Big wheel kit question.... - Polaris RZR Forum - RZR Forums.net
RZR 170 Specific Disccusion For all discussions about our little buddy - the Polaris RZR 170 and the RZR 170 EFI!
post #1 of 27 Old September 10th, 2012, 06:37 PM Thread Starter
AKmud's Avatar
My RZR: 170...Modestly modded
Member #39416
View AKmud's Photo Gallery(0)
For those of you that have used the factory big wheel kit, is the new gearing faster than stock? I put the wheels/tires on but never bothered changing out the sprockets and chain that came with the kit. I was trying to figure out the math, but with the increase in tire diameter I was getting a headache...
My initial thought was it probably just geared down for a little more low end which would not help top end....
Any experience? Should I make the change?
'08 WR450F
'06 PW80
'02 Honda Rancher 350
'92 Honda Fourtax 300
'04 Polaris Predator 90
'12 Polaris RZR 170
AKmud is offline
post #2 of 27 Old September 10th, 2012, 09:06 PM
NCsledhead's Avatar
First Name: Kip
My RZR: 2012 900 XP / 2014 570
Member #44603
View NCsledhead's Photo Gallery(0)
Re: Big wheel kit question....
I have the kit installed on my sons 170 and did NOT make the change. The stock gearing has worked flawlessly for the last 150 miles in all types of conditions; mud, steep climbs, hard pack, ruts. Prior to the BWK he ran the 170 with stock tires for about 50 miles, after the upgrade he claimed a bit more snap out of the hole. The top speed pans out at 31 mph
NCsledhead is offline
post #3 of 27 Old September 10th, 2012, 10:46 PM Thread Starter
AKmud's Avatar
Member #39416
31 is the same number I'm getting....I'm just wondering what difference the gear change will make...
'08 WR450F
'06 PW80
'12 Polaris RZR 170
AKmud is offline
post #4 of 27 Old September 25th, 2012, 05:50 PM
SPearOps's Avatar
My RZR: 800s-LE, RZR 170,
Member #44388
View SPearOps's Photo Gallery(0)
I have installed the full big wheel kit, new sprockets and skid plate. Here is what I have found. My top speed before the kit was 27 mph and with the gear change I get 34mph top end. I did notice it takes longer to get up to speed but is faster. We live in Fl so we mostly drive in suger sand, water and mud. We went out after the install and it has more clearance for the water and overall performed great. I will say that I noticed it struggling to get up the ramp when loading it on the trailer from a dead stop. It seems to have lost some low end power. I am not sure how that will effect the hill climbing in other areas then Fl. Talking with the polaris dealer he explained polaris designed the kit specificly not to tear up the transmission with the bigger tires. His explaination is that the engine is not powerful enough to turn much bigger tires or too agressive treads effectively. What I want to know from someone is which stock sprocket would you put back on to get back some of the low end power? And how do you think it will effect the transmission concern the dealer has? Hope this helps someone.
SPearOps is offline
post #5 of 27 Old October 10th, 2012, 01:00 PM
gearwrench's Avatar
First Name: jim
My RZR: 2012 xp900 lq silver
Member #38175
View gearwrench's Photo Gallery(0)
How much is the big wheel kit? where do you get them and how much higher will they lift the machine?
gearwrench is offline
post #6 of 27 Old October 14th, 2012, 09:02 PM
NCsledhead's Avatar
First Name: Kip
Member #44603
I paid just under $500 for them at Search Results for "babbitsonline.com", they have an MSRP of nearly $700, they are a Polaris OEM part. The kit also comes with a new chain and sprokets, I left the stock as is, more low end and tops out at 32mph.
The tires lift at least 3 inches over stock. The tires are only 2 ply, was worried about that at first, we ride on a lot of shale and jagged rock, havn't had any problems as of yet, 150+ miles.
post #7 of 27 Old October 15th, 2012, 04:50 AM
matt68's Avatar
Member #36335
View matt68's Photo Gallery(0)
what is the tire size of the big wheel kit?
Sent from my Kindle Fire using Tapatalk 2
matt68 is offline
post #8 of 27 Old October 15th, 2012, 08:39 PM Thread Starter
AKmud's Avatar
Member #39416
They are 22"
'08 WR450F
'06 PW80
'12 Polaris RZR 170
AKmud is offline
post #9 of 27 Old October 16th, 2012, 06:27 PM
Kraven's Avatar
Member #9015
View Kraven's Photo Gallery(0)
Cool Re: Big wheel kit question....
Originally Posted by AKmud View Post
They are 22"
What size rims?
BYRON, IL 1984. 9.47 E.T. 137+ M.P.H.
'72 DODGE COLT, MILD 426 WEDGE, TORQUEFLITE, 4.56 DANA, FULL TUBE CHASSIS, STRANGE STRUTS, 4-LINK, DOUBLE ADJ. KONI COIL-OVERS, 15" x 33", WELD SUPER-LITES, FUEL CELL, EVERYTHING ON DZUS FASTENERS AND QUICK RELEASE PINS. LEAVING THE STARTING LINE CARRYING THE FRONT WHEELS AND STOPPING IT FROM 137+ M.P.H. WITH A PARACHUTE, PRICELESS!!!
Kraven is offline
post #10 of 27 Old October 16th, 2012, 07:07 PM
matt68's Avatar
Member #36335
does the big wheel kit require spacers?
matt68 is offline
post #11 of 27 Old October 16th, 2012, 07:27 PM Thread Starter
AKmud's Avatar
Member #39416
No, it bolts right up. The rims are 10".
'08 WR450F
'06 PW80
'12 Polaris RZR 170
AKmud is offline
post #12 of 27 Old October 17th, 2012, 01:02 PM
gearwrench's Avatar
First Name: jim
Member #38175
I just ordered a set from polaris will see how it goesw thanks guys.
post #13 of 27 Old October 17th, 2012, 04:30 PM
Kraven's Avatar
Member #9015
Thanks for the info on wheel size.
Trying to decide between 10" and 12" diameter rims
Kraven is offline
post #14 of 27 Old November 2nd, 2012, 07:07 AM
heypilch's Avatar
First Name: Tim
Member #46343
View heypilch's Photo Gallery(0)
Usa Re: Big wheel kit question....
Has anyone found a non Polaris option that would achieve the same result without the 700+ (after shipping) price tag?
http://www.woundedwarriorproject.org
"The democracy will cease to exist when you take away from those who are willing to work and give to those who would not." - Thomas Jefferson
heypilch is offline
post #15 of 27 Old November 2nd, 2012, 07:40 PM
Cyclepartswarehouse's Avatar
Member #35580
View Cyclepartswarehouse's Photo Gallery(0)
Why not 14in? Lol
Parts Manager at CyclePartsWarehouse.com Longview, TX
Cyclepartswarehouse is offline
Wheel question Dangit800 RZR 4 Specific Discussion 5 August 30th, 2012 09:39 AM
Wheel question hoodlum General RZR Discussion 0 February 6th, 2011 12:13 PM
a wheel question hoopers2 RZR-S Specific Discussion 4 September 22nd, 2010 03:34 PM
Wheel question...PLEASE HELP! Loanshark Wheels and Tires 3 April 1st, 2009 05:32 PM
Question about wheel spacers/wheel offset caspian Wheels and Tires 8 October 2nd, 2008 11:38 AM
