Help with Transfer and Transmission Oil Change - Polaris RZR Forum - RZR Forums.net
post #1 of 12 Old June 1st, 2012, 03:03 PM Thread Starter
n7hwj's Avatar
First Name: Bill
My RZR: 2009 RZR LE Sunset Red
Member #16642
View n7hwj's Photo Gallery(3)
OK - I feel dumb but I've searched and found no good pictures so I'm hoping someone can help me.
The first picture is what I assume is the transfer case? Do I have the Fill, Level, and Drain identified correctly? Is the Drain, the 13mm behind the cable bundle? And is this the drain for the Tranny.
Does the "Fill" fill both the transfer case and tranny?
Sorry if these seem like dumb questions.
Bill
n7hwj is offline
post #2 of 12 Old June 1st, 2012, 03:07 PM Thread Starter
n7hwj's Avatar
First Name: Bill
Member #16642
Re: Help with Transfer and Transmission Oil Change
So I don't get confused I removed this post.
n7hwj is offline
post #3 of 12 Old June 1st, 2012, 03:26 PM
Sffisk1's Avatar
Member #38452
View Sffisk1's Photo Gallery(0)
The one you have mark drain is the level there is a drain farther underneath.
Sffisk1 is offline
post #4 of 12 Old June 1st, 2012, 03:37 PM
tanglefoot69's Avatar
First Name: Peter
Member #32425
View tanglefoot69's Photo Gallery(5)
In the first pic the one you have marked drain is the level for the transfer case,both drains are on the bottom.The engine oil drain takes an allen key,if you have an owners manual it will tell you the exact amounts to fill each one.I just did mine the other day and did it without removing the skid plate.It's easy just jack the machine up some to make it easier to get at.
2017 Polaris General 1000 White Lightening,Pro fit roof,Lock & Ride half windshield,Rear Panel,Rearview mirror,Polaris wireless winch remote,Polaris 4500lb winch.Polaris Glacier Pro Plow.
tanglefoot69 is offline
post #5 of 12 Old June 1st, 2012, 04:24 PM Thread Starter
n7hwj's Avatar
First Name: Bill
Member #16642
OK - I finally found two drains on the bottom (both 13mm) - one for the transfer case and another for the tranny.
Now in my picture, the plug I have labeled "Level?" is it the Level/Fill for the transmission?
Bill
n7hwj is offline
post #6 of 12 Old June 1st, 2012, 04:34 PM
First Name: Peter
Member #32425
Yes it is.
post #7 of 12 Old June 1st, 2012, 04:38 PM
Hleeh2o's Avatar
Member #38327
View Hleeh2o's Photo Gallery(0)
The plug on the right, put fluid in that hole until it runs out. Replace plug. Done
The plug on left that is marked drain, remove it, that's level plug. Put fluid into the left plug marked fill, until fluid comes out the level plug, replace both plugs. Done.
Can I get a hell yeah.
Hleeh2o is offline
post #8 of 12 Old June 1st, 2012, 05:02 PM
jack daddy's Avatar
My RZR: 2011 50"
Member #22982
View jack daddy's Photo Gallery(0)
I sub'ed to this thread since it helped with my questions. thanks
jack daddy is offline
post #9 of 12 Old June 1st, 2012, 05:09 PM Thread Starter
n7hwj's Avatar
First Name: Bill
Member #16642
Well it all seems so simple now but I'll tell ya this thing had me over a barrel.
Thanks to all who replied.
I think the biggest discovery was finding the drain plug for the transmission - I didn't think it would be up so high - had to use a 8" extension.
Geeze I spent a lot of time looking at the pictures in the manual and it just did not match up to what I was seeing.
So again, thanks to all.
Bill
n7hwj is offline
post #10 of 12 Old June 8th, 2012, 10:19 PM
Pirate's Avatar
First Name: Stuart
Member #3677
Well ya got it done. Ummm....you did put fresh fluid in didn't ya? LOL
Pirate
Pirate is offline
post #11 of 12 Old June 9th, 2012, 06:31 AM Thread Starter
n7hwj's Avatar
First Name: Bill
Member #16642
Pirate -
Yep went with Amsoil for everything but engine, I have a friend who is an Amsoil dealer. I used Mobil 1 0w40 and NAPA for the oil filter.
Bill
n7hwj is offline
post #12 of 12 Old June 9th, 2012, 08:39 AM
groundhog's Avatar
First Name: roger
My RZR: 2010 rzr
Member #9975
View groundhog's Photo Gallery(0)
Those fill/drain plugs are confuseing. Ain't no dumb questions. Should use polaris Demand drive plus for the front diff.
groundhog is offline
Transmission/T-Case Fluid Change.. HELP BillyBob427 General RZR Discussion 11 May 10th, 2012 10:00 AM
transmission oil change-- confused?? greenhorn Engine and Drivetrain 5 March 22nd, 2012 08:11 AM
How to change transmission fluid shanksyamaha Engine and Drivetrain 13 February 13th, 2012 02:18 AM
Transmission fluid change Ojmadness Engine and Drivetrain 3 November 21st, 2011 05:56 AM
transfer case cover (sub transmission) richcrook Engine and Drivetrain 2 February 21st, 2011 01:36 PM
