This is a discussion on Front Axle Removal within the Projects and How-To forums, part of the General RZR category; I'm removing my axles and cant get the front axles to come out of the diffrential.The manuel says to just jerk them out,This worked for ...
Front Axle Removal
I'm removing my axles and cant get the front axles to come out of the diffrential.The manuel says to just jerk them out,This worked for the rears no problem.But the fronts are A diffrent story I've tryed pulling them as hard as I could but they wont come out I also tried to use 2 screw drivers one on each side of the CV but the wont come out .Does anyone have A trick to getting them out?
| Sponsored Links | ||
Re: Front Axle Removal
Mine rears were pretty hard to get out. just push in and jerk back. finally got mine out. I had to replace a Clip on one of my rears the factory had jambed in into the housing
Had the same problem with mine and got a rachet strap and managed to get one end on the axle and the other on a tree and started racheting. Once the strap gets so tight that it starts moveing the RZR get a slender steel rod and a hammer and slightly peck around the part of the axle that goes into the gear box. Be careful not to damage anything and look out when that axle comes out it will be sailing through the air. The problem is that the axle is rusted inside the gear box and needs to be broke loose. These gear boxes are different from most other atv's utv's because the axle is sealed off seperate from the gear box. In other words you could pull both front axles and go ridding and never loose a drop of gear fluid out of the front. Now the rear is a different story!
push in first then yank
![]() 623.934.3070 Please understand we support many forums and cant keep up with Private messages or questions on the forum boards so If you have a question Please Call the Retail Shop 623-934-3070
I forgot to mention I used a couple of pairs of vise grips to attach the strap to the axle,"You have to be creative." Once these things get rusted in there it's very hard to get them out. Be sure to put some grease in there before reinstalling them so maybe next time will be easier
Spray penetrating oil into housing beside axles and run it around for a few minutes. This usually lubricates the axle spline and snap ring then you can pop axles out easy with 2 screwdrivers.
Going "slow" so you can get a good look ![]() RZR Tech +3 suspension Makin' Trax MT2 Shocks W/ Progressive Springs http://www.makintraxsuspension.com/ Moab UTV Rally - April 21-24th, 2010 |
#8
Make sure you get a good angle on them. I had a buddy use a cheater bar to bring the A-Arm up so that I could get a straight out pull.I couldnt budge the axle when it was on an angle. Hope this helps. Like another said, i put anti-seize on it before i put it back in b/c it did seem rusted in there.
'08 Gen. 3 RZR Green Full Big Gun Exhaust UNI Filter Waiting on Fuel MAP |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Frt. Axle removal | Darren Ellis | Forum Help, Questions and Info | 24 | June 8th, 2009 01:58 PM |
| Front swaybar removal Pros & Cons | MotoXXX | Suspension | 28 | June 6th, 2009 08:21 PM |
| axle removal how? | bigmike58 | General RZR Discussion | 6 | February 11th, 2009 12:20 AM |
| Front gearcase removal | Mr. Brownstone | Engine and Drivetrain | 11 | January 3rd, 2009 09:17 PM |
| Polaris RZR Axle Removal Tool | Crowdog | Suspension | 3 | September 26th, 2008 10:20 AM |
