| Roll Cages and Safety Equipment For discussion of roll cages |
need roll cage help |
May 5th, 2008, 09:59 AM
need roll cage help
For those who have built, or had built, roll cages for their RZR's, what diameter tubing did you use and what bend radius. I have a chance to pick up a JD Squared bender with some die's but want to make sure the bend radius will be right.
Thanks.
Re: need roll cage help |
May 5th, 2008, 10:14 AM
Rhino defector
My RZR: green gen 3 racer
i have the JD Squared model three and use 1.5" with 4.5" CLR. also use 1" die not sure of what CLR though. i bought a 1.75" die and never use it. all of the jeep and UTV cages i have been using 1.5" mostly and 1" for gussetts.
May 5th, 2008, 10:30 AM
Thanks!
Is the JD Squared pretty easy to use?
May 5th, 2008, 10:40 AM
Rhino defector
not too bad, keep everything lubed. just throw away the degree wheel and layout your bends with marks on the tubing. this is why you should have paid attention in math class, because you will need that math now.
May 5th, 2008, 11:39 AM
The stock cage is 1.75" .The bungs that you can get to match the original ones are for 1.75" O.D. .095 wall.
May 5th, 2008, 01:05 PM
Would you stay with 095 or go thicker?
Also, refresh me on the math :-)
My college kids are all....away at college!
Tony
