DIY Load RZR in truck bed and don't worry about tailgate! - Polaris RZR Forum - RZR Forums.net
post #1 of 40 Old February 6th, 2012, 07:02 PM Thread Starter
Vanguardbh1's Avatar
Okay, so I wanted to see if I could load my RZR S in the truck bed so I can still tow a trailer but I have heard to many horror stories about the tail gate cables giving out. So this is my solution.. I'm still fine tuning it but it worked great for today and it really did take the load off the tail gate. I strapped it down to my 5th wheel hitch and made it so the front tires also hold it in the bed. (If that makes sense). If you have any questions feel free to ask.. It took me about an hour and cost me $40 in wood (I had some laying around too).
ID:	45210   Click image for larger version
Name:	Truck bed 1.jpg
ID:	45211   Click image for larger version
Name:	Truck bed 2.jpg
ID:	45212   Click image for larger version
Name:	Truck bed 3.jpg
2010 RZR-S
2003 GMC LB7
Vanguardbh1 is offline
post #2 of 40 Old February 7th, 2012, 07:24 AM
Russell's Avatar
Re: DIY Load RZR in truck bed and don't worry about tailgate!
Nice work, Do you think if you had the Polaris front bumper that it would hit your back glass?
When i had my silverado, i couldn't tow my flatbed trailer with the tailgate down because it would hit the tongue jack. I haven't tried it with my F250 yet or with my Toy Hauler hooked up.
2012 RZR-S LE
Russell is offline
post #3 of 40 Old February 7th, 2012, 08:20 AM
XR4Honda's Avatar
Nice work. I did a similar setup in my Dodge with a 6'5" bed. I used aluminum channel. I need to take some pics and post. I would watch those boards close. You are getting alot of flex where you are "floating" the rear wheels over the tailgate. Especially watch for when you hit a bump and the RZR weight starts moving up and down.
Also invest in a 12 inch hitch extender to tow with your tailgate down and give you a little more clearance.
XR4Honda is offline
post #4 of 40 Old February 7th, 2012, 08:24 AM
XR4Honda's Avatar
Yes the front bumper would hit the window. I carry my RZR in the bed of my Dodge all the time and I drive it in until the front tires touch the front of my bed. I have seen guys load them backwards with the front bumper.....And that method is probably better because u put the heavier end in the truck.
XR4Honda is offline
post #5 of 40 Old March 2nd, 2012, 08:00 AM
inutak's Avatar
Hey guys new Rzr owner with Dodge 6.5' bed. Plan to do most of my hauling in 5th wheel toy hauler, but now times will come up (like dealer to home or short runs from camping to trail heads) where Im pulling my hitch to carry the new toy in the truck bed
If I understand this correctly, you did this to spread the load of the Rzr across the bed? Your configuration is interesting...any particular reason you angled the 2x8s into the front of the bed?
Would love to see pics commented on about using aluminum channel.
Thanks for helping out "da new guy"
inutak is offline
post #6 of 40 Old March 2nd, 2012, 08:05 AM
rzrs:)'s Avatar
I do it all the time! I tow trailers all the time so when I don't have to I don't. But I do have a 8' bed, But I also have the DG Tailgate supports. Also in the winter months when we have snow it is nice not to get that sloppy salt/snow spray all over your machine.
2009 RZR-S,Crow 5pt harness,ITI Doors,EMP Full windshield,EMP Back window,Winch,EMP Windshield,SLP super silent Pipe
rzrs:) is offline
post #7 of 40 Old March 2nd, 2012, 10:25 AM
inutak's Avatar
I just ordered the DG tailgate supports based on what I've read on here about tailgate load weights, but always looking for new info / ideas. Are u happy with the DGs?
inutak is offline
post #8 of 40 Old March 2nd, 2012, 11:40 AM
rzrs:)'s Avatar
Yes thy work great, easy to use. And being I have a 8' bed the tailgate can be put up to about a 45 so I am going to make some supports that are shorter to hole the tailgate up.
rzrs:) is offline
post #9 of 40 Old March 3rd, 2012, 08:11 AM
BugBoyOne's Avatar
Regarding the load newer tailgates can handle, it's not just the support cables that can fail. There are lots of examples where the pressed steel tailgate structure fails (bends or spot welds fail). Do some research on your truck brand/year and get opinions on the actual tailgate strength. Replacing the cable supports may be a false sense of security.
When I have to load the Rzr in my Toyota Tundra (6.5' box), I lay down four 8' 4X4 posts, two at each side of the box, for the wheels to sit on. I fashioned a separate 4X4 across the front of these that's jammed under the front box tie down loops to hold the front of the posts down as I'm loading/unloading. The OP made use of his 5th wheel hitch mount and tie-downs to accomplish the same thing - holding the front of the boards down so they don't pivot and load the tailgate as you start to load the Rzr.
I load the Rzr backwards as the back end is heavier by a couple hundred pounds. I also use some smaller chunks of 4X4 as chocks to stop the wheels before the bush bar can contact the front of the box or the rear window of the truck.
Using the 4X4 posts, the aluminum ramps bear directly on the ends of the posts, not the tailgate, so there is essentially no load placed on the open tailgate. (sorry, no photos).
Really a 1100 lb Rzr, 5 wooden post and 4 humans puts the Tundra over its GVWR... I need a bigger truck with an 8' box!
BugBoyOne is offline
post #10 of 40 Old March 4th, 2012, 12:53 PM Thread Starter
Sorry haven't been on here for a while. I angled the 2x10's into an A so they could be directly under the back tires and give it better support. Also for an update I upgraded my tailgate cables to the old school stainless steel ones (just for piece of mind). It's worked great so far!
2010 RZR-S
2003 GMC LB7
post #11 of 40 Old March 4th, 2012, 04:08 PM
FlatBlack's Avatar
Deleted by FlatBlack
FlatBlack is offline
post #12 of 40 Old March 6th, 2012, 12:21 PM Thread Starter
Here are a few updates to my build.. I added this angle iron to stiffen it up and it works great! I also drove around with my video camera in back to see how much it flexes when going over bumps and it doesn't really move at all! I also changed out my tail gate cables for piece of mind to the MA ones.. I think they were like $50 or so..
On a side note for any of you trying this make sure you hook your ramps to your truck somehow.. My truck has a 6 in lift and 35's so its a pretty steep climb and i know if they were not hooked into my bed they would slide right out.
ID:	47522   Click image for larger version
ID:	47523   Click image for larger version
ID:	47524   Click image for larger version
ID:	47525   Click image for larger version
2010 RZR-S
2003 GMC LB7
post #13 of 40 Old March 6th, 2012, 12:35 PM
King of crash!
Send a message via Yahoo to johnnycat8
glad i just tow with toyhauler...
johnnycat8 is offline
post #14 of 40 Old March 6th, 2012, 01:14 PM
kyle2601's Avatar
I was going to do the exact same thing with channel Iron welded together with a pin that fit into my gooseneck hitch that is a flush mount. I am dealing with a dodge short bed with an aux fuel tank as well so I have no room to haul anything.
2011 rzr 900xp White LE
33"x15" terminators on 15" chrome MSA diesels,Gorrilla axles,Custom reciever hitch,Viper 12,000lb winch,Aluminum polaris roof with custom built stereo enclosure with kicker wake tower speakers. Trail Tech GPS, rzr s bars, 4'fiber optic whips,
2012 rz 900xp red
30"x14" Moto Monsters on ss212 itps
kyle2601 is offline
post #15 of 40 Old March 6th, 2012, 07:51 PM
Coolbaldguy's Avatar
I just got a 900 xp. It is too wide to put in my Dodge 2500 bed. I have been thinking about running it all the way up to the top of the bed sides. If I built an aluminum "track" that fit into the bed pockets and rested on the bed sides and maybe some ramps that slide in and store in the "tracks". What do you all think? Sorry the only pics of this are in my head lol
Coolbaldguy is offline
Tags
bed, diy, rzr, truck
Do I need to worry about the CARB Cops in California? Nightmare General RZR Discussion 35 January 5th, 2012 09:34 PM
Idea's,Motorhome towing truck with RZR800 in the bed and Dirt bike on the truck hitch flbluerunner General RZR Discussion 23 September 2nd, 2011 01:22 PM
Pre load? hipcash Suspension 4 October 26th, 2009 09:42 PM
Load'em up.... Wrongway General RZR Discussion 1 April 8th, 2009 01:17 AM
