Battery: Oddesy PC1200 Install
Old January 20th, 2008, 02:43 PM
txmd500's Avatar
txmd500 txmd500 is offline
Machine: 2008 RZR
Build date:
11-07
Purpose: During a skid plate removal I noticed the OEM wiring harness ran under the OEM battery box and was "sandwiched" between the battery box and the skid plate, actuals hangs down lower than the frame rail. There were noticeable wear marks on the skid place where the wiring harness loom had chafed. The harness did not have enough slack to reposition it, I thought this was a flaw in the OEM design/routing of the wiring harness, if the harness was about 3-5 inch's longer it could have been routed safely around the OEM battery box and not sandwiched between the battery box and skid-plate. I do feel it would have taken some time or a hard hit at that exact point before any damage would have been done to the wiring, but why be reactive when I can be pro-active, plus I got a larger battery out of the discovery. :-)
Costing:
Battery: $198.00 from local battery supplier. (Batteries Plus)
Materials: Aluminum Flat Bar $10.00 to $15.00 (Est) I used scrap I had laying around.
Difficulty:
Fabrication: Low (basic welding)
Installation: Low
Time:
Fabrication: Est. 2-hours. From design to completion.
Installation: 20-min
OEM Chassis and parts Modification(s):
OEM Battery Box: The OEM plastic battery box will need cut from adjacent under-seat storage tray. (See Attached Photos). Cut near the seam as close as you can to the OEM supporting bracket. (Use a flush cutting hand saw)
Drilling/Tapping: You will need to drill and either tap of use self-tapping screws on the frame rail and the inside OEM battery box supporting bracket.
Battery Specifications: CCA 550, 44-Amp hours (Compared to the OEM at 18-Amp Hours. Odyssey PC1200
Materials Needed:
Aluminum Flat Bar: (All measurements are in inches)
1pc @ 1 1/2 X 1/8 X 12 1/2
2pc @ 1/2 X 1/4 X 8 1/2
2pc @ 1/2 X 1/4 X 5 1/4
2pc @ 1/2 X 1/4 X 6
1pc @ 1 1/4 X 1/8 X 8
1pc @ 2 X 1/8 X 6
1pc @ 2 X 1/8 X 7
1pc @ 2 X 1/8 X 8
1pc @ 1 1/4 X 1/8 X 5 1/4
Miscellaneous:
Screws: 5pc @ #10 X 3/4 Self tapping stainless steel.
Felt Pads: Cut to size (Heavy Duty Felt Blanket) Buy at Home Depot used to place under furniture feet.
Rubber Pads: 1/2 Buy at Home Depot used to place under furniture feet.
Battery reconnection:
The OEM ground lead will be too short and you will need to make a new cable, the OEM positive is long enough. I plan on adding a positive and negative terminal strip so I will not cover the reinstallation of the OEM battery leads.
Re: Battery: Oddesy PC1200 Install
Old January 20th, 2008, 02:54 PM
blackballed blackballed is offline
My RZR: '08
Nice write up and thanks. I'm always amazed at how much great info that we receive from some pretty generous owners out there.
Old January 20th, 2008, 04:16 PM
RZRider's Avatar
RZRider RZRider is offline
First Name: Al
My RZR: 08 Red
Extremely nice write up, GREAT JOB!
Makes me wish I could weld.
My RZR Project
Keep It Wet and Dirty!
Old January 20th, 2008, 06:33 PM
yellowzx01's Avatar
yellowzx01 yellowzx01 is offline
First Name: Josh
My RZR: Gen 2 in pieces
Send a message via AIM to yellowzx01
Hey man thanks for the info. I think I am gonna switch out my batter to an odyssey battery too. Again great write up, Nicely done.
Old January 20th, 2008, 07:18 PM
randopolis randopolis is offline
i did smash and cut 3 wires in that harness in my first weekend of riding my rzr...pennsylvania rocks can be brutal. I'm working on my battery box now!!
Old August 17th, 2008, 09:05 PM
firerzr's Avatar
firerzr firerzr is offline
do you have any pictures?
Old August 19th, 2008, 10:01 PM
txmd500's Avatar
Here's a link to my web gallery
user name: rzr
PW: rzr
look for the photos titled "Batt#XX"
Click the photo for a larger view.
MobileMe Gallery
Jimmy
Old August 20th, 2008, 09:21 AM
supersonictoys supersonictoys is offline
password protected
Old August 20th, 2008, 09:25 AM
txmd500's Avatar
Originally Posted by supersonictoys View Post
password protected
User Name: rzr
Password: rzr
give that a go.
