I just made some snorkels for the little RZR after spending much time reviewing what you had all done. I have gone with Crow belts and the bar behind the seat. Since I did not want to cut the body panels, I went through the holes left by the stock seat belts after I removed them.
Here are the pics
1. Fabricating them with PVC pipe
2. Passenger Side Fabrication
3. Drivers side Fabrication
4. Passenger side pre paint
Drivers side pre paint
Front view pre paint
Drivers side painted
Passenger side painted
Front view painted
Rear view painted
You will see in the rear view I have the Vent Racing intake along with the new belt support bar. Instead of using both bolts on each side for the support bar, I only used one each side, but angled the bar slightly forward before tightening it up. The Vent Racing intake fits perfect now, no touching the bar and no holes drilled in any of the body. I also made the final verticals slightly shorter before painting.
Next will be the front bumper bar, skid plates and exhaust...whew.
Here are the pics
Front view painted
Rear view painted
