Functional Radiator Protection (grill) for Cheap
This is a discussion on Functional Radiator Protection (grill) for Cheap within the Projects and How-To forums, part of the General RZR category; I have a 2012 Rzr 800 and was looking at replacing the flimsy plastic radiator grill with something sturdier. Where we ride in the foothills ...
Old December 23rd, 2011, 02:55 PM
BugBoyOne's Avatar
First Name: Rob
My RZR: 2012 Rzr 800 50"
Member #30151
View BugBoyOne's Photo Gallery(0)
I have a 2012 Rzr 800 and was looking at replacing the flimsy plastic radiator grill with something sturdier. Where we ride in the foothills of the Alberta Rockies we often have to improvise trail sections over saplings and other bushes (it's amazing how much stuff you can mow over, just don't try backing up). Usually all the branches get folded down without issue but I have seen someone's weekend wrecked by an errant branch to the radiator. An expensive branch too.
I know there are stainless and aluminum replacement grills available but they still just clip in on the 2012s and would seem to be easily pushed back into the rad. I think you could bolt one in solid from an older model but I still want full access to the radiator for cleaning (silty mud and muskeg here). I had the deluxe Polaris brush guard so I thought I would make a HD grill there. Here's the result.
Some stainless steel expanded metal, black plastic door-edge trim from Canadian Tire and some 1-1/4" cushion clamps. I used two 1" L-brackets for the bottom edge. Doesn't look too bad and it's very rigid. I would have painted it black if it was just carbon steel. Now all I need is the radiator mount stiffener in case I nail a tree.
Last edited by BugBoyOne; May 11th, 2012 at 08:37 PM. Reason: moved pictures to PhotoBucket
Old December 23rd, 2011, 03:01 PM
FunRide's Avatar
First Name: Jim
My RZR: '11 CP/MCX S-LE
Member #17399
Re: Functional Radiator Protection (grill) for Cheap
Nice work Rob. You should post this in the "budget mods" thread! Lot of action there...
Old December 23rd, 2011, 03:07 PM
Kandgo's Avatar
I am still 16 in my head!
Feedback Score: 29 reviews
First Name: Rick
My RZR: 09s 08stnd several atv's and more
Member #22394
I like it! Great job! And you had better get that Radiator Support done for sure. I like the Thunderhawk one.
Old February 16th, 2013, 09:41 AM
Tlbotts's Avatar
The Rookie
First Name: Tommy
My RZR: 2013 RZR 570
Member #50581
View Tlbotts's Photo Gallery(0)
I CAN'T FIND THE EXPANDED METAL ANYWHERE!!!!!!! Where did you buy it? I have checked 3 hardware stores.
2013 RZR 570
3500 Warn Winch
Click and ride Half windshield
60" Glacier II Plow
Old February 16th, 2013, 10:22 AM
BugBoyOne's Avatar
First Name: Rob
Member #30151
You're more likely to find it at metal fabricators or welding shops... they might have smaller chunks. I got mine from a similar place.
Old February 16th, 2013, 10:27 AM
BarRZR's Avatar
My RZR: 2012 RZR 800-S L/E
Member #32278
Looks good, and well-done,BUGBOYONE, and highly functional; I like it! Just fwiw, an alternative to the expanded-metal would be perforated-metal, and the advantage/s would be smaller openings in the screen that would only allow much smaller twigs and stuff to penetrate, and would be more rigid, due to having more structural material remaining in the screen. Just my two-bits.........
Cheers
Old February 16th, 2013, 10:34 AM
BarRZR's Avatar
Member #32278
Edit/delete double-post.
  #8
Old February 16th, 2013, 11:27 AM
Tlbotts's Avatar
The Rookie
First Name: Tommy
Member #50581
I bought some metal screen that is used as leaf guard I am going to try and make work. I just want to say that this forum and its members have helped me tremendously. Thank you
2013 RZR 570
3500 Warn Winch
60" Glacier II Plow
  #9
Old February 16th, 2013, 12:14 PM
BarRZR's Avatar
Member #32278
Good, then you owe us all a beer; where do you want to meet-up?........LOL.
Cheers
  #10
Old February 16th, 2013, 02:44 PM
Tlbotts's Avatar
The Rookie
First Name: Tommy
Member #50581
I will be in Reno in the next few months
2013 RZR 570
3500 Warn Winch
60" Glacier II Plow
  #11
Old February 16th, 2013, 02:51 PM
MattMcF's Avatar
First Name: Matt
My RZR: 2013 800 LE
Member #45961
View MattMcF's Photo Gallery(0)
Looks good. May end up using your idea. Very nice set up
Xtreme Honda & Polaris
740-598-9100
http://www.rzrforums.net/image.php?type=sigpic&userid=45961&dateline=136105  5549
  #12
Old February 16th, 2013, 07:53 PM
Tlbotts's Avatar
The Rookie
First Name: Tommy
Member #50581
I actually bought some perforated sheet metal today. I have the grill cut and painted and will have install pics tomorrow. The metal is pretty thick compared to the gutter screens.
2013 RZR 570
3500 Warn Winch
60" Glacier II Plow
  #13
Old February 17th, 2013, 10:32 AM
Tlbotts's Avatar
The Rookie
First Name: Tommy
Member #50581
i completed the radiator guard/protector today. The material is 16ga steel perforated sheet cut with a dremel cutoff wheel. The metal was painted with 3 coats black epoxy high temp paint. The bands are stainless steel zip ties. The 1 1/4 clamps mentioned above had to be special ordered. The zip ties have a tensile strength of 100 lbs. I used 13 of them so i think that will be sufficient for now. I also used the door edge guard from the auto parts store and the L brackets below. I have enough steel to make 4 to 5 more LOL.
2013 RZR 570
3500 Warn Winch
60" Glacier II Plow
  #14
Old February 19th, 2013, 07:05 PM
BugBoyOne's Avatar
First Name: Rob
Member #30151
Hey, looks good Tommy. Bring on the sticks.
  #15
Old February 19th, 2013, 07:14 PM
Tlbotts's Avatar
The Rookie
First Name: Tommy
Member #50581
I threw you some credit on the budget mod thread. You saved me some money and heartache for sure.
2013 RZR 570
3500 Warn Winch
60" Glacier II Plow
2012 polaris razor 800 grill
2012 polaris rzr 800 grill
2012 polaris rzr 800 le grille
2012 polaris rzr 800 radiator guard
2012 rzr 800 grill
570 rzr grill installation
grills for 800 rzr
is there a raditor guard on 2006 polaris ranger forums
polaris rzr radiator grill
rzr 800 grill
rzr 800 grille
rzr 800s grill
rzr radiator grill
rzr radiator guard
rzr radiator protection
need better protection for radiator JDS General RZR Discussion 1 July 25th, 2011 06:36 PM
Full windshield with (2) functional vents ROOSTER_AP Polaris RZR Parts For Sale 7 May 16th, 2011 07:08 AM
Opti-air 600 filter, cheap, cheap, cheap!!! Vinman Engine and Drivetrain 1 October 19th, 2010 09:16 AM
Cheap new hood with vents and grill LvDirtJunky General RZR Discussion 2 October 16th, 2008 10:38 PM
Cheap solution to open flow to radiator pitcher Projects and How-To 6 May 14th, 2008 07:28 PM
