Rev limiter - Polaris RZR Forum - RZR Forums.net
post #1 of 16 Old February 28th, 2013, 02:15 PM Thread Starter
570razor's Avatar
First Name: Jim
My RZR: 2013 Jagged X
Member #50018
View 570razor's Photo Gallery(0)
Rev limiter
Hey guys, at what RPM is your 570 hitting the rev limiter? I'm sure we are all topping out at 56-57 on level ground.
570razor is offline
post #2 of 16 Old February 28th, 2013, 02:55 PM
Timmi's Avatar
Member #42712
View Timmi's Photo Gallery(0)
Re: Rev limiter
around 7550 rpm
Timmi is offline
post #3 of 16 Old February 28th, 2013, 03:43 PM Thread Starter
570razor's Avatar
First Name: Jim
Member #50018
Re: Rev limiter
Since I put my new 26"Kendra bear claws on with HD wheels I lost the mid range power. I changed my stock 52 gram clutch weight to 48 gram that was great mid range power. The problem was I hit the rev limiter at 45mph.
Polaris doesn't make a 50 gram weight. So I grounded down my 52 gram stock weights to 50 gram. From 0-48 my mid range power is great. I still hit 56-57 but only at 7300 rpm. So no rev limiter for me.
570razor is offline
post #4 of 16 Old March 3rd, 2013, 01:42 PM
devin87's Avatar
My RZR: rzr 570
Member #34147
View devin87's Photo Gallery(0)
I'm hitting the speed limiter at 59mph and 7200rpm with 26" tires
Sent from my HTC One S using Tapatalk 2
devin87 is offline
post #5 of 16 Old March 3rd, 2013, 02:16 PM
rts
rts's Avatar
Member #50743
View rts's Photo Gallery(0)
Re: Rev limiter
DO you have stock clutching
rts is offline
post #6 of 16 Old March 3rd, 2013, 02:22 PM
devin87's Avatar
My RZR: rzr 570
Member #34147
I do.
devin87 is offline
post #7 of 16 Old March 3rd, 2013, 05:48 PM Thread Starter
570razor's Avatar
First Name: Jim
Member #50018
Re: Rev limiter
Hey Devin, I have 26" tires and I felt that my mid range power was missing. I had 48 weights put in and there and was a ton of mid range but not enough top end. Polaris doesn't make a 50 gram clutch weight and that's what I thought would really work perfectly. I to took my stock 52 grams and ground them down evenly. I bought a $12 scale at habor freight to measure the weight. My mid range is better tha stock and my top end is back to the normal 58 mph on GPS.
I took it out for a couple test runs and I smelt rubber burn a little. I thought it was the belt.
Well after hammering the gas on asphalt from a dead stop about dozen times, I realized it wasn't my belt. I was burning my tires up! Lol.... So if you feel like you lost some mid range with your 26 tires that a good fix.
570razor is offline
post #8 of 16 Old March 4th, 2013, 01:47 PM
devin87's Avatar
My RZR: rzr 570
Member #34147
I was thinking about an adjustable clutch kit but wasn't sure how much of a difference it would make. I didn't notice Any power loss with my tires because they have been on it since New.
devin87 is offline
post #9 of 16 Old March 4th, 2013, 02:03 PM Thread Starter
570razor's Avatar
First Name: Jim
Member #50018
Re: Rev limiter
I would go with an adjustable weight. You would pick up some good mid range power.
570razor is offline
post #10 of 16 Old March 4th, 2013, 06:13 PM
RazerMac's Avatar
First Name: Roy
My RZR: 570 Trail LE
Member #51522
View RazerMac's Photo Gallery(0)
Re: Rev limiter
Are there any on-line discussions on how to do this? Sounds like just the ticket for me. I could figure it out, but prior knowlege is a good thing. Thanx
Roy
RazerMac is offline
post #11 of 16 Old March 4th, 2013, 06:39 PM Thread Starter
570razor's Avatar
First Name: Jim
Member #50018
Re: Rev limiter
To change clutch weights? Pull off your clutch cover, you will see 8 bolts on your primary clutch. Loosen the 8 gold bolts. You will also see your three clutch weights. After you loosen the bolts you can take your clutch weights out. You can't miss the clutch weights.
This is a great time to learn how to change a belt to. I never did any of this and it was easy.
Take your tire off to make this enjoyable and a lot easier.
570razor is offline
post #12 of 16 Old March 4th, 2013, 06:46 PM
RazerMac's Avatar
First Name: Roy
Member #51522
Re: Rev limiter
You da man - thanx again.
Roy
RazerMac is offline
post #13 of 16 Old March 5th, 2013, 01:47 PM
soapy's Avatar
My RZR: 2017 rzr 1000S
Member #24680
View soapy's Photo Gallery(2)
Re: Rev limiter
Starting Line Products installed adjustable clutch weights on mine and also installed a Team secondary. I think with the Team clutch they actually used a 54 on the primary for the best performance with my 26 inch Bear Claw Htrs.
soapy is offline
post #14 of 16 Old March 5th, 2013, 03:02 PM Thread Starter
570razor's Avatar
First Name: Jim
Member #50018
Re: Rev limiter
I thought you had 48 weights in yours?
570razor is offline
post #15 of 16 Old March 6th, 2013, 08:37 AM
soapy's Avatar
Member #24680
Re: Rev limiter
When I had the stock secondary clutch I did have 48s in mine when using the 26 inch tires. When I added the TEAM secondary clutch they found that the 54s worked better at my altitude and machine setup.
soapy is offline
rev limiter longbow Engine and Drivetrain 3 July 23rd, 2011 03:49 PM
How to get rid of rev limiter ROOSTER_AP General RZR Discussion 16 June 3rd, 2011 07:03 AM
XP Rev limiter, here it is s2k1 RZR XP 900 15 April 4th, 2011 05:18 PM
Is there a way to take the limiter off of my '08 RZR RAZORFREAK General RZR Discussion 7 December 1st, 2009 12:07 PM
Rev Limiter m741329 Engine and Drivetrain 6 April 24th, 2008 08:26 AM
