Fan Override Switch Schematic - Polaris RZR Forum - RZR Forums.net
post #1 of 17 Old August 9th, 2009, 08:17 PM Thread Starter
Buck RZR's Avatar
Member #8199
View Buck RZR's Photo Gallery(0)
I am interested in installing a fan override switch for my '09 RZR. My brother had a fan issue with his '02 Sportsman and he just used a jumper wire to bypass the temp sensor in the radiator. I would like to have a switch if this would ever happen. I'm not naive to electronics, but I'm drawing a blank on the schematics of the switch. I would like to have the led lit when the fan comes on and the ability to turn the fan on with the switch. Do I need a DPDT or can I make it work with SPST, which I have, with a diode. Any suggestions would be greatly appreciated.
Thanks, Buck RZR:rzrs:
Buck RZR is offline
post #2 of 17 Old August 9th, 2009, 08:32 PM
gearheadjoe's Avatar
My RZR: 2009 RZR
Member #7308
View gearheadjoe's Photo Gallery(0)
Re: Fan Override Switch Schematic
This might be a good option for ya, hope it helps. ATV parts, ATV tires, Quadovator ATV Accessories
gearheadjoe is offline
post #3 of 17 Old August 9th, 2009, 08:50 PM
rjsmith's Avatar
First Name: Ralph
My RZR: 2009 RZR Red
Member #4388
You need to tap into the yellow black wire from the fan relay take tap to one side of SPST switch, ground the other side of switch. This will allow fan to operate normally when switch is not thrown and operate all the time when switch is activated. If you want to add a indicator LED then it would be best to use a DPDT switch and have the LED on the other pole with the LED anode connected to 12 v and the cathode connected to the switch.
XP1000 Titanium Black
RZR 800 put out to pasture
1 Limey in a world of Yanks
rjsmith is offline
post #4 of 17 Old August 9th, 2009, 09:12 PM
GIFF-TURBO's Avatar
First Name: Gary
Member #3946
Feedback Score: 18 reviews
yeah what he said........lol wtf Ralph, you lost me at fan....lol
GIFF-TURBO is offline
post #5 of 17 Old August 9th, 2009, 09:16 PM
rjsmith's Avatar
First Name: Ralph
Member #4388
Just stick to stainless it won't hurt your rusty brain.....
rjsmith is offline
post #6 of 17 Old August 9th, 2009, 09:18 PM
GIFF-TURBO's Avatar
First Name: Gary
Member #3946
You got that.....but if I have electrical problems you will hear from me!!! .........LOL
post #7 of 17 Old August 10th, 2009, 07:32 AM
Penguin's Avatar
First Name: Doug
My RZR: 2009 CAMO RZR
Member #7120
View Penguin's Photo Gallery(1)
This is the one I just installed on my 09. Instructions were simple I had the same issue with my 2000 sportsman fan burt up never saw the over heat light. I also just installed a autometer phantom II water temp gauge as well.
Would be nice if PoPo would put seprate gauges in these machines but then again they would charge 1,000.00 more I guess.
Penguin is offline
post #8 of 17 Old August 10th, 2009, 11:08 AM Thread Starter
Buck RZR's Avatar
Member #8199
Thanks for your help!!!
Buck RZR
Buck RZR is offline
post #9 of 17 Old August 10th, 2009, 11:45 AM
KC
KCCOMPUTERS's Avatar
First Name: Kevin
My RZR: 08 Red RZR
Member #5370
View KCCOMPUTERS's Photo Gallery(52)
Or use the diode and the SPST switch, wiring the diode and led off of the switched terminal of the SPST switch. That way when its closed the led will light. diode will prevent drain when open. KC.
Im a victim to the RZR addiction, For which there is no cure...
But I am accepting donations for rehab. Please give what your heart tells you to. Thanks.
KCCOMPUTERS is offline
post #10 of 17 Old September 27th, 2011, 09:13 PM
rzr420's Avatar
Member #25760
View rzr420's Photo Gallery(0)
so i need to have a keyed or constant power run to switch, tap into power side of fan to switch and tap into ground to switch or do i need to use ground at all? if so would just tapping into ground side of fan work for the switches ground? i did one one on my old brute but just ran direct off battery with inline fuse. i want the thermo switch to still workthis time.
rzr420 is offline
post #11 of 17 Old September 28th, 2011, 08:33 AM
rzr420's Avatar
Member #25760
rzr420 is offline
post #12 of 17 Old September 28th, 2011, 06:36 PM
chipper's Avatar
First Name: Chip
My RZR: 2011 RZR
Member #15196
Feedback Score: 5 reviews
I hooked mine up from a second fuse box i installed, it is on an unswitched circuit so I can run it with the key off incase I'm having overheating problems. Use a 20 amp breaker so it will automatically reset if needed.
chipper is offline
post #13 of 17 Old July 17th, 2012, 03:23 PM
blklightning's Avatar
Member #19108
View blklightning's Photo Gallery(0)
ive emailed quadovator and no reply?
blklightning is offline
post #14 of 17 Old July 18th, 2012, 03:30 PM
chipper's Avatar
First Name: Chip
My RZR: 2011 RZR
Member #15196
Did you call? I know they have a phone number on their site.
chipper is offline
post #15 of 17 Old July 18th, 2012, 06:43 PM
skitownriders's Avatar
First Name: Dan
My RZR: rzr-s
Member #7911
View skitownriders's Photo Gallery(0)
Quadovator is the way to go. Plug and play and switch lights up when fan comes on either from manually turning on switch or auto when thermostat turns on fan.
skitownriders is online now
Make AWD switch to 4WD? Jas149mxer Engine and Drivetrain 32 May 17th, 2010 09:46 AM
Need Schematic SuperBuys Engine and Drivetrain 5 July 18th, 2009 01:53 PM
08 Wiring Schematic Stumpduster Lighting, Stereo and Electrical 3 May 7th, 2009 05:48 PM
Custom switch panel rzr.racer Lighting, Stereo and Electrical 58 March 23rd, 2009 07:50 PM
All Time 4x4 Switch powermizer Engine and Drivetrain 2 January 27th, 2008 02:38 PM
