heater install
Old April 12th, 2008, 01:49 AM
jerrzr's Avatar
jerrzr jerrzr is offline
heater install
just trying to see if I can get some pics out to you all. This is a heater core that I installed for about $150bucks. That creek you see me stuck in, it was snowing and 20 degrees outside and I stayed warm and toasty inside the rzr. let me know if the pics go across.
J & T
Re: heater install
Old April 12th, 2008, 02:02 AM
jerrzr's Avatar
Re: heater install
more pics?
Re: heater install
Old April 13th, 2008, 08:05 AM
rexdibble's Avatar
rexdibble rexdibble is offline
Re: heater install
More pics would be good. Is that one of those Jeep heaters from JC Whitney? I wouldn't mind a heater but I refuse to pay Polaris 30 million dollars for one.
Re: heater install
Old May 6th, 2008, 09:20 PM
outdoortoys outdoortoys is offline
My RZR: 2008 RED GEN2
Re: heater install
More info on the heater?
Re: heater install
Old May 6th, 2008, 10:44 PM
jerrzr's Avatar
Re: heater install
[/IMG]
Well its called a flex-a-lite mojave heater. I ordered it from summit racing. I installed it by making a small frame from some angle bolted together and spot welded. The heater hoses connect just outside the firewall in parrallel with the cooling system. I sweated some copper together to make my T's 1" to 5/8" . I also installed a shut off valve to it to keep any residual heat out when its warm out side. now that its warm out, i use the blower alot to help keep air circulating it works great both when its cold and hot outside and its not in the way at all. Everything total cost about $180. The bottom of the heater is about 30 inches from the ground, it concerns me getting the blower motor wet, just gotta keep her 30 inches shallow
Re: heater install
Old May 13th, 2008, 10:51 PM
ARZEEAR's Avatar
ARZEEAR ARZEEAR is offline
ARZEEAR
My RZR: 2008 Red RZR
Re: heater install
I spent the big bucks for the Polaris heater, but it seems to work good. It'll be real nice this coming hunting season when I get my Cab installed.
Re: heater install
Old May 14th, 2008, 07:32 PM
Sprinklerhead Sprinklerhead is offline
First Name: Kevin
My RZR: uuhh-Green
Re: heater install
There is a heater you can install on the rzr that is ceramic type and is powered by your d.c. outlet on dash.Cost $50.00.Ill have to remember where i saw it.I do believe it was on a rzr aftermarket parts website.
Re: heater install
Old May 14th, 2008, 08:16 PM
rexdibble's Avatar
Re: heater install
$50 bucks now that's a good price. Post it if you remember
Re: heater install
Old May 14th, 2008, 08:34 PM
jackbenimble's Avatar
jackbenimble jackbenimble is offline
My RZR: 2008 3rd Gen
Re: heater install
I've seen this one advertised at a couple of different places. It is pretty cheap but not $50
12V DC Heater
I am personally not interested in a heater that draws 300 watts.
I have given this one at JC Witney some consideration. I think it is made by Tommy Toppers or at least they sell it too:
UTV Heater
$210 is a little more reasonable then Polaris. Has anybody tried that one?
Re: heater install
  #10 (permalink)
Old May 30th, 2008, 04:58 PM
weekend warrior weekend warrior is offline
First Name: scott
My RZR: red 08 rzr
Re: heater install
I BOUGHT A NICE CAB HEATER ON E BAY FOR $ 80.00 plus shipping its a 17,500 btu cab heater by zero start it comes all ready to install with box and fan w/ switches only 7x8x8 inches check it out northern tool . com also has them for about $ 200.00 bucks has 5/8 inlet and outlet simple hook up way cheaper than polaris
Re: heater install
  #11 (permalink)
Old May 30th, 2008, 06:47 PM
Re: heater install
Here is another one that is reasonably priced. I have no idea if it is any good.
Summit Automotive Heater
Re: heater install
  #12 (permalink)
Old November 4th, 2008, 01:13 PM
andrews08's Avatar
andrews08 andrews08 is offline
My RZR: 2009
Send a message via AIM to andrews08
Re: heater install
Zerostart 17,500 BTU Cab Heater, Model# 700-0101 | Heaters | Northern Tool + Equipment
Re: heater install
  #13 (permalink)
Old November 5th, 2008, 08:50 AM
jerrzr's Avatar
Re: heater install
[/IMG]
Re: heater install
  #14 (permalink)
Old November 22nd, 2008, 05:38 PM
joeobanion joeobanion is offline
Re: heater install
You guys know if you do not run atleast one of the heater lines from the core to behind the thermostat when the thermostat closes you will not have any heat, more noticable at low speed.....
Re: heater install
  #15 (permalink)
Old November 22nd, 2008, 06:47 PM
jerrzr's Avatar
Re: heater install
Not absoultly true. I have always had heat and actually more than needed. I didnt want to tap in before the thermostat because I felt by doing so it would prevent the engine from getting up to temp or better said -overcooling; just like when a thermostat is stuck open on your car and you never get heat from your heater. The heater core is cooling the engine. True, the thermostat opens and closes maintaing an optimal temp for the engine and when its open, the heater is pushing out about 180degree air and when the tstat closes the heat output decreases as the coolant begins to cool in the core. But like I say i allways have heat and more than enough to keep me warm and my engine doesnt have to suffer for it.
