570 - Kenda Bear Claw HTR's? - Polaris RZR Forum - RZR Forums.net
post #1 of 19 Old July 16th, 2012, 04:12 PM Thread Starter
stacyandmel's Avatar
My RZR: 570
Member #40160
View stacyandmel's Photo Gallery(4)
Well I've read a thousand tire reviews, and I think I've narrowed it down to the Bear Claw HTR's. We use our machine for low impact trail riding and hunting in the Midwest....nothing serious. Tired of reading about issues with the stock 2-ply tires. They look like decent tires for the money. If I road a 1000 miles per year I would go for Maxis, ITP, Pitbull, etc, but we don't ride enough. Anybody have experience with these tires? Good? Bad? Issues? Any comments are appreciated..
stacyandmel is offline
post #2 of 19 Old July 16th, 2012, 06:24 PM
soapy's Avatar
My RZR: 2017 rzr 1000S
Member #24680
View soapy's Photo Gallery(2)
Re: 570 - Kenda Bear Claw HTR's?
I run them on my 570 and 800 rzr. They have been a great tire for me. There are several posts on these tires on this forum. I think anyone who has them likes them.
soapy is offline
post #3 of 19 Old July 16th, 2012, 06:26 PM Thread Starter
My RZR: 570
Member #40160
Thanks for the reply. If I get the same tire size and mount them to stock wheels, I won't experience any fit issues will I?
post #4 of 19 Old July 16th, 2012, 06:53 PM
bradlineberry's Avatar
First Name: brad
Member #28901
View bradlineberry's Photo Gallery(0)
Run em on my s.
Grim reapers
Itp 900xc
Bearclaw htrs..
Have all 3.
Currently run bearclaws
bradlineberry is offline
post #5 of 19 Old July 17th, 2012, 12:47 AM
AlbaChev's Avatar
First Name: Brian
My RZR: 2012 RZR 570
Member #40335
View AlbaChev's Photo Gallery(0)
I think you have my input already from the other post but I can guarantee 1 thing... If you go with the stock tire size (front and rear) there are ABSOLUTLEY, GUARANTEED no fitment issues whatsoever. I believe Soapy runs larger sizes in the HTR's and it was his suggestion that I try the HTR's (but again I am running the stock sizes) and it has been the best advice I have received thus far! We appear to ride similiar terrain and I am amazed at the better ride quality not to mention the piece of mind. They are heavier and I would expect to lose a couple miles an hour but I don't think you're racing it. (I do believe allot of the other tires are heavier anyway.) As I said in the other post, I've got 768 miles on the HTR's since I switched roughly a month ago... and well, I coldn't be happier that I listened to soapy. (And I do put on over a couple\few thousand miles a year.)
I always support the forum vendors but I couldn't pass up this deal, I just pulled my receipt for all 4 and it was $365.52 shipped:
Front Tire in stock size:
Kenda Bearclaw HTR Front Tire - Chaparral Motorsports
Rear tire in stock size:
Kenda Bearclaw HTR Rear Tire - Chaparral Motorsports
Enjoy!
(FYI: I'm not affiliated with AlbaRacing, but I do recommend their products!)
“Courage is being scared to death, but saddling up anyway.” - John Wayne
AlbaChev is offline
post #6 of 19 Old July 17th, 2012, 03:48 AM Thread Starter
My RZR: 570
Member #40160
Thanks Alba for the input. I planned on sticking with stock sizes, but I wanted to make sure. I've read a few posts where guys had clearance issues with tires, but this was probably due to new rims with different offsets in combination with different tire sizes. I'm not one to mod the hell out of a machine. I just want something that works, is safe, and is reliable. It sounds like the HTRs will suit our needs perfectly. Thanks again for the great advice and input!
post #7 of 19 Old July 17th, 2012, 08:44 AM
AlbaChev's Avatar
First Name: Brian
Member #40335
My pleasure.
AlbaChev is offline
post #8 of 19 Old July 17th, 2012, 06:01 PM
soapy's Avatar
Member #24680
The 570s have much more room for tires compared to the 800 rzr. The 800 has a motor mount that limits the tire being any wider on the rear without spacers. The 570 can easily take wider tires on the rear with no rubbing at all. I am running 26x9r12 BC HTRs on the front and 26x11r 12 on the rears and have no problem with rubbing on either end.
soapy is offline
post #9 of 19 Old July 17th, 2012, 08:24 PM
boxer0987's Avatar
First Name: Matt
My RZR: RZR 570
Member #39716
View boxer0987's Photo Gallery(0)
Soapy was that a typing error. I am not seeing the bc htrs available in a 26x10x12. Did you mean 26x11x12?
boxer0987 is offline
post #10 of 19 Old July 18th, 2012, 06:13 AM
homdaddy's Avatar
Member #26239
View homdaddy's Photo Gallery(0)
i wonder how much these weigh
i like the looks better than big horn
homdaddy is offline
post #11 of 19 Old July 18th, 2012, 11:48 AM
soapy's Avatar
Member #24680
Yes, it should have read 26x11r12 on the rear.
soapy is offline
post #12 of 19 Old July 18th, 2012, 02:39 PM
boxer0987's Avatar
First Name: Matt
My RZR: RZR 570
Member #39716
Soapy could you tell me if the stock wheels will run the 26x9x12 on the front and if the stock wheels will run the 26x11x12 on the rear with or without spacers? Thanks.
post #13 of 19 Old July 18th, 2012, 06:39 PM
soapy's Avatar
Member #24680
You will not need spacers with the stock wheels and the larger tires. I have not used the stock steel wheels but have used the same size wheels off a LE rzr with no problems.
soapy is offline
post #14 of 19 Old July 18th, 2012, 06:44 PM
boxer0987's Avatar
First Name: Matt
My RZR: RZR 570
Member #39716
Also soapy I see you run skinny's on one of your machines. Do you prefer it to the 11's on the rear?
post #15 of 19 Old July 20th, 2012, 10:48 AM
soapy's Avatar
Member #24680
The stock steel wheels on the 570 are a 5+2 offset. On a 800 50 inch they are a 6+1. On my 570 I originally ran 26x9r12 on the front and 26x11r12 Bear Claws on the rear with 6+1 Le wheels from a 800 rzr. This combo kept my width under 50 inches. Last night I put on 26x9r12 Bear claw HTRs all the way around using some new 4+3 offset wheels. This made the overal width just under 52 inches. After a 80 mile ride I have the following observations comparing the 2 different combinations. The 9 inch wide all the way around are easier to turn and should give a little better mileage. The 9 inch rubber slides out quicker on the rear when taking fast gravel corners.I think the 11 inch wide rubber on the rear do give a little better traction. I will probably run the 11 inch wide in the snow or on sand dunes. For most of my summer riding the 9 inch wide rubber works better for me plus I can rotate the tires as needed to prolong the tread life.
soapy is offline
Tags
570 tires kenda bear claw
UTVGiant.com BEAR CLAW DOORS for RZR/S/XP 2 or 4 Door utvgiant UTVGiant.com 113 December 25th, 2015 05:30 AM
Bear Claw HTR soapy Wheels and Tires 123 January 20th, 2015 12:07 PM
anyone running kendra bear claw htr bdub153 Wheels and Tires 2 February 15th, 2012 01:18 PM
Kenda Bear Claw HTR BadBowtie Wheels and Tires 14 November 5th, 2011 05:50 PM
Kenda Bear Claw for desert running? mmotley Wheels and Tires 2 February 13th, 2011 04:06 PM
