Home-made Lock N Ride Anchors
This is a discussion on Home-made Lock N Ride Anchors within the Projects and How-To forums, part of the General RZR category; No way I'm paying $18 each for the L&R hold-downs. They can only clamp something down to the bed and don't provide a place to ...
Old January 22nd, 2008, 07:23 AM
guy48065's Avatar
Feedback Score: 4 reviews
Member #309
No way I'm paying $18 each for the L&R hold-downs. They can only clamp something down to the bed and don't provide a place to tie off or anchor a bungee. So I made my own.
There are a few different types of expanding rubber plugs available in hardware, boating and plumbing stores. Here are some choices of 1" stoppers that should be available at most well-stocked hardware stores and plumbing supply:
The rubber on the left and right plugs is a little soft so I didn't trust it to be a good anchor. The plug in the middle uses a rubber stopper that's firm and solid. Once snugged in place I'm unable to pull it out. To make it usefull as a tiedown I replaced the metal parts with a 1/4-20 x 1.5" eyebolt and a 1/4-20 "T-nut". A T-nut is a woodworking nut with barbs that sink into wood to keep the tapped nut from spinning. Cut or grind the barbs off leaving tiny nibs to keep the nut from rotating on the rubber stopper. Run a regular nut up the shaft to jam against the eye or the end of the threads. Re-use the large flat washer that came with the stopper. Spin on the T-nut and the finished anchor will look like this:
As you finger-tighten the eyebolt the rubber is squashed between the T-nut and flat washer and expands to grip the hole in the bed. Don't overtighten or you risk cracking the plastic sleeve in the hole.
You can also substitute a hook for the eyebolt to make an anchor that's convenient for looping the middle of a bungee thru.
Why buy the cow?
Old January 22nd, 2008, 10:43 AM
Jim's Avatar
Jim Jim is offline
"RHINO" HUNTER
First Name: Jim
My RZR: green 08
Member #431
View Jim's Photo Gallery(0)
Re: Home-made Lock N Ride Anchors
WOW! that's is an awsome tip. thanks for sharing
Old January 22nd, 2008, 11:04 AM
RZRider's Avatar
First Name: Al
My RZR: 08 Red
Member #482
View RZRider's Photo Gallery(0)
Yeah, the one on the far left is a waste of time. Under constant load and a few miles on the trails, the sucker pops like a cork.
Old January 22nd, 2008, 11:22 AM
mdevans's Avatar
Member #878
View mdevans's Photo Gallery(0)
you dont need l&r plugs i just clamped rubber bungie hook in a vice and bent it out a little. this way nothing stick's up and gets in the way. just slip bent out hook into l&r hole. but if you dont have to worry about l&r loop sticking up it would work great.good idea for some cases.it would be a good idea to use some anti-seaze. (?)
Old January 23rd, 2008, 06:08 PM
guy48065's Avatar
Member #309
I made up a bunch and keep them in a box in my tote along with a couple bungies and some parachute cord. You can see on the left one what the T-nut looks like with the barbs cut off.
Old January 23rd, 2008, 06:31 PM
kamper's Avatar
Member #562
View kamper's Photo Gallery(0)
Where can I find the rubber plugs?
Old January 23rd, 2008, 07:47 PM
guy48065's Avatar
Member #309
I found all 3 at a local ACE hardware. I don't think the big box stores carry plugs this small. It's getting harder to find the well-stocked neighborhood hardwares we used to take for granted til the giants drove them out of business.
  #8
Old January 30th, 2008, 01:53 PM
bigd451's Avatar
Member #1128
View bigd451's Photo Gallery(0)
Great tip Mark! I made a few of my own, I just took it one step further and dipped the loops in rubber. I used Performix Plasti-Dip, they came out really nice. Check them out!
  #9
Old January 30th, 2008, 03:23 PM
Mudinyeri's Avatar
Stock ... sorta
First Name: Toby
Member #600
View Mudinyeri's Photo Gallery(0)
The plasti-coat adds a nice touch. Great tips, guys!
For an online source, check out McMaster-Carr. I'll see if I can find a link.
  #10
Old January 30th, 2008, 03:35 PM
RZRider's Avatar
First Name: Al
My RZR: 08 Red
Member #482
Nice touch on the eyelet.
  #11
Old January 30th, 2008, 03:37 PM
BKozan's Avatar
...at the Speed of Life
First Name: Brian
My RZR: 2007 Kawasaki ZZR 600
Member #251
View BKozan's Photo Gallery(0) Send a message via AIM to BKozan Send a message via MSN to BKozan
Awesome project!
  #12
Old January 30th, 2008, 03:53 PM
RZRider's Avatar
First Name: Al
My RZR: 08 Red
Member #482
I'm addicted to that place.
McMaster-Carr
  #13
Old January 30th, 2008, 07:18 PM
guy48065's Avatar
Member #309
Very nice finishing touch there
Why buy the cow?
  #14
Old January 30th, 2008, 08:57 PM
HOTRIDE4U's Avatar
Hotride4u
First Name: Kelly
My RZR: The New one lol
Member #280
View HOTRIDE4U's Photo Gallery(0)
How hard is it to remove after you have it in after a hard ride or length of time?
Thanks,
Kelly
www.hotride4u.com
sales@hotride4u.com
  #15
Old January 31st, 2008, 05:45 AM
Mudinyeri's Avatar
Stock ... sorta
First Name: Toby
Member #600
guy, do you know the name for the plug you used? I can't seem to find anything quite like it in the McMaster site ... and that's rare.
Bookmarks
my home made top 09 LE NUCLEAR SUNSET rjrzr Members Rides and RZR Of The Month Contest! 3 April 5th, 2009 07:26 PM
New home made billet grill cwspfx RZR-S Specific Discussion 9 December 1st, 2008 10:19 PM
Home made snorkel and the location of them FORKLIFMAN Engine and Drivetrain 1 October 3rd, 2008 05:47 PM
home made lock and ride clamps? USMCSKI General RZR Discussion 9 March 29th, 2008 06:03 AM
home made skid plate idea mdevans General RZR Discussion 29 January 24th, 2008 07:59 PM
