This is a discussion on DIY roll cage builders within the Roll Cages and Safety Equipment forums, part of the Safety category; What kind of bender are you all using? Could you give me some pros and cons to them, as I'm going to start a new ...
| Roll Cages and Safety Equipment For discussion of roll cages |
What kind of bender are you all using? Could you give me some pros and cons to them, as I'm going to start a new cage here soon. I need all the info I can get, so anything will be appreciated...thanks in advance..
DA-OUTLAW...... ![]() NRA Last edited by Thrasherman; February 7th, 2012 at 07:26 PM. Reason: still cant spell |
| Sponsored Links | ||
Re: DIY roll cage builders
I possibly may do my own as well. Here is the best bang for the buck benders I could find after research.
JD Squared, Inc.
Just stay away from the $75 harbor fraught pipe crushers(bender). They crush the tube and make your bends even weaker then a quality bender. Get something that is ment to bend structural tubing. It's your safety. Don't skimp on things that matter.
For all those guys thinkin bout doin your own cage,I hav 60ft of1.75 x.095 wall d.o.m. tubing for 150$. Changed my mind and jus purchased a cage.
#8
A buddy and I built a cage for a desert truck I was working on a few years ago with a JD2 and just used it again to build one for the Rzr. Worked perfectly. Dies for different size tubing can get spendy after buying the bender, but you'll likely be able to get the bender, the die you need, a notcher, and the steel you will need for what you pay for a built cage.
Last edited by Duneroller; February 10th, 2012 at 06:21 AM. Reason: Added pic of bender. |
#10
I'm doing research for the same purpose. Liking what I'm reading on the JD2 bender, but was curious as to which die set others are using to bend the 1.75" .095 tubing for their cage? At $300-$400 a set, I don't want to order one that wont work for every bend I might want to make.
#13
I have a similar style to the JD2. If i bought another one i probably would buy the JD2 though. Its a very popular bender and set up for hydraulics. i have used a fast trick on a ranger cage i built to save money on dies. I used .120 DOM 1.75" for the main loops and .095 1.5" for the bracing. I took a piece of the .120 wall and bent it as far as the bender would. Then I cut the tubing in half long ways. One half was scrap, the other half is an adapter that fits into the 1.75" die and doing this math, 1.75-.120-.120= 1.51" My 1.5" diameter tubing fit right in and bent like a charm.
2010 RZR "$" |
#15
No, you'd have to buy a radius bender which works buy rolling the tubing. Their not cheap.
http://pro-tools.com/large-radius-benders.aspx |
| Search tags for this page |
2 cage,cheap roll cage for a 90 honda,diy arctic cat prowler roll cage,diy jeep builder,diy polaris rzr roll cage,diy roll bar,diy roll cage,diy rzr cage,diy xp rzr,isi tube bender forum,polaris rzr cage pipe,roll bar tubing size on a polaris rzr 900,roll cage diy,roll cage jd2,roll cage tube size on rzr 900,rzr roll cage dimensions,rzr xp race cage,rzr xp roll cage,what size pipe on can am commander roll cage,where to get roll cage pipe diy
| Thread Tools | |
| Display Modes | |
| RZR S Roll Cage | 09BMFRZRS | Polaris RZR Parts For Sale | 2 | January 23rd, 2012 02:50 PM |
| looking for a roll cage | rzrxpdean | RZR XP 900 | 13 | June 17th, 2011 08:20 AM |
| Builders | gridman | RZR XP 900 | 30 | March 11th, 2011 05:05 PM |
| need roll cage | pik 199 | Want to Buy | 0 | March 16th, 2009 05:34 AM |
| Roll cage Roll Call | papaglock | Roll Cages and Safety Equipment | 0 | April 29th, 2008 12:36 PM |
