So I am thinking about selling my daughters 170 and buy a 570. The issue I have is the height. Currently my enclosed trailer opening is 62 inches. I believe the height of the rzr cage is 69 inches. Is there anything that could be done to cut the height? Not fitting in the trailer is a deal breaker as the trailer houses 2 other ATVs
Thank for the responses. I just purchased my trailer a few months ago and not about to buy a 3rd one . Sitting in the 570 much above your head is the cage? I also didn't know that the cage could be changed out
My enclosed is the same height as yours. When entering the trailer you will find that the cage will be in before the rear wheels are completely up the ramp. I have a hard top that I have to remove for the clearance. If you have doubts take the trailer to dealer and give it a try.
My trailer is an Interstate 6X10 and it fits ok. A little tight on the sides but I can get in to tie it down.
Denny:redrzr:
I have a 10 x 6 with the same problem, I have to remove the roof but what I did find out is if you keep the front of trl. level or a little bit low you have a little more room because of the slant of the ramp puts your rear wheels a little lower and the top bar is already in.
