Exactly where do you adjust the throttle cable? - Polaris RZR Forum - RZR Forums.net
This is a discussion on Exactly where do you adjust the throttle cable? within the RZR 4 Specific Discussion forums, part of the General RZR category; So i was reading about adjusting the throttle cable, and noticed there is about 1/2" slack in mine, obvious as the cable is slacked at ...
Go Back   Polaris RZR Forum - RZR Forums.net > General RZR > RZR 4 Specific Discussion
RZR 4 Specific Discussion For all discussions about the four seater RZR 4 800!
Old September 21st, 2011, 07:58 AM   #1
bishop1670's Avatar
My RZR: 2011 RZR 4 EPS "the Blue Car"
Member #2995
View bishop1670's Photo Gallery(0)
So i was reading about adjusting the throttle cable, and noticed there is about 1/2" slack in mine, obvious as the cable is slacked at the peddle. However, it seemed that the cable stopped pulling just before the peddle hit the floor, like the last 1/2-1/2" was just me pushing it. I read someone posted see how far your peddle moves before the rpms move, and it is about 1/2". I just want to make sure i am not just searching for something that is not there.
Anyways, There is not adjustment at the peddle i could find, and i could not get to the throttle body in the back, yet i might add. Do i need to take off the entire bed, to get to it. i removed the back seats, and the panel, and the clutch vent tube connection, and still could not see it. I guess what i want to know is, do i need to take the bed top, or bed off to get at the throttlebody. Also figured there might be an adjustment under the car somewhere, under the skid plate. Just looking for a little direction from those that have done this.
Thanks,
Chris Bishop
bishop1670 is offline   Reply With Quote
Old September 21st, 2011, 08:16 AM   #2
Feedback Score: 11 reviews
mark5193's Avatar
First Name: mark
Member #1018
View mark5193's Photo Gallery(5)
Re: Exactly where do you adjust the throttle cable?
it is there, and you do not need to take the bed off. there is a little rubber boot covering the adjustment nut. super easy.
2016 yamaha yxz
2009 yfz 450r
2006 raptor 700
2008 bounder 34g
mark5193 is offline   Reply With Quote
Old September 21st, 2011, 08:19 AM   #3
FunRide's Avatar
First Name: Jim
My RZR: None
Member #17399
Mark, Think he's lookin' for the exactly location of said adjustment nut
FunRide is offline   Reply With Quote
Old September 21st, 2011, 08:25 AM   #4
Feedback Score: 176 reviews
swingarm1's Avatar
First Name: Tim
Member #7690
Thanks,
Chris Bishop
Your in the right area... With the panel removed behind the seats, locate the intake manifold (located on the drivers side of the head), moving towards the drivers side of the RZR 4 the throttle body is next and the throttle cable is attached to the throttle body... Pull back the rubber boot, it takes a 10mm wrench and a 8 mm wrench to adjust the throttle cable... Turning the adjuster in is lower RPM, turning the adjuster out increases the RPM...
Hope this answers your question
Old September 21st, 2011, 09:53 AM   #5
bishop1670's Avatar
Member #2995
Thanks guys, i will give it another try this evening, and hope for better results.
Thanks,
Old September 21st, 2011, 10:01 AM   #6
crazyguy's Avatar
First Name: Jay
My RZR: 2012 xp 900 voo doo
Member #21942
View crazyguy's Photo Gallery(0)
I adjusted mine all the way till the adjuster ran out of threads and i still have 1/2"+ play in the pedal.
crazyguy is offline   Reply With Quote
Old September 21st, 2011, 12:58 PM   #7
fngman's Avatar
First Name: Eric
My RZR: 2011 RZR4
Member #19917
View fngman's Photo Gallery(0)
I just adjusted mine (2011). I had to take the bed off, as there was no access to the cable through the access panel.
fngman is offline   Reply With Quote
Old September 21st, 2011, 02:14 PM   #8
King of crash!
Member #787
the slack adjuster is about 1.5 ft from the tb.. just follow the cable back till you find it
Old September 21st, 2011, 09:52 PM   #9
wild woody's Avatar
First Name: Jeff
My RZR: 170 and RZR 4
Member #8753
View wild woody's Photo Gallery(0)
so doing this will give you more speed ?
wild woody is offline   Reply With Quote
Old September 21st, 2011, 10:37 PM   #10
Magicmantx's Avatar
First Name: Bruce
My RZR: 2016 Graphite XPT
Member #20584
Not sure on a 4 but on my 2011-s I couldn't get to it from the inside panel so i just pulled the bed off for a couple of reasons. First it made it reallt easy to find and adjust the throttle cable adjuster which on mine was screwed right on the throttle body. Second it allowed me to clean everything good. Third It allowed me to get a good look at my vent tubes that from outward appearances looked fine but with the bed off i found the two melted. Pulling the bed was simple to do and took about 3o minutes and now that I.ve done it once could do it in less time. The end result is definitly worth the effort. Once you pull the bed its right in front of you. There is a black rubber boot over the jamb nut just pull it back . I believe it was a 14 or 15 mm.
:TX
Brunomspts@yahoo.com
Magicmantx is offline   Reply With Quote
Old September 21st, 2011, 10:44 PM   #11
Magicmantx's Avatar
First Name: Bruce
Member #20584
yep and better response. Feels like alot more hp . Apparantly mine has always been wrong. Fastest mine ever went was 61 after doing some alignment adjusting but had slowly gotten slower. I guess the cable stretched some. Recent top speed was 55-56 now hits 66 and gets there alot quicker. I thought everybody was kinda exegerating there top speed but not anymore.
:TX
Old September 22nd, 2011, 07:03 AM   #12
dajo's Avatar
First Name: Dave
My RZR: 2010 RZR4 Street legal
Member #19884
View dajo's Photo Gallery(0)
After reading on her about all the loose cables I checked mine and it was adjusted good. Always looking for a little more power.
dajo is offline   Reply With Quote
Old September 22nd, 2011, 07:46 AM   #13
Spicoli's Avatar
First Name: Jonathan
My RZR: 2009 Polaris Rzr
Member #5093
View Spicoli's Photo Gallery(0)
Think I might check mine...Maybe I can get up to 85 quicker
Rzr Weber Sold. Need new ride desperately!
Spicoli is offline   Reply With Quote
Old September 22nd, 2011, 12:42 PM   #14
Scrubbs's Avatar
Member #14859
View Scrubbs's Photo Gallery(0)
This is not a good long term solution, but after installing my snorkel kit and putting everything back together, and THEN reading this thread, I took three small washers, cut a small section out to form a V, and inserted them at the pedal end of the cable, in between the pedal frame and the cable end flare. A couple of wraps of black tape, and you are on the go again until you can get time for a more in depth fix. Use the required number of washers to clear all slack out but not increase your idle.
2" Racer Tech Lift Kit, Snorkel Kit, Front/Rear Guards, Rock Sliders, Aluminum Skids w/A Arm Guards, Poly Roof, Wicked Built PS
Still looking for the ATM slot, cause I know I have a lot of money stored in this thing, be nice to retrieve some of it back.......
Scrubbs is offline   Reply With Quote
Old September 22nd, 2011, 01:18 PM   #15
Tiorum3's Avatar
First Name: Al
Member #10509
I had heard recently that they all come set that way by the factory so you don't really get to 6600 RPM you only get to 6000. That way its less stress on the motor over time. You have to fix it to get the throttle to open up all the way. Sneaky Polaris!
http://i265.photobucket.com/albums/ii202/Tiorum3/Allegheny%20off%20road/aor-stickerjpeg_zps3be9880e.png
see our website for more product details at: www.alleghenyoffroad.com
Tiorum3 is offline   Reply With Quote
2014 polaris rzr 800 throttle cable adjustment
adjust throttle on polaris atv
adjust8ng throttle cable rzr 800
adjusting the throttle speed on rzr170
how do i adjust the throttle cable on my polaris rzr
how do you tighten the clutch cable on a 800 rzr
how to adjust throttle cable on 09 rzr
how to adjust throttle cable on a polaris rzr
how to adjust throttle cable on rzr
how to adjust throttle cable on rzr 800
how to adjust throttle cable polaris rzr 800
how to tighten throddle cable on 2005 polaris fusion
polaris 800 s rzr le throttle cable adjustment
polaris rzr throttle cable adjustment
where does the throttle cable enter the engine on a 2013 rzr xp900
Anyone have photo of where to adjust the throttle cable? jmw5016 General RZR Discussion 2 June 8th, 2011 09:41 AM
Throttle cable removal hoodlum General RZR Discussion 3 January 10th, 2010 06:47 AM
throttle cable vectorboy_99 Engine and Drivetrain 3 December 26th, 2009 10:47 AM
throttle cable bobby Projects and How-To 7 October 25th, 2009 06:06 PM
Adjust the throttle cable? IXIswamperIXI Engine and Drivetrain 2 February 13th, 2008 04:30 PM
