Pet Carrier for bed...
Old February 25th, 2008, 06:28 PM
bluesti's Avatar
bluesti bluesti is offline
In Over My Head
First Name: Matt
My RZR: Red 2008
I wanted a simple, cheap solution for carrying my dog in the back of my RZR so I set out to do just that. If Polaris made something, I may have bought it, but looking back on the litle work it took and the money saved, this is a GREAT way to accomplish it.
Total time: 3 hours
Difficulty (1-5): 2
Price: $25 (excluding any tools)
Here is a list of the items needed:
- 3/4" Schedule-40 PVC pipe (48")
- Plastic Mesh Netting
- 3/16" Rivets
- 3/16" Fender Washers
- Sand Paper (Medium Grit)
First things first... the 3/4" PVC is NOT a direct fit into the hole, because the holes are tappered. Just cut a few strips of sand paper, and get to work! You may want to cut the 48" piece in half, to make working easier. I concentrated on about a 3" section of the bottom of the pipe, because only 1" actually goes into the hole.
Just keep sanding, and test fitting until the piece fits ALL the way into the hole, about an inch. You want a tight fit, so don't sand TOO much.
The next thing I did, was grab my dog, and place him in the back after the first pole was sanded. Measured up to his neck level, and marked with a Sharpie, and cut it. After that, kept sanding and placing the OTHER pieces in, and with a level, measured the top of the rest, after the FIRST piece as a reference.
Here's the first 3 or so completed...
And after a little more work and time... all 6 in place...
The next part was obviously the tricky part... working with the plastic mesh. Here's the exact brand that I bought...
Here's a shot of what we're dealing with... it's VERY easy to measure and cut because it has flat parallel squares the whole length of the material. Scissors or dikes work well!
Now I simply rolled a chunk around the whole RZR, and cut off a piece a little easier to work with... as well as shortened it up. As you can see, I used zip-ties as I went along, to keep the pieces I had already measured and cut, secured... It was simply a matter of going around, and just cutting as I went, to get it lined up! Very easy...
After I had it all cut and measured... I had to do a test-fit of course!!! []
Buster approved, and gave me the final go-ahead to complete it...
While it was all in place with the zip-ties... I drilled the 3/16" holes I needed for the rivets. 2 on the short ones, and 3 on the tall ones in the rear. Then, I took everything apart... Sprayed the PVC all black, and then waited for the paint to dry...
Here's the washers you'll need... they're called "Fender Washers" and again, 3/16" is the size...
Once dry... I put everything in place, and simply riveted everything in to the PVC for good. It's all easily removable, and VERY tight and secure when in place. Will easily hold up to the weight of a dog and if you ever need to, it's easy to rebuild. In all honesty, I probably won't even remove it that much.
Here is the final product!!!!
A great solution for people with small pets, or any other cargo you just want to keep inside. The best part is, there's a small gap between the net and the roll cage, so the dog can still peek his head out and have his face in the wind... which all dogs love!
Re: Pet Carrier for bed...
Old March 5th, 2008, 07:10 PM
Arctic rzr's Avatar
Arctic rzr Arctic rzr is offline
I am laughing my a$$ off.That is the coolest Dog catcher mobile EVER.
Old March 5th, 2008, 09:15 PM
ARZEEAR's Avatar
ARZEEAR ARZEEAR is offline
ARZEEAR
My RZR: 2008 Red RZR
Very Cool. I had a yellow lab that loved riding on ATV's. I lost her 2 years ago. I plan on getting another dog and I will make this for her. Do you tie your dog to something in the front of the box with a leash for safety?
Old March 6th, 2008, 09:52 AM
XXXOffroad XXXOffroad is offline
Buster needs some gription to keep from sliding around.
Maybe a piece of indoor outdoor carpet on the bed?
Double sided carpet tape should do the trick to hold it in place.
Old March 6th, 2008, 11:31 AM
bluesti's Avatar
In Over My Head
First Name: Matt
My RZR: Red 2008
Yeah, I'll be putting some carpet in the bottom of the bed for sure!
I also bought a chest-harness for him, and will clip the lead to the top of the roll cage, with just enough slack so he can move around, but not fall out if I hit a bump!
Old March 6th, 2008, 04:33 PM
jdhoggg's Avatar
jdhoggg jdhoggg is offline
Man that is really cool! I have thought about taking one of my dogs with me, but he won't go anywhere without his "girlfriend" and she doesn't want anything to do with riding in the RZR.
Old March 15th, 2008, 01:19 PM
WB7S WB7S is offline
First Name: Jerry
My RZR: 2008
Got to make something for our 10 pound Pomeranian...8 pounds without all her fur!
Some good things to think about here!!!.
Old May 15th, 2008, 04:38 PM
getfit74's Avatar
getfit74 getfit74 is offline
That's awesome man, I have an Australian Sheperd and he loves to ride. Was thinking last weekend I was gonna have to come up with something, think I'm gonna get the stuff and make one of those as well. Great job and thanks for sharing.
Old May 23rd, 2008, 09:46 PM
ddog9600 ddog9600 is offline
Thats a cool idea. I didn't think it would turn out looking so good.
  #10 (permalink)
Old June 27th, 2008, 12:07 AM
checkpoint's Avatar
checkpoint checkpoint is offline
First Name: Don
My RZR: '08 Red
Few months ago purchased a dog carrier sold to be used in vehicles. I bolted it to the top of the cargo box far enough forward to still open the box. The carrier has a more than adequate 3 point restraint for our 15 # dog.
When we take the full size Ranger it's easy to remove the bolts and put the carrier in the middle of the bench seat and secure with seat belt which is the intended attachment in a vehicle.
Don't laugh but this alone wasn't enough for my wife so she made me make a sun canopy and to help protect the dogs eyes from dust, dirt and mud I also had to mount a plexiglas windshield.
'05 DODGE 3500 DUALLY
H.D. CUMMINS
Vision '02 Trail Lite Trailer
'07 Polaris Ranger XP
'08 Polaris RZR
  #11 (permalink)
Old June 27th, 2008, 10:15 AM
RedMan RedMan is offline
I think that windshield is going to make fluffy one dusty dog.
  #12 (permalink)
Old July 23rd, 2008, 08:20 AM
bluesti's Avatar
In Over My Head
First Name: Matt
My RZR: Red 2008
Crap! My hosted pics disappeared...
I need to re-post them if I can find them...
When I grow up, I want to be a kid again...
