170 stalls on whoops - Polaris RZR Forum - RZR Forums.net
This is a discussion on 170 stalls on whoops within the RZR 170 Specific Disccusion forums, part of the General RZR category; My 170 stalls a lot when going over whoops. I was thinking maybe the choke cable came loose again or it's getting too much gas. ...
Go Back   Polaris RZR Forum - RZR Forums.net > General RZR > RZR 170 Specific Disccusion
RZR 170 Specific Disccusion For all discussions about our little buddy - the Polaris RZR 170 and the RZR 170 EFI!
Old May 18th, 2012, 08:00 AM   #1
WChighfill's Avatar
First Name: Carl
My RZR: 170
Member #39268
View WChighfill's Photo Gallery(0)
My 170 stalls a lot when going over whoops. I was thinking maybe the choke cable came loose again or it's getting too much gas. Anyone else have this issue or any ideas of what it could be??
WChighfill is offline   Reply With Quote
Old May 19th, 2012, 08:54 PM   #2
XP900Chic's Avatar
First Name: Nikki
My RZR: 2011 RZR XP 900 White Lightning
Member #28769
View XP900Chic's Photo Gallery(0)
Re: 170 stalls on whoops
Ours kept stalling over bumps and when we turned hard right or left turns, especially right. Very odd! This was after we installed a big bore kit so we were stumped. Tried everything and finally found out it was the hi rev ignition coil. You might also check your fuel pump and vacuum lines. Good luck!
XP900Chic is offline   Reply With Quote
Old May 23rd, 2012, 09:59 AM   #3
WChighfill's Avatar
First Name: Carl
My RZR: 170
Member #39268
Cool thanks
170 rzr shuts down when run in water
polaris 170 dies turning to the right
polaris rzr 170 shuts off when u hit bumps
polaris rzr sputtering after bumps
rzr 170 bump stall
rzr 170 dies when hitting bumps
rzr 170 stalling have to pull choke
rzr 170 stalling on down hill
rzr 170 stalls down hill
rzr 170 stalls going over bumps
rzr 170 stalls in hills
rzr forum 170
rzr170 stalling
rzrz 170 stalling
stall over whoop
Rough idle then stalls?? hitter44 General RZR Discussion 20 April 8th, 2014 11:00 AM
RZR 170 stalls in a right turn CoryD RZR 170 Specific Disccusion 3 January 20th, 2011 06:48 PM
rzr 4 sputters,backfires,stalls out riverride Engine and Drivetrain 9 February 9th, 2010 09:35 AM
ruff idle then stalls weekend warrior Engine and Drivetrain 10 January 15th, 2010 01:21 PM
Low Idle and stalls Kragar General RZR Discussion 1 June 7th, 2009 12:53 PM
