Made Snorkels
This is a discussion on Made Snorkels within the RZR 170 Specific Disccusion forums, part of the General RZR category; I just made some snorkels for the little RZR after spending much time reviewing what you had all done. I have gone with Crow belts ...
Go Back   Polaris RZR Forum - RZR Forums.net > General RZR > RZR 170 Specific Disccusion
RZR 170 Specific Disccusion For all discussions about our new little buddy!
Old January 21st, 2010, 07:45 PM
mnctxusa's Avatar
My RZR: 2010 170 RZR and 2010 Ranger Crew
Member #12188
View mnctxusa's Photo Gallery(0)
Made Snorkels
I just made some snorkels for the little RZR after spending much time reviewing what you had all done. I have gone with Crow belts and the bar behind the seat. Since I did not want to cut the body panels, I went through the holes left by the stock seat belts after I removed them.
Here are the pics
1. Fabricating them with PVC pipe
2. Passenger Side Fabrication
3. Drivers side Fabrication
4. Passenger side pre paint
Drivers side pre paint
Front view pre paint
Drivers side painted
Passenger side painted
Front view painted
Rear view painted
You will see in the rear view I have the Vent Racing intake along with the new belt support bar. Instead of using both bolts on each side for the support bar, I only used one each side, but angled the bar slightly forward before tightening it up. The Vent Racing intake fits perfect now, no touching the bar and no holes drilled in any of the body. I also made the final verticals slightly shorter before painting.
Next will be the front bumper bar, skid plates and exhaust...whew.
Old January 21st, 2010, 08:55 PM
Gunny's Avatar
First Name: Randy
My RZR: 2009 RZR S
Member #9486
View Gunny's Photo Gallery(0)
Re: Made Snorkels
Good work
Old February 2nd, 2010, 03:09 PM
lrenfro's Avatar
My RZR: RZR 170
Member #12546
View lrenfro's Photo Gallery(0)
Re: Made Snorkels
What size of PVC?
Old February 2nd, 2010, 03:19 PM
HioSSilver's Avatar
My RZR: Silver LE
Member #10535
View HioSSilver's Photo Gallery(0)
Re: Made Snorkels
what is that backend on it??
Old February 2nd, 2010, 03:51 PM
mnctxusa's Avatar
Member #12188
Re: Made Snorkels
I used 1.25" PVC tubing.
If you are referring to the "backend" as the top of the two snorkels, those are two 90 degree pieces. One of them is the type with the end that fits directly into the other. I had no PVC pipe between them.
Old February 2nd, 2010, 06:42 PM
wild woody's Avatar
Member #8753
View wild woody's Photo Gallery(0)
Re: Made Snorkels
so what does snorkeling the 170 do ? does it mean you can go into deep water and not mess or stall the motor up?
Old February 3rd, 2010, 01:35 PM
culvert's Avatar
Member #11469
View culvert's Photo Gallery(0)
Re: Made Snorkels
those snorkels are for the CVT. this keep mud & water out of the belt dirve causing problems.
  #8
Old February 8th, 2010, 09:12 PM
granthucko's Avatar
Grant
First Name: Grant
My RZR: rzr 170
Member #12474
View granthucko's Photo Gallery(0)
Re: Made Snorkels
Do you think you need to have the pvc extend that high above the rear bar ? I have snorkled the pipes behind my rear seats through the location of the old seat belts. I am thinking of leaving the relocation of the cvt behind the seats. Any opinion on not extending them up in the air. I felt just getting them out from behind the rear tires was good. Thanks for any help .
  #9
Old February 9th, 2010, 06:07 AM
mnctxusa's Avatar
Member #12188
Re: Made Snorkels
As long as you are not restricting the intake and exhaust on the snorkel they can be shorter. Mine were that long because my son liked the look.
Bookmarks
Home-made snorkels--incl. parts list guy48065 Projects and How-To 224 Today 06:21 AM
My Snorkels silveradols Projects and How-To 2 December 6th, 2009 08:51 PM
For those of you with snorkels ... tennman0258 General RZR Discussion 4 July 8th, 2009 09:17 AM
Snorkels Squirrel Duster Projects and How-To 20 January 18th, 2008 06:09 PM
snorkels rzrwrecker General RZR Discussion 5 January 16th, 2008 04:44 PM
