Hard Top Install Problem
Old June 20th, 2008, 10:25 PM
z_rzr's Avatar
z_rzr z_rzr is offline
First Name: Ron
My RZR: 2008 RZR 800, the fast Red one
So I pull the new Polaris Hard Top out of the package and try to install it before heading out for the 1st ride. How tuff can it be? A simple plastic top w/four clamps. Came w/four rubber covered clamps which wrap around the roll cage tubes and then tabs are supposed to stick thru slots in the top and secure w/screws. Well the slots line up parallel to the roll cage tubes but are too far from the tubes for the tabs to stick thru. What the heck? I can drill new slots in the right spots but has anyone else run into this?
Ron ...
2007 Dodge Ram 1500 Quad Cab
2007 Suzuki Z400
2007 Arctic Cat DVX250
2008 Polaris RZR (Red)
Re: Hard Top Install Problem
Old June 21st, 2008, 12:12 AM
RZRider's Avatar
RZRider RZRider is offline
First Name: Al
My RZR: 08 Red
It all lines up, shift the top around a little bit and make sure you have the clamps facing the correct direction.
Left rear.
Right Rear
My RZR Project
Keep It Wet and Dirty!
Old June 21st, 2008, 06:35 AM
rexdibble's Avatar
rexdibble rexdibble is offline
Yeah you need 3 hands to do this easily. It's hard to explain on here but do just as RZRrider says. Get the clamp positioned close to where you want it and take your thumb and roll the top of the clamp towards the bolt. This is where your third hand comes in handy because you have to hold it there and start the nut. Once you get one done it will make perfect sense and the rest will be easier. Leave all of them loose to position the roof where you want it. Keep in mind since the clamps are rubber lined it won't move much so get it close from the start.
Old June 21st, 2008, 08:45 PM
z_rzr's Avatar
First Name: Ron
Thanks guys! I think I got it. Will try it tomorrow ...
Ron ...
