Step by Step - How to Replace the Water/Oil Pump Seal - Polaris RZR Forum - RZR Forums.net
post #1 of 6 Old January 27th, 2011, 07:37 PM Thread Starter
Feedback Score: 4 reviews
BlackBart's Avatar
This Subject should be useful for anyone needing to perform this task OR if you don't know any details regarding the Pump, allow you to view it internally.
I talked a GOOD Friend of Mine into Doing the Work as I took the Pictures.
Believe it or not, HE's Still a Good Friend.
Rebuild/Replace Water/Oil Pump Seals - Work Performed by Steven (SuperSPuppy) MASTER Backyard Mechanic
If you must change the Oil Pump Seal, the Engine must be pulled and the Engine Case removed. If only changing the Water Pump Seal, this may be done with the Engine left in.
Picture of Engine Case Oil Seal
Use a Brass Punch to Gently Knock Out the Oil Seal
25 mm Socket
Water Pump Seal
Gently Remove the Water Pump
Water Pump Seal Out of Copper Gasket
Water Pump Seal w/Copper Gasket
Knock out the Oil Seal Behind the Water Pump
Oil Seal in Hole Behind the Water Pump
Needing a bit of a Break and some Humor
EVER GET TIRED OF JUST STICKING Around
New Oil Seal
Use a Socket to Knock Out the Copper Water Pump Seal
Gently using the 25 mm Socket to Remove the Seal
Copper Water Pump Seal Removed
SKIP
Gently/Carefully Trim the Plastic Cover Off the New Water Pump Seal
Clean the Engine Case Cover
Cleaned Seal Inside Weep Hole
Picture of What Weep Hole Looks Like from the Outside
Gently open the New Water Pump Seal Leaving the Top Part of the Seal STILL in the Plastic Cover
This is what if Looks Like without the Cover
Picture of Water Pump Seal JUST sitting in the Engine Case – NOT INSTALLED
REDNECK Water Pump Tool---select a Socket that just fits around the inside rubber pump, so that it is sitting against the Copper Lip on the Seal
Socket Size ??? 1 ¼”
Place the Engine Case on a Flat Solid Surface and Tap the Seal Gently until it is Bottomed Out
Bottom View of Engine Case with Water Pump Seal Installed
Mag Side of Pump Seal
Picture Showing Mag Side
Using a SMALL amount of Gasket Seal to aid in the Installation, HOWEVER NOT RECOMMENDED supposed to be installed DRY
Use a Socket as big as the lip on the Seal MAYBE 1 ¼”
Hand Press the Seal UNTIL it Bottoms Out
Example of Finished Oil Pump Seal Viewed from the Mag Side
NOTE : You can SEE the Weep Hole at the Back of the Water Pump
Oil Seal at Water Pump
Turn the Socket Upside down
Gently push in until it is Flush with the Engine Case
WARNING and SIDE NOTE : Seal is Flush with Outside Engine Case BUT not pressed all the way in against the Water Pump Seal OTHERWISE this would BLOCK the Weep Hole
Place Top Half of Water Pump Seal on Water Pump
Remove Cover
The Link below is to a previous post concerning the Weep Hole
http://www.rzrforums.net/engine-driv...-mud-read.html
Last edited by BlackBart; January 28th, 2011 at 01:08 PM. Reason: added linkback to previous post
BlackBart is offline
post #2 of 6 Old April 16th, 2011, 07:29 AM Thread Starter
BlackBart's Avatar
Re: Step by Step - How to Replace the Water/Oil Pump Seal
Got a couple of PM's regarding this subject, so HERE it is again
post #3 of 6 Old October 18th, 2011, 11:21 AM
popparuch's Avatar
Great write up
2013 rzr s racer tech 2" lift, ricochet all aluminum skids,a arm guards pro armor doors and harnesses racer tech springs and rear bumper roll cage extension 20" led. 2 way radio
popparuch is offline
post #4 of 6 Old January 24th, 2012, 11:55 AM
Myleslong's Avatar
Glad I found this, I'm going to be doing this very soon! Thanks for taking the time to post this! It should help me out quite a bit, Thanks again!
2010 Robby Gordon RZR4. MC MOTO tires, Buckshot wheels, 1/2" poly skids and A-arm guard, Front bumper with some off road HID lights, Half and full wind shield, 4 4pt harnesses, Polaris winch, Wicked whips whip, Polaris lock and ride box, radio and speakers, gas can holder,RuKind headlight covers, and a mounted Gerber machete.
Myleslong is offline
post #5 of 6 Old April 5th, 2014, 10:00 AM
birdmanf250's Avatar
Awesome!
SWAMP DONKEY PATROL
FTM 6" Arched Lift
Gorilla Axles
Speed Werx/Hot Seat Performance Custom Clutching
UTV Inc. Intake/Donaldson Filtration
Burke Moto Pro HID's
Custom Tunes w/J Strong Top
birdmanf250 is offline
post #6 of 6 Old April 10th, 2014, 04:50 PM
countrystunter's Avatar
Is the oil seal included with the water pump seal.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
countrystunter is offline
Tags
blackbart, rhinoeater, teamhog
Water Pump Seal? Demoman Engine and Drivetrain 17 September 1st, 2011 11:27 PM
Water Pump Seal Leaking cdarling12 RZR 4 Specific Discussion 3 May 20th, 2010 08:43 AM
Water Pump Seal Removal Tool HivoltageRZR Engine and Drivetrain 4 March 17th, 2010 07:50 PM
New RZR S water pump seal leaking! Pimp Dog RZR-S Specific Discussion 6 November 25th, 2008 11:24 AM
