Vent Lines......?
Old August 5th, 2008, 07:29 AM
rzr2008's Avatar
rzr2008 rzr2008 is offline
First Name: Josh
My RZR: 2008
Vent Lines......?
I recently snorkled my rzr and i can not find 2 of the 8 vent lines on the bike. I believe there are two on the throttle body? Correct? I am maybe thinking that one of the tubes fell off because there is a nipple where it would look like one was previously. The other one has a check valve on it and is it ok to run the vent line up and not let it hang? Any advise?
3" Extreme lift, 1 1/2" wheel adapters, 27" outlaws on douglas wheels "spyders", 27" XTR on SS112 14" rims, 4500 lb viper max winch, front & rear deluxe brush guard, sport roof, 600W amp pushing four 8" full range speakers. Uni filter, big gun exhaust w/TFI controller. More too come....
Re: Vent Lines......?
Old August 5th, 2008, 09:58 AM
blcoonrod's Avatar
blcoonrod blcoonrod is offline
Ok I will start at the front. You need to run the front diff vent, som run the radiater overflow vent(I didnt and have had no problems), gas tank vent, throttle body...you don't need to run the one that has the check valve, just put a hose on one of the 2 nipples on the lower of each side and cap the the other. Then there is a tranny vent, rear diff vent, and there is one more I can't remeber what it goes to, but it is already ran up with clear line to about the top of the bed. Also, some people put silicone in the weap hole of the water pump. I would think that is only neccesary when riding in a lot of thick mud.
08 Red Rzr: ITP 14" 212's, 26" Bighorns, 1.5" wheel adapters, Xtreme 3" lift, Viper Max 4500lb winch with amsteel rope, Custom snorkels, Custom mounted Ammo Cans, Polaris: Pre runner bumpers, cargo net, cargo rack, over head bag, plastic top, rock sliders, and billet steering wheel, Fender flares, front and rear lights, Custom amp/switch box, MTX wakeboard speakers.
Old August 7th, 2008, 07:53 AM
rzr2008's Avatar
First Name: Josh
My RZR: 2008
Ok, Ive ran 5 vent lines up the snorkel. The intake tube i left in the air filter box, seems that its acts as a blow off valve tube or something. The excess nipples i found under the throttle body seem to go nowhere. Does anybody know if or where there are any hidden vent lines?
Old August 7th, 2008, 10:57 AM
blcoonrod's Avatar
That should be all of them. I have 6, but I ran one of the TB nipples and caped the other.
Old August 8th, 2008, 11:21 AM
THNKTWCE's Avatar
THNKTWCE THNKTWCE is offline
I think the nipples that people are referring to is just a part of the cast. I took a picture to show that it is a straight shot to the other side, and there is no where for water to enter the TB. Should be just 5 lines. Front diff, gas tank, tranny,crank,rear diff. Here is the picture.
Just Muddin!
Old August 8th, 2008, 11:32 AM
rzr2008's Avatar
First Name: Josh
My RZR: 2008
Thanks for all the info... I did notice that the nipples went all the way through and didn go anywhere, just wanted to make sure i got all lines before i dipped it in the water.
Old October 17th, 2008, 07:11 PM
wgladde's Avatar
wgladde wgladde is offline
My RZR: Green 08
I have snorkeled my RZR and when I go in water it starts bogging down. It definitly feels like its getting water into the engine I just can't figure out where. I've checked the seals on the engine breather box and snorkel all seem to be fine.
Any thoughts or suggestions would be great
Old October 17th, 2008, 07:18 PM
striperman striperman is offline
First Name: Ed
My RZR: 09 RZR S and 08 Gen 2 Greenie
Get a Jet Ski.LOL
Ed 08 RZR, and my 04Rhino racing team.
