its almost done ! |
June 21st, 2008, 02:49 PM
razor abuser
First Name: todd
My RZR: 3rd gen red
its almost done !
well heres a couple pics will be done tomarrow some have asked about air intake solutions so heres mine the kms cant be seen but its instaled and the ehs racing airbox plus some shots of the cage and doors i just finished and got back from powdercoat and the diamond plate roof we got formed up thru the week
itp wheels, maxxis bighorns, custom cage, custom diamond plate roof, suicide doors, front and rear bumpers, winch, lonestar weld in gusset kit, utv crap frame tubes, full skid plate,clutch spacer removed, kms intake, ehs racing airbox, fmf exhaust, dobeck tfi box, bored throttle body, 4 point harnesses
Re: its almost done ! |
June 21st, 2008, 04:20 PM
It looks like the belt exaust is plumbed into the intake. Wont that feed your motor hot belt air? You want cold air for intake, not hot.
June 21st, 2008, 04:31 PM
razor abuser
First Name: todd
My RZR: 3rd gen red
there is a divider in the box look closely at the pic of the box you can see an opening on the side thats were the cvt exhaust exits and theres a 7x7 hole cut in the front of the bed with an outerwear cover on it that lets fresh air straight in the intake
June 21st, 2008, 04:34 PM
razor abuser
First Name: todd
My RZR: 3rd gen red
also on the pic from the back you can see a weld line on the right side thats where the diveder is welded in ill post some pics with the bed on too so you can see the finished product
June 21st, 2008, 05:10 PM
First Name: DAVE
My RZR: 2008 RZR
You will not be disappointed with the EHS system, I also put pre filters on the inlets inside the box. Take a old pre filter and cut it in half top to botom and clamp them on.)After 2 hours i pulled my air box cover and it was clean 0 dust.
June 21st, 2008, 05:39 PM
Talking bout' Yankee Rose
First Name: Rick James Bitch!
My RZR: Green 3rd Gen
Looks great man.
Have a Q though:
Do you plan on cross bracing your cage? Stability both laterally and horizontally on your cage doesn't look so good. Taking a roll at any decent speed will fold that cage very easily.
Not trying to be rude, just trying to save you possible injury.
June 21st, 2008, 07:14 PM
razor abuser
First Name: todd
My RZR: 3rd gen red
Originally Posted by RickyRazr
Looks great man.
Have a Q though:
yes pics arent close up but everywhere a tube intersects its gusseted with 3/16 plate and the roof is actually designed to be structural its made of 1/4 treadplate and grade 8 bolted to all 8 gussets on the top of the cage
June 22nd, 2008, 07:16 PM
razor abuser
First Name: todd
My RZR: 3rd gen red
heres a pic of the finished air intake
July 4th, 2008, 09:35 AM
Crash Test Dummy
My RZR: 2008
Damn man, that thing looks awsome! You did a heck of a job on it!
2008 RZR-Glacier II plow, Venom 4000x Winch, Amsteel Cable, Rear Brush Bumper, Rear Accessory Rack, 3" Xtreme Lift, 2" Datin Wheel Spacers, HD Springs, EPI Clutch Kit, KIMMER Custom Snorkle, K&N Apollo Airbox, 30" Gorilla Silverbacks On ITP SS106's, Ram Mount With Lowrance H2O GPS-owner of www.s197forum.com
July 6th, 2008, 06:29 AM
razor abuser
First Name: todd
My RZR: 3rd gen red
thanks kimmer its done now ill have to get some finished pics up now the cage is 3" lower than stock in rear and almost 1" lower in front and coupled with the aluminum roof it rocks on the trails i took it out for the first time yesterday it makes woods riding so much better down trees and low branches and going thru culverts gave me promblem before now with the lower ridged cage and roof i can force my way under them it great pics coming soon ....... kimmer you get that trailer figured out that you pm'd me about ?
July 6th, 2008, 06:35 AM
razor abuser
First Name: todd
My RZR: 3rd gen red
oh yea and i know  theyre comming ok
July 6th, 2008, 06:56 AM
razor abuser
First Name: todd
My RZR: 3rd gen red
heres a couple got the date screwed up on the camera but ohwell pics are there
July 6th, 2008, 05:00 PM
Crash Test Dummy
My RZR: 2008
Like I said, pretty awsome man! As for the trailer, I have a couple steel plates bolted to the frame extending the trailer about a foot for a temp fix. I have to check some local shops still about extending it or doing a side load up front. Only bad thing about the side load is that the rzr is 110" long, so it will be sticking way out on each side.
