spark plug gap - Polaris RZR Forum - RZR Forums.net
RZR 170 Specific Disccusion For all discussions about our little buddy - the Polaris RZR 170 and the RZR 170 EFI!
post #1 of 4 Old August 5th, 2012, 06:50 AM Thread Starter
Blackbelt's Avatar
spark plug gap
What do you set the gap to?
Blackbelt is offline
post #2 of 4 Old August 5th, 2012, 07:03 AM
Feedback Score: 176 reviews
swingarm1's Avatar
Re: spark plug gap
Depends on which type and model of plug your using...
Some plugs are pre-gapped and you DON'T gap them...
You might want to purchase or download the service manual for your ride... It'll answer all your maintenance questions... Then you can have the info every time you need it...
Gapping
Since the gap size has a direct affect on the spark plug's tip temperature
and on the voltage necessary to ionize (light) the air/fuel mixture, careful attention is required. While it is a popular misconception that plugs are pre-gapped from the factory, the fact remains that the gap must be adjusted for the vehicle that the spark plug is intended for. Those with modified engines must remember that a modified engine with higher compression or forced induction will typically require a smaller gap settings (to ensure ignitability
in these denser air/fuel mixtures). As a rule, the more power you are making, the smaller the gap you will need.
A spark plug's voltage requirement is directly proportionate to the gap size. The larger the gap, the more voltage is needed to bridge the gap. Most experienced tuners know that opening gaps up to present a larger spark to the air/fuel mixture maximizes burn efficiency. It is for this reason that most racers add high power ignition systems. The added power allows them to open the gap yet still provide a strong spark.
With this mind, many think the larger the gap the better. In fact, some aftermarket ignition systems boast that their systems can tolerate gaps that are extreme. Be wary of such claims. In most cases, the largest gap you can run may still be smaller than you think.
swingarm1 is offline
post #3 of 4 Old August 5th, 2012, 07:13 AM
BarRZR's Avatar
Re: spark plug gap
Install NGK Iridium plugs, #BKR7EIX, and DON'T re-gap them! They'll probably out-last your engine. My two-bits.............
Cheers
BarRZR is offline
post #4 of 4 Old August 5th, 2012, 09:23 AM Thread Starter
Blackbelt's Avatar
Re: spark plug gap
This is going in a 170. I have an ngk plug already but not an iridium. That plug you listed fits the 800 and is what i use in mine.
Btw i had a pdf service manual but the computer crashed and i am not going to buy again. I am sure someone will eventually post a link to a 170 manual again. I already found the one for mine again for free.
RZR 570 NGK spark plug pj8556 RZR 570 Specific Discussion 7 June 9th, 2014 01:05 PM
12 570 spark plug???? 2012rzr570 RZR 570 Specific Discussion 26 January 31st, 2013 07:54 AM
spark plug charlot RZR 900 Engine 16 June 23rd, 2012 09:01 AM
RZR 800 best spark plug? redrzrrider General RZR Discussion 23 June 5th, 2012 08:05 AM
Where's the spark plug? JShows Engine and Drivetrain 21 February 27th, 2012 06:10 AM
