Axles-removing-installing TIPS
Old December 27th, 2007, 11:02 PM
BigAir's Avatar
BigAir BigAir is offline
I am trying to replace my OEM axles with gorrilla. Stock a-arms. I have the service manual for the rzr and it says just to just pull on the axle to get it out. Well a few people have tried and its not moving. Even tried to pry out abit but stopped.
Any tips, tools, that would help the help removing the orignal axles?
The Gorrilla axles I got are a few inches longer than the original ones. I thought the place I got them from maybe sent me long travel, but I called G Axles and they said that was normal and would fit.
We'll see.
Re: Axles-removing-installing TIPS
Old December 27th, 2007, 11:10 PM
BigAir's Avatar
The OEM is broke so its hard to tell the differance in length...plus its still so that doesnt help but here are some pics.
Old December 27th, 2007, 11:47 PM
Code Blue's Avatar
Code Blue Code Blue is offline
My RZR: two red ones
Show a close up picture of the proximal end of the Gorilla shaft..
Old December 28th, 2007, 05:13 AM
odtodd1az odtodd1az is offline
First Name: Todd
you could try a bearing splitter and a slide hammer behind the plunge joint. when your all back together, you should be able to grab the axle shaft and move it in and out of the plunge joint slightly. That will tell you if the axle is the correct length. ( no binding the cv's)
Old December 28th, 2007, 07:48 AM
xtreme's Avatar
xtreme xtreme is offline
First Name: Shane
My RZR: 08 RZR
I just changed my axles to the long travel kit from Lone Star. I agree that the axles look longer.
When I removed my axles, I just gave the shaft a tug and they came right out. You are probably going to have to apply a little pressure to the inside edge of the axle to get them out. I wouldnt pry against the case though. Get a longer pry bar and possibly a 2X4 to pry against. It only has a circlip on the inner axle keeping it in so its probably a little rusted in the splines that's keeping it from coming out.
Hope this helps.
Shane
Old December 28th, 2007, 08:18 AM
RZRider's Avatar
RZRider RZRider is offline
First Name: Al
My RZR: 08 Red
It helps greatly if you have one person hold the axle straight or level while another gives it a tug or as stated above uses the "pry" technique.
If you decide to "pry" on the axle, use 2 pry bars across from one another so that you get an even pull on the axle.
My RZR Project
Keep It Wet and Dirty!
Old December 28th, 2007, 05:15 PM
BigAir's Avatar
Thanks, hopefully I'll get a few friends over this weekend to get her back together..and finally cleaned up
I was ripping around a corner about 20-30 mph I think and hit a tree with the front left tire so hard that it lifted the rzr off the ground and hit the tree on the other side. The tie rod on the right snaped too So hoping that inside the case is bent or something.
I adjusted the suspension 2 clicks in the back and 1 in the front, plus was the first ride with the LTE and fuel box. So the ride was totally different. When I was getting comfortable I went outside my limits trying to get a better time...well thats when shit happens.
Old December 28th, 2007, 05:33 PM
Dusty's Avatar
Dusty Dusty is offline
Totally understandable. I'm glad your not one to put the blame on Polaris like I hear too much. Like was said, it is just a snap ring holding it in. They can be a pain, but you just need to be abit aggressive sometimes.
How do you like the sound of your LTE? I haven't heard anyone say they dis-liked it.
Brian
Old December 28th, 2007, 05:39 PM
BigAir's Avatar
Loud as hell..love it. Could be too loud for some. Set off a few car alarms when I drove past. But they were probably set high.
  #10 (permalink)
Old December 28th, 2007, 09:02 PM
i have the lte also and love the sound it is a tad loud but sounds like a harley.... nice tone and rumble at idle if someone can help i have a video of mine in my driveway just dont know how to post the video short of putting it on my space or your tube with a link
2006 silverado 2500 hd
2006 additude toy hauler
2008 polaris rzr
2006 suzuki ltr450
2005 kawisaki kfx700
2003 suzuki z400
2003 honda ex250
  #11 (permalink)
Old December 28th, 2007, 11:32 PM
Code Blue's Avatar
you tube is the best way go ahead then add the link.. But maybe it would be cool to start a new thread with it, like "video of LTE sound"..
  #12 (permalink)
Old December 29th, 2007, 04:24 PM
well ill give it a shot and see if this works....john
YouTube - polaris rzr walk around and sound lte ex
  #13 (permalink)
Old January 16th, 2008, 12:13 AM
BigAir's Avatar
Well they were just rusted pretty good, and had no grease left. We ended up pulling so hard the boot ripped off! Then had to use channel locks to get the end off.
FINALLY used liquid wrench, let it sit then came RIGHT out.
Guess just needed some lube
Then got to the rear and found out I bent the rear a-arm bolt and a-arm....so I should get them in a few days. I hope I get to ride sometime this year
Stock parts suck for jumping...
  #14 (permalink)
Old January 16th, 2008, 10:49 AM
quadnkev's Avatar
quadnkev quadnkev is offline
First Name: Kev
My RZR: Red for now!
The two pry bar method is correct, and use some anti-seize when putting it back together.
