This is a discussion on Clutch Spacer Removal... THE RIGHT WAY! (pics) within the Projects and How-To forums, part of the General RZR category; **THIS DOES NOT APPLY TO THE RZR "S" OR SOME NEWER 09+ MODELS... THEY HAVE NO SPACER** I just recently bought my RZR a few ...
I just recently bought my RZR a few days ago, and after much searching and looking around, found a few threads on the subject. They all has similar content, but none of them had really clear-cut instructions for those people a little unsure about what they're doing. As you probably know, the clutch spacer is known to increase the top speed of the RZR by 4-5 MPH, up to around 60-62mph. I asked the dealer service center about this mod, and the service tech was ALL FOR IT... in fact he wanted me to report the results! He said it should in no way affect the warranty, but mentioned the only thing that may take the abuse is the belt... which isn't warrantied anyway, and EASY to replace! So here we go! I took a few pics of the important steps along the way, to help those that are debating it. THIS IS A PIECE OF CAKE!!! If you at all mechanically inclined, you'll have no trouble! The method I chose to take, is probably the most effective, reliable, and safest way to do it. No hammer/chisel... No hot blade... and the parts are saved if you want to replace. I chose the "remove the clutch cover" method... It didn't take any longer than the other methods, and if anything is probably EASIER! Total time: 25 minutes start to finish Difficulty (1-5): 2 The first few steps I didn't take any pictures, because I'm going to assume that if you're trying this, you have a "little" mechanical common sense. First remove the seats... and the black plastic cover that hides the transmission set-up... Then you'll see the tranny-cover which has a black tube coming out of the top... simply losen the hose-clamps, remove the two black push-fasteners that hold the vent-pipe in place, and remove that tube all together... you're left with the following... You'll see the cover, and the open hole where the pipe once was... I circled the screws you need to remove in red, there's around 8 or so total. In blue, I circled the 2 bolts and 2 screws you need to remove on the seat-belt mounting bar... This will come right out to make everything easy. ![]() After you remove the cover... you can see the exposed clutch and CVT assembly... Here's the spacer you're looking for, in the clutch... ![]() Some people break it with a chisel and hammer... or melt it with a hot blade... but I prefer to do it properly, and keep the stock spacer intact, in case you ever want or need to re-install it. The next step, is to simply un-bolt the 6 bolts that I circled below... don't worry there's NO pressure on the plate yet, it's being held by the center bolt... ![]() Now you have the clutch cover, with just the center bolt holding it in place... take the 5/8" socket again, and loosen the center bolt, while holding the cover... take note as to how much force is needed to release the bolt, as you want to apply similar torque when you are replacing it... don't worry, it doesn't spring off hard, it's VERY LIGHT pressure (have your wife or girlfriend hold it, if you're scared)... ![]() ![]() After that, just slide the bolt out, making sure not to lose the plastic sleeve that the bolt sits inside... and remove the spacer! ![]() After that, re-insert and re-tighten the center bolt, ensuring everything lines up correctly... apply around 50 ft/lbs, which is NOT very hard... you can crack the magnesium cover if you go crazy. Like I said, similar to the pressure you used to remove that bolt, and just a "tiny" bit extra when going back in. Now just reverse all the steps, and you're done... should only take 20-30 minutes, and all parts are intact! Probably the safest and easiest way to do this... Hope this helps the newcomers, and people still unsure about it. It was literally MUCH MUCH easier than I thought it was going to be! Last edited by BlueSTI; October 4th, 2009 at 01:38 PM. |
| Sponsored Links | ||
Re: Clutch Spacer Removal... THE RIGHT WAY! (pics)
Wow! I have been contumplating doing this but I was affraid there might be too much pressure on the clutch and things would just fly out upon attempting this! Great job on your 'How-To'. Now I'm going to do it. Thanks!
Nice. I will admit I have tried about 4 different methods with the hot blade being the fastest and not even a scratch. But I guess an extra 5 minutes doesn't matter one way or another. I just didn't want to risk the possibility the 2 sections needing to be installed in the same position they were removed.
:Polaris Parts Catalog: :RZR Manuals: :08 Service Manual: :My RZR Project: Keep It Wet and Dirty! |
Make sure you put the clutch end cover back on in the same place!
The clutch is a balenced unit. Just mark it with marker before you take it apart. |
#8
ok bluesti;
how do you like it? how much more top speed did you really get? i have also thought about this mod... i have some concerns with belt life after spacer removal... thank you for the great post...... |
#9
I haven't been able to test the top speed yet... I just bought mine 3 days ago... notice the perfectly clean unit? lol
My street is too small to get up to speed. As soon as I get it topped out, I'll report back. |
#10
boooyyy thats uh perrrty rzr i could fixit right quick,on a more serious side how often do you expect to see that extra 4 miles an hour on the trail,not tryin to be a dick or any thing,if you wana go fast we go fast,your only 40 mins away from me and some fun trails the rzr will be back together soon we go faaast
#11
Where do you ride at?
We're going to be going to Gorman a lot... and there's PLENTY of trails out there where you can max it out. Plus, again... why not? Extra top end in the rare case you "might" need it... better to have it, than not, right? |
#13
the dead is done....
i surrendered to the speed gods and removed my spacer today. god forgive me. have mercy on my speed loving soul...... will be able to test it against 4 rhinos this weekend. 2 of them have cdi boxes. i lost to one of them before. not anymore!!!!!!!!! |
| Visitors found this page by searching for these keywords: |
polaris clutch removal,polaris rzr clutch,rzr clutch spacer removal,polaris clutch removal too,How to take a clutch off of a polaris rzr,clutch spacer,polaris rzr clutches,polais rzr clutch,polaris rzr clutch removal,polaris razor s spacer removal,clutch for polaris rzr,HOW 2 C A PIC OF A SPACER,polaris rzr ebs clutch,Spacer in Main Clutch of Polaris RZR,seatbelt bolts,rzr clutch removal tool,how hard is it to change plastic sleeves on a polaris clutch,polaris drive clutch removal,polaris ranger clutch removal,how to install polaris rzr throttle spring |
| Thread Tools | |
| Display Modes | |
| Clutch Spacer | cbowtie | Engine and Drivetrain | 11 | January 24th, 2009 05:33 PM |
| clutch spacer mod | rafael_250r | RZR-S Specific Discussion | 4 | November 13th, 2008 11:04 AM |
| clutch spacer removal | rugman | General RZR Discussion | 2 | October 28th, 2008 08:39 PM |
| getting rid of clutch spacer for more MPH? | norcalsvx | Engine and Drivetrain | 41 | September 20th, 2008 06:54 PM |
| Clutch spacer removal question | JB408 | General RZR Discussion | 3 | September 18th, 2008 05:22 PM |
