backfire - Polaris RZR Forum - RZR Forums.net
backfire
This is a discussion on backfire within the RZR 570 Specific Discussion forums, part of the General RZR category; Does anyone own a 570 that does'nt backfire. Mine has 450 miles on it and I get little pops sometimes when I let off the ...
Go Back   Polaris RZR Forum - RZR Forums.net > General RZR > RZR 570 Specific Discussion
Old February 25th, 2012, 02:09 PM   #1
flride's Avatar
My RZR: 2015 570
Member #36552
View flride's Photo Gallery(0)
Usa backfire
Does anyone own a 570 that does'nt backfire. Mine has 450 miles on it and I get little pops sometimes when I let off the gas quick but it has not gotten any worse and the dealer has no fix.
flride is offline   Reply With Quote
Old February 25th, 2012, 05:09 PM   #2
soapy's Avatar
My RZR: 2017 rzr 1000S
Member #24680
View soapy's Photo Gallery(2)
Re: backfire
I have never had mine backfire yet. about 300 miles.
soapy is offline   Reply With Quote
Old February 25th, 2012, 05:26 PM   #3
"Dual Primed!"
Feedback Score: 11 reviews
desertvet1990's Avatar
First Name: Rick
Member #15483
Re: backfire
Does it do it when its Hot(engine and exhaust) or cold? Hot COULD be the packing in the muffler. I have a Home Built exhaust using Harley mufflers and it will "pop" or kinda backfire when the pipes are really hot like after a hard run and then going downhill at an idle.
Land of the Free,, Because of the Brave!!Freedom is'nt free,, I Payed for it!
Shock Therapy Springs
GET FULL COVERAGE INSURANCE!! DONT take the chance!!
desertvet1990 is offline   Reply With Quote
Old February 25th, 2012, 06:55 PM   #4
Trees's Avatar
First Name: Cliff
My RZR: 570
Member #34390
View Trees's Photo Gallery(0)
Re: backfire
mine did the same. change the spark plug. they use a champion plug from the factory. Seams like they foul out early. i changed mine to an autolite but others prefer the NGK CR9EIX.
Trees is offline   Reply With Quote
Old February 25th, 2012, 07:33 PM   #5
BarRZR's Avatar
My RZR: 2012 RZR 800-S L/E
Member #32278
Re: backfire
Quote: Originally Posted by flride View Post
Does anyone own a 570 that doesn't backfire. Mine has 450 miles on it and I get little pops sometimes when I let off the gas quick but it has not gotten any worse and the dealer has no fix.
Just to clarify, so we're all speaking the same language; "backfiring" is occurring when you're getting popping or flash-back in the intake tract, not the exhaust. It is most often caused by tight intake valves or out-of-phase ignition timing. If the popping sound is coming from the exhaust, that's not backfire, but, rather is caused by a combination of too rich a mixture and a phenomenon known as "reversion", wherein fresh air is being sucked back up the tailpipe, where it mixes with the hot, overly-rich, unburnt fuel in the pipe and then combust's explosively, making a (often-times loud) popping sound. Straight-pipes and straight-through mufflers, or mufflers with the baffles pulled-out are very much prone to this condition. Just FWIW...........................
Cheers
Old February 26th, 2012, 08:25 AM   #6
flride's Avatar
My RZR: 2015 570
Member #36552
Re: backfire
Thanks for feedback. seems to do it when its hot. Question on the spark plug change, will it void the warranty
Old February 26th, 2012, 08:47 AM   #7
"Dual Primed!"
First Name: Rick
Member #15483
Re: backfire
Mine still backfires in the exhaust when its hot. Dont matter what the politically correct term is and the OP didnt specify intake or exhaust.
I still bet its the muffler, but changing the plugs is fine. Just make sure you get the same temprature range as the stock ones. The range is in the plug number. Your auto parts dealer will be able to cross reference a similar heat plug in a different make. putting a "colder or hotter' plug COULD do damage and void the warranty. I run BKR7EIX 2667 ,NGK Iridium plugs in my 800. same heat range as stock. Yours might be different. You might even check what the gap on the plug should be and is. It could be set wrong.
2011 polaris rzr 570 back fire
2012 rzr 570 running rich fuel
570 rzr back fires
my rzr idles slow when cold any tips
new rzr 570 backfires when letting off gas
plug gap polaris 570
polaris 570miss and backfiring
polaris backfire downhill
rzr 570 back fire
rzr 570 backfire
rzr 570 backfiring
rzr 570 no fire
rzr 570 pops at slow speeds
what is making my palaris back fire
will a different spark plug fix polaris 570 backfire
Backfire crazy coonie Engine and Drivetrain 3 January 9th, 2012 08:25 PM
backfire Ronzo General RZR Discussion 7 October 24th, 2011 06:02 PM
RZR 170 BackFire! MTW RZR 170 Specific Disccusion 7 June 30th, 2011 09:40 AM
Backfire BuRep RZR 170 Specific Disccusion 14 June 13th, 2011 02:01 PM
backfire 08 rzr gasattack16 Engine and Drivetrain 7 February 14th, 2011 08:20 PM
