Home-made snorkels--incl. parts list
This is a discussion on Home-made snorkels--incl. parts list within the Projects and How-To forums, part of the General RZR category; Quote: Originally Posted by firerzr Where did you buy the Rubber Couplers, I live in Texas and ABS is next to impossible to find here. ...
  #31
Old September 11th, 2008, 03:24 PM
adrenalinfanatic's Avatar
First Name: Travis
Member #2210
View adrenalinfanatic's Photo Gallery(0)
Re: Home-made snorkels--incl. parts list
Quote: Originally Posted by firerzr View Post
Where did you buy the Rubber Couplers, I live in Texas and ABS is next to impossible to find here. I am going to order the fittings from Genova products online. When I spoke to them they said they did not have the rubber couplers? What is the Actual use for the Couplers maybee that will help me find them locally???????? Thanks
Go to Lowes or Home Depot. They will be in the plumbing section close to $4 a piece. I used PVC and painted it with high heat paint. Looks good. I was like you, I could not find ABS anywhere.
Also,since I have the DFR filter I did not worry about putting filters on each of my intakes. However I do have outerwear in between the tubbing on the last bend to keep debris out. Cant see it though.
Travis
  #32
Old September 11th, 2008, 05:09 PM
guy48065's Avatar
Feedback Score: 4 reviews
Member #309
OK now that I'm caught I had to take a new pic & fix the link so it shows correctly.
If anyones Outerwears sock blew off because of this, I'm really sorry
(again
Why buy the cow?
  #33
Old September 12th, 2008, 09:24 AM
wgladde's Avatar
My RZR: Green 08
Member #1929
View wgladde's Photo Gallery(0)
A 22 degree street would turn a 90 in to a 112 degree elbow
Quote: Originally Posted by guy48065 View Post
I wish there was such a thing as a 110 degree elbow...
I agree that I should turn down the end but an additional 90 will interfere with my tote. All I really need is a little "eyebow" or overhang. Plastic pipe is so easy to work with I'll probably bandsaw the thick hub end off another elbow--at an angle--and glue it on the 90 to make it a 110
I'm not worried about getting a little water in the CVT case--it'll dry up quickly once that big fan gets going. But I'll go to a little extra trouble to prevent it if I can.
  #34
Old September 12th, 2008, 11:16 AM
guy48065's Avatar
Member #309
If you look close at the picture you can see what I did. I took a street fitting and bandsawed it very short and at a slight angle to give me a little "hood" on the exhaust. It didn't help recently whenI trailered it through a rain storm. So much water got in the CVT that I couldn't back the Rzr off the trailer until I loosened the cover & drained most the water out. Now I stuff a tennis ball in the end of the elbow if it looks like rain.
Why buy the cow?
  #35
Old September 21st, 2008, 03:59 PM
roadsidedoc's Avatar
Member #2206
View roadsidedoc's Photo Gallery(0)
Thanks for the info, just finished mine, I turned the outlets out under the bottom roll bar so that I could still use the shoulder storage bag! and where did yo get the outerwears?
  #36
Old September 22nd, 2008, 04:16 PM
weekend warrior's Avatar
First Name: scott
My RZR: red 08 rzr
Member #2066
View weekend warrior's Photo Gallery(0)
instead of paint use spray on bed liner i did my rzr with white pvc and put on black paintable bed liner still looks new i have used my machine about 15 times no chipping or pealing about $5.00 a can and you can paint any color made by duplicolor
  #37
Old September 22nd, 2008, 08:26 PM
guy48065's Avatar
Member #309
The Outerwears part number for a size that fits over the end of a 2" PVC elbow is 20-2265. It's got an elastic tie that fits over 2.75" and is 2.5" tall.
Got the socks direct from Outerwears. I should clarify that this sock doesn't stretch tight over the end of the pipe. The sock might restrict flow a little if it were that small so I got taller socks & put a round piece of very open celled aquarium foam in the end of the pipes. Just rinse the sock & foam off in water when it gets dirty. A flick with the finger is usually all that's needed to knock the loose dust off the surface.
Why buy the cow?
  #38
Old October 3rd, 2008, 02:39 PM
budlight_87's Avatar
First Name: Bud
My RZR: 2009 RZR S
Member #4541
View budlight_87's Photo Gallery(0)
did you still use the stock air box?
  #39
Old October 3rd, 2008, 06:20 PM
guy48065's Avatar
Member #309
So far--but its days are numbered!
Why buy the cow?
  #40
Old October 3rd, 2008, 11:00 PM
First Name: Bud
My RZR: 2009 RZR S
Member #4541
what would you do? remove stock air box and go straight into throttle body with an air filter on top of snorkel or leave the air box and leave top of snorkel open? I have a 2009 RZR S and a new guy to the RZR so any help would be awesome. another question since i'm going to have everything apart would it be great idea to install drain plug into cvt housing?
  #41
Old October 4th, 2008, 08:58 PM
almost's Avatar
My RZR: 09 RZR
Member #4133
View almost's Photo Gallery(0)
I would just like to say thanks for such a great post!I used this post as my guide to snorkeling my rzr this weekend! Everything went great! I made a few small changes to the steps on snorkeling the lower belt and the 90's at the top of snork's, but all in all it went great and looks very professional! Could'nt have done it so easy or such a good job without this post! THANKS!!
09 RZR - 26" horns on bruiser's,aluminum pre-runner bumpers rock slider's! performance mods coming soon!!
  #42
Old October 6th, 2008, 06:50 AM
Bigdog800EFI's Avatar
Member #667
View Bigdog800EFI's Photo Gallery(0)
Same here, Finished one RZR next weekend We will get the other one. All peices are cut, just need to fit them and glue it.
  #43
Old October 6th, 2008, 07:47 AM
guy48065's Avatar
Member #309
I'm glad you guys are finding this helpful.
I'm just practicing to add "Technical Writer" to my resume
Why buy the cow?
  #44
Old October 6th, 2008, 06:18 PM
GearHead's Avatar
Member #2516
View GearHead's Photo Gallery(0)
Dumb Question, but why are there 3 tubes?
  #45
Old October 6th, 2008, 06:22 PM
guy48065's Avatar
Member #309
Cuz there's 3 big ducts under the bed:
Engine air intake, CVT fan intake & exhaust. Both intakes are in the upper air box & compete for the same restricted air supply. The cvt exhaust is under the bed & blows towards the back.
Why buy the cow?
Bookmarks
Home-made Lock N Ride Anchors guy48065 Projects and How-To 47 October 23rd, 2009 05:32 PM
my home made top 09 LE NUCLEAR SUNSET rjrzr Members Rides and RZR Of The Month Contest! 3 April 5th, 2009 07:26 PM
New home made billet grill cwspfx RZR-S Specific Discussion 9 December 1st, 2008 10:19 PM
Home made snorkel and the location of them FORKLIFMAN Engine and Drivetrain 1 October 3rd, 2008 05:47 PM
home made skid plate idea mdevans General RZR Discussion 29 January 24th, 2008 07:59 PM
