Home-made Lock N Ride Anchors - Page 7 - Polaris RZR Forum - RZR Forums.net
This is a discussion on Home-made Lock N Ride Anchors within the Projects and How-To forums, part of the General RZR category; Quote: Originally Posted by bradlineberry Rmatv sells two tusk anchors for 3.50 a piece. Only comes in two pack for 6.99 Most i have seen ...
Old July 28th, 2012, 05:54 AM   #91
Official Parts Breaker
Feedback Score: 21 reviews
orangecrush's Avatar
My RZR: 2013 Jagged X
Member #21745
View orangecrush's Photo Gallery(20)
Re: Home-made Lock N Ride Anchors
Most i have seen on this thread dont look as good and cost just as much.
This may have been mentioned earlier i did not read the whole thread.
Adding another option.
I was thinking the same thing... I guess prices have come down because I ordered a 4 pack from EMP for 18 bucks.
Of course, I do love Ace and little hardware stores.
Mark
orangecrush is offline   Reply With Quote
Old August 1st, 2012, 06:04 PM   #92
Darkstone's Avatar
My RZR: RZR S
Member #36212
View Darkstone's Photo Gallery(0)
I bought the stuff to make one of these today. $6 and 10 minutes worth of time and it works great. Now I can get enough to make 5 more
John
Darkstone is offline   Reply With Quote
Old August 6th, 2012, 03:40 PM   #93
Stinky's Avatar
Member #39883
View Stinky's Photo Gallery(6)
I tried to get the expansion plugs locally and found the following:
O'Reilly Auto - $2.99/ea (1 in stock)
AutoZone - $2.99/ea (1 in stock)
Napa Auto - $4.59/ea (1 in stock)
ACE hardware - $4.00/ea (6 in stock)
O'Reilly and AutoZone were Doorman 1" - 1-1/8" (25mm - 28mm) Expand-Tite Rubber expansion plugs (#02600). Napa and Ace sold them un-packaged. Ace hade them in a pull out drawer on the nuts & bolts isle.
I got one from each of them because I went to Ace last and only planned on making 4. I got the following from Home Depot:
5/16" x 3-1/4" eye bolt w/ nut - $0.63/ea
5/16" tee nuts - $1.18/4pk
After building and testing those 4, I decided I needed at least 4 more. I decided this time to search online for a cheap price and found the exact same Doorman plugs cheaper:
rockauto.com - $2.56/ea (+$5.45 priority mail S&H for 8 plugs)
I got 8 more eye-bolts and 2 more packs of tee nuts from Home Depot for $7.90 making my total for these 8 tie-downs $33.83 after tax and shipping.
Also, I made mine just like @guy48065 did in the first post. Here is a list of the steps I took to build them:
1 - Remove the hardware from the plug. Keep only the rubber and the larger washer.
2 - Drill/ream the hole in the plug with a 3/8" drill bit. This isn't required, but will help keep the plug from expanding from the tee nut.
3 - Cut the barbs off the tee nut, leaving only little nubs. When the tee nut is used with the full barbs, it expands and makes it difficult to insert the finished tie down.
4 - Thread the nut all the way up to the eye. I've seen some made without this nut, but I think that might make it harder to hand-tighten from above.
5 - Put the eye bolt through the flat washer, then the rubber, then into the tee nut. Had tighten until the tee nut has set into the plug.
6 - Insert into a lock-and-ride hole in your RZR and hand tighten. I tightened them as much as I could without tools and they were pretty stable. I gave them all another 1/2 to 1/4 turn with a screw driver through the eyelet and had no fear of damaging the plastic on my RZR. With 4 of these and some bungees I kept my cooler and tool box in place without incident for 2 days on some fairly rough Uinta trails.
I've seen some of the ready-made versions of this plug using a fender washer and (nylon lock?) nut on bottom. If I were leaving these in semi-permanently, I would think that would give the best hold and stay power.
I also like the hook idea, but think I may just cut a 1/4 inch from a couple of my eye bolts where the bend returns to the eye or spread them out a little. That should give me enough of a gap to slide bungees or straps into the eye without having to feed them through.
Parts for 8 tie-downs (1 extra eye-bolt & pack of tee-nuts):
Rubber plug drilled out and barbs on tee nut clipped off:
The tee nut in the first plug has the full barbs still, the second one has them clipped. You can see how much the barbs distort the rubber and makes them harder to insert:
Close-up of a tee nut with the barbs cut off. I just used red-handle tin-snips:
My 8 newest complete tie-downs.
Stinky is offline   Reply With Quote
Old August 17th, 2012, 10:07 AM   #94
2009 rzr
MItrailrider's Avatar
First Name: jamie
My RZR: 2009 rzr 50"
Member #40232
View MItrailrider's Photo Gallery(27)
these are cool...im gonna make em tonight.... funny... i've used this plug before. When i was in virginia in 2010 i blew a spark plug in my excursion.... bought that rubber plug to plug hole and drive back to MI. Worked great.
MItrailrider is offline   Reply With Quote
Old August 17th, 2012, 10:57 AM   #95
Feedback Score: 16 reviews
guy48065's Avatar
Member #309
Mark
EMP has the right idea, Tusk doesn't. You need tools to install & remove the Tusk anchor. Easy in-out and finger tight is all you need. For the same $$ get the T-nut ones so you don't need to reach underneath with a wrench to hold the nut from spinning.
guy48065 is offline   Reply With Quote
Old August 21st, 2012, 07:41 AM   #96
Stinky's Avatar
Member #39883
I just received an email from rockauto.com with a 5% off coupon code that is re-usable. I checked to make sure it works and also noticed the plugs have come down to $2.34 each. The shipping for 8 of these has gone up to $7.41 (7 is still $5.45). You're better off placing 2 orders of 4. That makes it $23.18 for all 8.
Here's and excerpt of the email I received:
Your discount code is:
108544438911331
Enter the code above in the "How did you hear about us" line of the shopping cart. If you are using our traditional HTML catalog, please click the "Apply" button to the right of the field. Your discount will automatically appear, subtracted from your order total. Orders using discount codes must be placed online. Phone orders are not eligible for discounts.
The discount takes 5% off our already-low prices. There's no limit on order size or the number of orders. Use the code for your next order, and share the code with friends, neighbors, relatives, the guy at the corner garage--anyone you know who works on cars or trucks.
This discount code expires on October 21, 2012; so don't wait!
Old August 21st, 2012, 06:49 PM   #97
sparky1000's Avatar
My RZR: 2011 Polaris RZR 800 4
Member #41532
View sparky1000's Photo Gallery(0)
Do you have a part number for them at rockauto?
sparky1000 is offline   Reply With Quote
Old August 21st, 2012, 10:05 PM   #98
Stinky's Avatar
Member #39883
DORMAN Part # 02600 (Click here)
Old August 22nd, 2012, 04:59 PM   #99
sparky1000's Avatar
Member #41532
Thanks Stinky.. thats what I needed.
Old October 24th, 2012, 10:26 PM   #100
boardrider12's Avatar
First Name: Brian
My RZR: RZR-S (soon)
Member #41776
View boardrider12's Photo Gallery(0)
NV Re: Home-made Lock N Ride Anchors
Thank you everyone that posted on this thread! I have spent 2 and a half weeks chasing down a little piece of rubber to make these work and this is what I had found...
Autozone, Ace, Home Depot, O'Reily's, Lowe's, Walmart, West Marine, etc didn't have any clue where I could find this little piece of round rubber. Eventually, Pep Boys had 6 of them spread across 3 stores.
Big thank you for all of the ideas and suggestions. Now, I can go on my trip that I had planned with all of the gear I need.
Thanks Again!
boardrider12 is offline   Reply With Quote
Old October 26th, 2012, 09:05 AM   #101
ccrider72's Avatar
Member #18026
View ccrider72's Photo Gallery(0)
you should be able to find the rubber expansion plug at any hardware store that carriers the Hillman Brand of fasterners and such. Here's a link to the plug on their website.
Item # 58250-A, 1 to 1 1/8 in. Neoprene Expansion Plug on The Hillman Group
ccrider72 is offline   Reply With Quote
Old March 24th, 2013, 05:48 PM   #102
WyoBull's Avatar
First Name: Scott
My RZR: 2012 Rzr 800 Walker Evans Edition
Member #49635
View WyoBull's Photo Gallery(0)
Brass plug in original post on left side of picture is a simple boat drain plug that you can buy in any quantity you want at your local boat dealer.
I made up 6 of them last weekend in less than 30 minutes.
WyoBull is offline   Reply With Quote
Old April 1st, 2013, 08:52 PM   #103
TeamK's Avatar
First Name: David
My RZR: 2015 High Lifter
Member #46996
View TeamK's Photo Gallery(0)
Usa Re: Home-made Lock N Ride Anchors
I decided to make some billet lock and ride tie downs. Kind of time consuming but a different look.
[IMG]http://i1174.photobucket.com/albums/r602/TeamKRacing1/20130324_000340_zps6d9bf416.jpg
I have made tie downs for 3 different box and cooler holder combinations. I just took my Dee Zee box to my buddy to be spray foamed into a large cooler.
Polaris 2015 RZR 1K HIGH LIFTER:Polaris glass windshield, roof, back glass, upper cab doors, rear bumper, Digital Display, Polaris suspension seats, Shocks by ED the suspension guy, ssv works radio, lock&ride cooler, Rigid D2 10" led light bar, turn signals, running lights, Vendetta rock&tree kickers, Firestorm heater, Go Pro camera, Nexus 7 tab/GPS/BCN, Otrttw switches, 30-10-14 big horns, 2012 Ranger 800 HD, 2016 Ranger XP 900, 2016 PRO RMK 800 sled
06 Duramax Hauler, 08 Yamaha FX SHO Jet Ski
TeamK is offline   Reply With Quote
Old April 1st, 2013, 09:08 PM   #104
TeamK's Avatar
First Name: David
Member #46996
A few more
Old June 9th, 2013, 03:26 PM   #105
brianstrange's Avatar
Member #52885
View brianstrange's Photo Gallery(0)
I just made a set of these with parts from True Value. They had large (1") expansion plugs in plumbing, 1/4" x 3" stainless eye bolts, 3 prong t nut, and I added a nylock nut to prevent the assembly from coming apart. I didn't need to cut the t nuts as they only had 3 prongs. they go in the hole firm, and expand and grip very well. The nylock nut allows you to loosen everything completely without worries. All in all, they cost $6 each, but the rubber compond in these plugs is a bit softer than the automotive ones.
ID:	76904   Click image for larger version
ID:	76905   Click image for larger version
brianstrange is offline   Reply With Quote
Tags
guy48065
home made polaris lock and ride anhors
homemade eyebolts for polaris ranger
homemade lock and ride anchors
homemade lock and ride type tie downs
homemade polaris ranger tie downs
homemade rzr lock and ride
lock n ride polaris
polaris lock and ride anchor
polaris lock and ride anchors
polaris lock and ride boat plug
polaris lock and ride plugs
polaris ranger bed lock and latch
polaris ranger lock and ride anchors
rzr dyi bed anchors
home made lock and ride clamps? USMCSKI General RZR Discussion 11 April 14th, 2015 05:38 PM
home made skid plate idea mdevans General RZR Discussion 32 June 16th, 2010 11:07 PM
my home made top 09 LE NUCLEAR SUNSET rjrzr RZRForums Members' Rides 3 April 5th, 2009 08:26 PM
New home made billet grill cwspfx RZR-S Specific Discussion 9 December 1st, 2008 11:19 PM
Home made snorkel and the location of them FORKLIFMAN Engine and Drivetrain 1 October 3rd, 2008 06:47 PM
