2014 Polaris RZR 570 Specs - Polaris RZR Forum - RZR Forums.net
This is a discussion on 2014 Polaris RZR 570 Specs within the RZR 570 Specific Discussion forums, part of the General RZR category; RZRŪ 570 Engine Engine Type 4-Stroke DOHC Single Cylinder Displacement 567cc Fuel System Electronic Fuel Injection Cooling Liquid Drive Train Transmission/Final Drive Automatic PVT P/R/N/L/H; ...
Go Back   Polaris RZR Forum - RZR Forums.net > General RZR > RZR 570 Specific Discussion
Old July 29th, 2013, 04:55 PM   #1
4Nines's Avatar
My RZR: 09 RZR S
Member #5322
View 4Nines's Photo Gallery(1029)
RZRŪ 570
EngineEngine Type4-Stroke DOHC Single Cylinder
Displacement567cc
Fuel SystemElectronic Fuel Injection
CoolingLiquid
Drive TrainTransmission/Final DriveAutomatic PVT P/R/N/L/H; Shaft
Drive SystemOn-Demand True AWD/2WD
Engine Braking System/ Active Descent ControlAvailable on Limited Edition
SuspensionFront SuspensionDual A-Arm with Anti-Sway Bar 9' (22.9 cm) Travel
Rear SuspensionDual A-Arm, Anti-Sway Bar 9.5' (24 cm) Travel
BrakesFront/Rear Brakes4-Wheel Hydraulic Disc with Dual-Bore Front Calipers
Parking BrakePark in Transmission
Tires And WheelsFront Tires25 x 8-12; Ancla
Rear Tires25 x 10-12; Ancla
WheelsStamped Steel / Cast Alu. on LE's
Dimensions / CapacitiesWheelbase77' (196 cm)
Dry WeightBase 992 lb (456 kg)
Overall Vehicle Size (L x W x H)107.5 x 50 x 69' (273 x 127 x 175.2 cm)
Ground Clearance10.5' (26.7 cm)*
Seat HeightN.A.
Fuel Capacity7.25 gal (27.4 L)
Bed Box Dimensions (L x W x H)20 x 40 x 9' (51 x 102 x 23 cm)
Front/Rear Rack or Box CapacityN.A./300 lb (136.1 kg)
Payload Capacity740 lb (335.6 kg)
Hitch Towing Rating1,500 lb (680.4 kg)
Unbraked Trailer Towing CapacityN.A.
Hitch/TypeStandard/1.25' Receiver
FeaturesCargo SystemLock & Ride
LightingHalogen, 50W
Electronic Power SteeringAvailable on Limited Edition
InstrumentationDigital Gauge: Speedometer, Odometer, Tripmeter, Tachometer, Coolant Temperature, Volt Meter, Hour Meter, Service Indicator, Clock, Gear Indicator, Fuel Gauge, Hi-Temp Light, Seatbelt Reminder Light; DC Outlet
ColorsColorsIndy Red|Blue Fire LE
4Nines is offline   Reply With Quote
Old July 29th, 2013, 06:39 PM   #2
Dascrow's Avatar
Member #5856
View Dascrow's Photo Gallery(0)
Re: 2014 Polaris RZR 570 Specs
And a few more photos!
Dascrow is offline   Reply With Quote
Old July 29th, 2013, 07:21 PM   #3
Denver's Avatar
First Name: Denver
My RZR: S 900 Titanium
Member #41951
I'm not seeing any improvements/upgrades. Will be interesting to see how/if they fixed the intake problem!
Bought!!! 2015 RZR S 900 Titanium! Let the fun begin (again)!!
Polaris half windshield and rear mesh screen. Outerwears on air filter and clutch intake. 3500# Winch. Scrap tubing DIY parking brake ($0.00). Drift Innovation action camera. Roof. Side mirrors. DIY mud flaps. Tusk front bumper. UHMW A-arm guards. Next up: Skid plate(maybe). Bumper/Back bones. Better harnesses. (Not necessarily in that order) Whatever else strikes my fancy (& I can afford)(& the wife will let me buy)...
Denver is online now   Reply With Quote
Old July 29th, 2013, 07:58 PM   #4
DG_Rider's Avatar
My RZR: 2014 Honda Pioneer 4P
Member #55370
View DG_Rider's Photo Gallery(0)
I was going to start a thread like this titled "Meanwhile, back in the real world.." after watching the XP1000 launch...and seeing it's 19K pricetag.
Before Polaris' site crashed again, I did notice dual rate springs for the 570 this year. Shold help maintain ground clearance better.
DG_Rider is offline   Reply With Quote
Old July 30th, 2013, 07:24 AM   #5
Yamasaki86's Avatar
First Name: Marce
My RZR: 2013 570
Member #52686
View Yamasaki86's Photo Gallery(0)
Any news on the HP Rating for this Unit, Just seen the Sportsman 570 has 44HP.
I'm loving the New 1000 XP but I'de rather see more HP out of this 570.
Yamasaki86 is offline   Reply With Quote
Old July 30th, 2013, 07:28 AM   #6
Terrain Domination
shomkr's Avatar
My RZR: 2012 RZR 570
Member #32692
View shomkr's Photo Gallery(0)
X2, nice color, fix the intake, and air box sealing!
Shoe.
2012 RZR 570, Lovin it!
Bandit Shocks, Heretic RZR LED Headlights, MotoAlliance Viper Winch, ITP TerraCross R/T Tires, Polaris Crusher Rims, Kolpin Roof, Pro-Comp Roll Bar Rapz, Plano Storage trunk.
shomkr is offline   Reply With Quote
Old July 30th, 2013, 07:49 AM   #7
2013 rzr 570
arp1500's Avatar
My RZR: 2013 570
Member #49297
View arp1500's Photo Gallery(0)
isn't it that same exact machine
arp1500 is offline   Reply With Quote
Old July 30th, 2013, 10:06 PM   #8
Goose2222's Avatar
My RZR: 2015 XP 1000
Member #34094
View Goose2222's Photo Gallery(0)
I do not see turf mode in those specs. Looks like they did away with that on the 2014 LE.
Goose2222 is offline   Reply With Quote
Old August 30th, 2013, 09:03 AM   #9
thebrinkster's Avatar
My RZR: 2013 RZR 570 LE
Member #37117
View thebrinkster's Photo Gallery(0)
Turf mode is still there and they did fix the air intake with the one piece. I checked one out a couple weeks ago when mine was getting looked at for a weird noise, found out it was just the loose calipers. Interesting how just that can make a noise like the trans is binding or grinding.
2013 LE 570
Highlifter 2in lift,26" Duro Powergrips, EMP flip up windshield, soft top, homemade rear windshield, Pioneer stereo 200Watt, Sway-bars disconnected, PVC intake fix, UNI and Fram air filter, $1 parking brake, Outergear hand grips, rear mirror, 4500lbs winch, 66" Polaris poly plow, SuperATV Springs, Tusk overhead storage, Camoplast T4S tracks, 200 watt Dual stereo,.. TBC!
DRIVE IT LIKE YOU STOLE IT!!:rzrs:
thebrinkster is offline   Reply With Quote
Old August 30th, 2013, 02:26 PM   #10
Goose2222's Avatar
Member #34094
I know they fixed it. I own one.
Old August 30th, 2013, 03:10 PM   #11
Terrain Domination
shomkr's Avatar
Member #32692
Goose(bunch of 2's)
I mean fix the dirt getting past the filter in the top of the air box, to the bottom! I used door foam and made a shim myself.
Did they fix that?
Shoe.
Old August 31st, 2013, 07:54 AM   #12
brute978's Avatar
Member #44633
View brute978's Photo Gallery(0)
new exhaust 2014
rzr 570 2012
brute978 is offline   Reply With Quote
2014 polaris ranger 570 specs hp
2014 polaris rzr 570
2014 polaris rzr 570 hp
2014 polaris rzr 570 review
2014 polaris rzr 570 reviews
2014 rzr 570
2014 rzr 570 horsepower
2014 rzr 570 problems
2014 rzr 570 review
2014 rzr 570 specs
polaris 570 rzr heigth
polaris rzr 570
polaris rzr 570 specs
razr 570 engine size specs
rzr 570 specs
2014 Polaris RZR XP 1000 Specs and Information 4Nines Polaris RZR News 536 September 13th, 2013 11:21 AM
** Polaris Ind Is Coming To Our Taylor Park Ride with the new 2014's ** FJK Taylor Park Colorado Ride 76 August 26th, 2013 09:21 PM
Polaris Opens The VIP Online Launch Site for the New 2014 RZR FJK Polaris RZR News 190 July 30th, 2013 07:12 AM
Polaris Introduces The 2014 Lineup 4Nines Polaris RZR News 1 July 29th, 2013 09:51 PM
Pic of the Polaris new 2014 RZR? jmart233 General RZR Discussion 1 July 16th, 2013 09:29 PM
