This is a discussion on Adjustable RZR 900 XP Lift Kit! within the Rubberdown Customs forums, part of the Supporting Vendors category; I have made changes to my RZR 900 lift kit so that it can now be installed (takes about an hour) and once installed, you ...
Rubberdown Customs
Rubberdown Customs - 905-356-9181 |
I have made changes to my RZR 900 lift kit so that it can now be installed (takes about an hour) and once installed, you can quickly (15 minutes) convert it back to stock riding height.
Why did we do this you may ask??? We have had a few people tell us they love to play in the mud with big tires and loads of ground clearance, BUT this is also an amazing trail machine with a smaller set of trail tires. Now by swapping tires and changing a few bolts, you have your machine set up for the best of both world! I only made 5 kits on my first run of this revised kit and they will be back from the powder coaters in a few days so if you want one of these first 5 kits, let me know ASAP!
09 RZR, RDC 2" lift kit, Gas cap, Rad overflow Cap, Flame style Fairlead & Amsteel on a Vipermax 4500 winch 28.5" Dominators on SS wheels, Pro Armor Doors 2009 Sportsman 850 XP EPS, RDC Everything and LOTS of other stuff I cant afford 04.5 500HO "RACE ONLY", done to the nuts in RDC stuff, 46 HP! Shes drinkin 110 Octane & goes fast www.rubberdowncustoms.ca rubberdowncustoms@yahoo.ca (905) 356-9181
| Sponsored Links | ||
Sweet!!!! Can not wait for pics!!!!! All stock measurements at stock setting and then your 2 1/2" / 3" lift? Just moving the top shock bolt?
Will this kit be priced the same as your non-adjustable kit. Sorry for all the questions, just excited about this kit!!!! Sent from my iPhone using Tapatalk
2012 RZR XP White LE UTV, Inc. Nuke Cage w/ Rear Bumper & Roof, UTV, Inc. 3" Padded 5 point Harnesses, UTV, Inc. Custom Grill, UTV, Inc. Doors, UTV, Inc. A-Arm guards & Trailing Arm Sliders, & RDC Adjustable Lift.
Re: Adjustable RZR 900 XP Lift Kit!
Not sure yet, do you have an XP4 right now? Some of the part 3's are exactly the same, it just might work....
The only thing that might be different is the bolt size in the shock, but other than that I would think the same.
Yes I have one now. The highlifter kit said it would work, but the adjustment would not. I would like to run your lift if the adjustable portion would still work.
#9
I know that ours is really REALLY close to not working both ways on the 900 2 seater. I had it installed and tested here in my shop and it seemed to really work well in the stock position but under heavy aggressive riding the reservoir would lightly touch the shock mounts on the lift brackets. We did some modifications and it has a lot more room now but its still being somewhat tested. One problem with the testing being done by a friend is that now that he has it in the lifted position, since its nut a HUGE lift kit, he says he is never going back to stock. Says it handles awesome with the lift, good feedback yes, but hard to get him to move it moved back to stock position
#10
Paul.....I will have it on in stock position in harlen, KY in June. That will be a good test!!!!!
#11
I'm curious if anybody that makes an adjustable lift that compensates for the xp4 and xp walker Evans edition. The difference isn't in the bolt diameter it in the shock design. The rear shocks are walker Evans 2.5" body instead if fox 2" body. I think the reservoirs are different too. I'd like a 2-4" adjustable run so I could run 2" on rear and 4" on front then reduce the preload on front shocks to compensate for the difference and make the ride better. Then for play time put both on 4" and adjust preload stiffer.
2012 RZR 900 XP 4 LE Liquid Silver |
#12
im running 29.5 outlaw 2s will this adjustable kit clear my rubbing problems and whats the availability on this kit
#14
Grizzbrute, we are making another 10 kits now, should be ready in maybe 2 weeks. The rear lift kit has been modified for the last time as we put a large window in the lower portion of the rear lower parts to allow for more clearance for the reservoirs.
Photos of Rubberdown Customs | Facebook
| Search tags for this page |
2012 rzr 900xp 4 lift kit,catvos 4 lift on polaris 900xp,lift kit for polaris rzr 900,polaris rzr 900 lift kit,polaris rzr 900xp 2-1/2 lift kits,polaris rzr 900xp lift kit,polaris rzr xp 4 900 2 lift kit,polaris rzr xp 900 lift kit,rzr 900 2 in lift,rzr 900 lift kit,rzr 900 lift kits,rzr 900 xp 3 lift kit,rzr 900 xp lift kit,rzr xp 900 lift kit,who makes a shop lift for a rzr xp 900
| Thread Tools | |
| Display Modes | |
| SuperATV 1.5" to 3" adjustable lift kit | Super ATV | Suspension | 53 | April 8th, 2013 08:20 PM |
| Tony's Toys Adjustable Lift | Col_Sanders | RZR XP 900 | 9 | February 9th, 2013 05:55 PM |
| PRO Com Adjustable CDI RZR 800 | Quad411 | Polaris RZR Parts For Sale | 8 | January 10th, 2012 06:08 PM |
| Great Deal on Our 1.5-3 INCH Adjustable Lift Kit! | Super ATV | Suspension | 4 | July 9th, 2010 09:39 AM |
| Great Deal on Our 1.5-3 INCH Adjustable Lift Kit! | Super ATV | General RZR Discussion | 0 | June 1st, 2010 07:36 AM |
