM   #4
BT3RZRFireBlue's Avatar
First Name: Anthony
My RZR: 2013RZR800LEFireBlue
Member #52237
View BT3RZRFireBlue's Photo Gallery(0)
So far I haven't noticed any sag in mine. Only have about 150 miles on it. Need to take measurements to see if or when they do.
Anthony
2013 RZRLE Fireblue
"You haven't lived till you cheated the Grim Reaper of his Gold"
Polaris Hard top. Polaris doors. Polaris Brush Guard. Polaris Half windshield. UTV 3'' Blue Harnesses. Viper Max 4000lb Winch. Moose side mirrors. Polaris Ranger RZR soft top bag. Soft rear window.
BT3RZRFireBlue is offline   Reply With Quote
Old April 22nd, 2013, 03:10 AM   #5
ORNGRZR's Avatar
First Name: PJ
My RZR: 2015 XP1K4
Member #32025
View ORNGRZR's Photo Gallery(0)
Highlifter hawk engineering and utv Inc all sell progressive rate springs utv Inc being the old makin Trac brand they now sell them
2015 XP1K4, time to start all over again! sxswindsheild, Racertech lift, 32"Intimidators on HD4's, Dalton clutch kit for Todd at Hunterworks, Isota roof, EMP rear windshield, Sandcraft carrier bearing, R2C filter from Desertcraft, Alba radius rods,did the front diff shim swap myself, UTV Giant lower doors, Rok Blokz flares, to be continued!
2011 800 LE SOLD!
ORNGRZR is online now   Reply With Quote
Old April 22nd, 2013, 03:48 AM   #6
Feedback Score: 4 reviews
Sahara01's Avatar
My RZR: 800 EFI
Member #33929
View Sahara01's Photo Gallery(0)
Makin Trax is still in business, look them up on the www. Racertech is another very good option.
Sahara01 is offline   Reply With Quote
Old April 22nd, 2013, 04:21 AM   #7
Brettm57's Avatar
First Name: Brett
My RZR: 2011 RZR
Member #8994
View Brettm57's Photo Gallery(0)
I can't speak for the OEM 2013 springs, but I have a set of Highlifter springs on my 2011. IMHO, they are a huge improvement over stock. They gave me the ground clearance I wanted without going to a lift kit.
Brettm57 is offline   Reply With Quote
Old April 24th, 2013, 10:41 PM   #8
randy74's Avatar
Member #24174
I just ordered a full set of racertech heavy springs i'll post how they are when i get them on.
Old April 24th, 2013, 10:52 PM   #9
Sahara01's Avatar
My RZR: 800 EFI
Member #33929
Good choice have them on both my Rzr's .
Old April 25th, 2013, 06:09 AM   #10
randy74's Avatar
Member #24174
Do they keep the front end up? Now when i park it the shocks are half way compressed rear seems ok just the front sags. I went ahead and bought the full set because mine does buck some in the rear it sounds like the rear dual rate helps take care of that. What posistion do you run your adjusters on?
Old April 25th, 2013, 09:08 AM   #11
Sahara01's Avatar
My RZR: 800 EFI
Member #33929
I have very little preload on my S with fox podium shocks, my 50" has Afco MT-1 shocks, and basically snugged spring retainers to keep springs in place, no preload. They will definitely keep the front end up. I have the heavy rate on both machines.
Old April 25th, 2013, 09:55 AM   #12
BarRZR's Avatar
My RZR: 2012 RZR 800-S L/E
Member #32278
The King Progressive springs (225# fronts and 250# rears) from Makintrax or UTV Inc. work EXTREMELY well and are a perfect match for the Fox-Podium shocks, set to mid-range on the damping. You'll end-up with a bit over 13" of ground-clearance, front and back. And, in nearly 2000 miles of running, I've detected NO sagging-out. Just my two-bits........
Cheers
Old April 25th, 2013, 11:21 AM   #13
First Name: Jim
Member #18785
Cheers
Those springs are awesome, love mine. Work well with Walker Evans shocks as well.
2011 Pursuit Camo
Old April 25th, 2013, 09:11 PM   #14
Feedback Score: 5 reviews
true520's Avatar
My RZR: 900, 570
Member #47555
View true520's Photo Gallery(0)
I just tested the Racer tech heavy spring and I am very
Pleased. I was bottoming out all the time with the OEM
springs set at their stiffest setting. I only set these on the
2nd notch up too.
They do make a lot more squeaking noise tho... but dont
Really notice that when driving hard. LoL
true520 is offline   Reply With Quote
Old April 25th, 2013, 09:37 PM   #15
King of crash!
Member #787
more than likely the cheep shocks are shot get some new shocks their are alot of cheeper ones with springs that will out last you rzr and can be rebuilt makin trax has a nice set for the 50 in 1000 times better than sachs
2013 rzr 800 highlifter springs
2013 sportsman 800 fromt springs
2013polarisrangerrearsprings
do i need new spring retainers with highlifter springs
front springs
high lifter springs for polaris ranger
highlifter or racertech spring for rzr
highlifter springs rzr 800
how high do i have to lift the front of my rzr to get it in the back of my pickup
my rzr s with sach shocks sags badly
polaris ranger rzr 800
rzr 800 50 in shocks racer tech or high lifter
rzr high lifter front springs
springs for 2013 polaris rzr 800s
Highlifter Springs Remington Suspension 25 September 24th, 2015 07:48 PM
Highlifter springs on the way! Teamnipplesdeep RZR 800 Specific Discussion 9 December 18th, 2012 11:11 AM
SuperATV springs vs. Highlifter springs nelsonk Suspension 13 December 15th, 2011 09:01 AM
(4) Highlifter lift springs front/rear $175-brand new pimp800 Polaris RZR Parts For Sale 4 January 4th, 2010 06:56 PM
highlifter springs? AzDevildog Suspension 6 July 10th, 2008 06:05 AM
