Clutch Spacer Removal... THE RIGHT WAY! (pics)
This is a discussion on Clutch Spacer Removal... THE RIGHT WAY! (pics) within the Projects and How-To forums, part of the General RZR category; Quote: Originally Posted by mEthOdsOmAhAn My spacer has been out for 1500 miles with no belt affect BUT I did notice a SLOWER acceleration . ...
  #31
Old July 24th, 2008, 08:21 AM
BlueSTI's Avatar
"The Belt Killer"
First Name: Matt
My RZR: Red 2008
Member #1401
View BlueSTI's Photo Gallery(20)
Re: Clutch Spacer Removal... THE RIGHT WAY! (pics)
Quote: Originally Posted by mEthOdsOmAhAn View Post
My spacer has been out for 1500 miles with no belt affect BUT I did notice a SLOWER acceleration . cruising on the streets is a lot better because the rpms are much lower at 55 . I mainly ride in woods/mud/highway. I AM THINKING ABOUT CUTTING IT IN HALF AND REINSTALLING IT .
The slower acceleration must be due to something else. The spacer has NO effect on anything but top speed.
-I may not be the fastest... but I'll be damned if I'm the slowest!
-I make up for power, by adding stickers and flashing lights.
  #32
Old July 24th, 2008, 08:28 AM
acsracing's Avatar
First Name: Sherman
My RZR: Blue Silver Black one
Member #1489
View acsracing's Photo Gallery(0)
raise rev limiter differnt programming on cdi. Pipe fuel controller clutch kit.
  #33
Old July 25th, 2008, 04:47 PM
Dilledille's Avatar
My RZR: 2008
Member #2977
View Dilledille's Photo Gallery(0)
The pictures and your explanation were very good. You done an excellant job. I have not attempted this yet but with your help I don't see any problems. Thank you.
Any chance of you doing the same thing with the air filter box? From what I have read it is a great problem.
  #34
Old July 25th, 2008, 07:33 PM
mEthOdsOmAhAn's Avatar
Member #3446
View mEthOdsOmAhAn's Photo Gallery(0)
this is incorrect due to removing the spacer effectivly " gears " it higher thus bringing it out of the power band lugging/bogging the engine . Mine had 2 miles on it when i removed it . made several passes ( drag racing another stock one ), 15 minutes later made several more with the spacer removed . about 7 mile an hour faster , but slower acceleration . I have been riding , racing , mechanicing , atvs since 1986 .
  #35
Old July 25th, 2008, 08:10 PM
fanjules's Avatar
Member #2903
View fanjules's Photo Gallery(0)
So is that true? It's about the only place I've read that. And if it does increase the gearing theoretically mpg could increase a little?
  #36
Old July 28th, 2008, 04:42 PM
Mr_Huntsburg's Avatar
First Name: Bill
My RZR: Not yet, TBD
Member #3455
View Mr_Huntsburg's Photo Gallery(0)
Will the removal of the spacer effect the warranty?
  #37
Old July 28th, 2008, 08:03 PM
jklein322's Avatar
First Name: Jim
My RZR: 2008 800 efi Red
Member #2348
View jklein322's Photo Gallery(6)
I just completed the job. It was super easy and didn't take anytime at all!
Your the best
  #38
Old August 3rd, 2008, 01:27 PM
psycholime's Avatar
My RZR: 08 rzr gen 1
Member #1885
View psycholime's Photo Gallery(0)
So did anyone else loose low end acceleration? Thought about removing the spacer as well but not if it is going to loose low end speed? Spoke to holztech the other day and they said don't take it out if i did their clutch kit.
  #39
Old August 3rd, 2008, 02:11 PM
fanjules's Avatar
Member #2903
I'm leaving mine in for now. I'm sure it does something other than improve top speed for free, nothings free - why do Polaris have a spacer at all? If it does change the gearing, then it makes sense that aside from the speed, acceleration, and economy changes, there is also increased load on the belt at low speeds.
  #40
Old August 6th, 2008, 08:38 PM
Trey's Avatar
Member #3584
View Trey's Photo Gallery(5)
Thats what im saying. i think it may be putting the belt under more pressure at low speeds
  #41
Old August 6th, 2008, 08:54 PM
gdog's Avatar
Member #736
View gdog's Photo Gallery(0)
My dealer told me "no problem" if I take it out.
  #42
Old August 7th, 2008, 01:34 AM
fanjules's Avatar
Member #2903
Is this the same dealer that said there was "no problem" with the filter?
Spacer removal + uprated belt might be worth while though. My take is the RZR was originally meant to have a 65-ish top speed, but they lowered it to 55mph to extend the life of the belt, since that's a lot cheaper for the bean counters ($0.50) than a reinforced belt ($+20?), or a warranty belt replacement? Perhaps they just found the RZR needed to be geared slightly lower through testing... being geared as it was in stock form, but add on on two humanoids, 140lbs+ of accessories, and typical cargo that you take on a trail and it really was a bit too much of a strain.
That all seems logical, and having a spacer is a neat way and very cheap/quick way of being able to gear a vehicle to a speed of your choosing! We just need somebody to determine with performance timing equipment or some other means, that the gearing is actually changed and the spacer simply isn't a brick wall at the end of the performance envelope, which makes a lot less sense.
  #43
Old August 7th, 2008, 07:30 AM
gdog's Avatar
Member #736
Uh...yeah
He basically said he was told...it was to limit the speed a bit and that they had not had any problems with a bunch of guys who have taken it off.
All I care about if/when the belt blows...I'll go back and say "You told me to take it off!"
And in regards to the filter...they are warrantying all the new parts for me...boot, filter, ring and lip on TB + if that doesnt work, a DF filter system at their cost.
  #44
Old August 12th, 2008, 04:43 PM
Camlsr's Avatar
Member #2959
View Camlsr's Photo Gallery(0)
CA Re: Clutch Spacer Removal... THE RIGHT WAY! (pics)
Hey Matt when you go to Gorman to ride are the trails restricted to the 50" trail width UTV or ATV's? I have a long travel kit on my RZR. What exit off of the 5? Does it cost any to ride? Great post I am gonna try it. Great Pics too! I live in Whittier over the hill from Covina.
  #45
Old August 13th, 2008, 07:49 AM
Member #3446
i now have 1500 miles on the original belt with out the spacer . it will cruise at 55mph at a much lower rpm , which i think is alot easier on the engine .
Bookmarks
Clutch Spacer cbowtie Engine and Drivetrain 11 January 24th, 2009 05:33 PM
clutch spacer mod rafael_250r RZR-S Specific Discussion 4 November 13th, 2008 11:04 AM
clutch spacer removal rugman General RZR Discussion 2 October 28th, 2008 08:39 PM
getting rid of clutch spacer for more MPH? norcalsvx Engine and Drivetrain 41 September 20th, 2008 06:54 PM
Clutch spacer removal question JB408 General RZR Discussion 3 September 18th, 2008 05:22 PM
