Cheap solution to open flow to radiator |
March 17th, 2008, 08:59 PM
PITCHER
My RZR: RED
I wanted to increase the air flow on the razor. So with a couple of beers down I embarked on a project that had been brewing for a couple of months. I have seen the grills that you rivet to the front plastic and i wasnt too impressed for the price. Plus you still dont get maximum air flow.
I started by cutting the hood at the break point when it turns downward. This first cut is the most expensive, $200.00 is the price of a new hood. After the making the cut I felt a hole lot better about my mod.
Next was a trip to Home depot. First I bought a 12'' X 30'' I think piece of expanded metal. The box reffered to using it on a charcoal bbq. Then a 36'' X 1'' piece of thin wall box tube. 2 wing bolt 1/4'' x 1 1/4'' and a big can of rustoleum black spray paint.
Apon arrriving home I fit the piece of box tube on the top rail of the inner support assy. I used 3 self tapping screws securing it(the box tube) to the rail.
next I drilled holes in the hood and into the box tube. I tapped the 2 holes with a 1/4'' 20 tp tap.
Then I marked and cut the expanded metal to fit in the void between the two supports in front grill assy...
Spray painted the box and expanded metal and installed pieces. Using the 2 torx 27 bolts that hold the grill assy together bolt through the expanded metal and you have a good cheap mod...I cant seem to get pics to load I will do it tomorrow.
FOR SALE: 2008 RZR mechanics special, Polaris gave me the parts but no labor.
Re: Cheap solution to open flow to radiator |
March 17th, 2008, 09:07 PM
First Name: Al
My RZR: 08 Red
I look forward to pictures.
March 18th, 2008, 08:48 PM
PITCHER
My RZR: RED
Heres some pics of the mods... Doesnt look bad but works soo good.I hope these work....
Reason: change
March 18th, 2008, 09:32 PM
My RZR: 08 Red Gen 2
Nice job with the cheap upgrade i like it. What beer exactly where you drinking when you thought of this might have to get some next time i step out into the garage for a project. Ha Ha!!!
March 29th, 2008, 06:37 AM
Good idea! Wondering if the hood might blow up/off at highway speeds? Have you done something to hold the front edge down?
May 13th, 2008, 11:04 PM
ARZEEAR
My RZR: 2008 Red RZR
Have you noticed if it cools better? Nice job, thanks for sharing.
May 14th, 2008, 08:28 PM
PITCHER
My RZR: RED
Yes it cools much better than stock compared to my buddys stock one the fan only kicks on half the time
