This is a discussion on Clutch Spacer Removal... THE RIGHT WAY! (pics) within the Projects and How-To forums, part of the General RZR category; No one answered an earlier question in the thread, so I'll ask it again... I have an iTi performance ECU, which increases my rpm to ...
#196
Re: Clutch Spacer Removal... THE RIGHT WAY! (pics)
I have an iTi performance ECU, which increases my rpm to 7000. Will removing the spacer potentially hurt the motor when I'm full throttle? I ride strictly at Glamis, and I just removed the spacer tonight before my new years trip. I just want to make sure I made the right decision. I have it at full throttle a lot on my way to the drags, or during the drags. Thanks, Ron
-Ron J - Custom RZR |
| Sponsored Links | ||
#199
I think you're askin for a bent crankshaft if it's stock....thats what I think!
Save The Riders Dunes WebsiteMy Website...Check it out & sign my guestbook! |
#200
i wouldnt go over 6,800 spacer out is good...but watch the rpm the turbo high hp guys are bending the crank around 7,000
#201
The mechanic where I bought mine says between 6750 & 7000 RPM are the worst on this crank as far as vibration goes. He claims if you're high enough HP to scream past 7000 to an even higher RPM the motor will be happier. A steady RPM in the 6750 to 7000 is what kills em according to him.
#202
Someone said early about installing a "S" setup (primary & secondary) on the standard model. Is this possible? I'm interested because of the engine breaking & top speed increase. Alot of steep hills around here and I have to tap throttle to try and keep engine braking on.
#203
i just walked my 9 year old through taking out our spacer. that was a breeze. didnt try it out yet its only 17deg. here today.! thanks for the good directions!!!
#204
**THIS DOES NOT APPLY TO THE RZR "S" OR SOME NEWER 09+ MODELS... THEY HAVE NO SPACER**
I just recently bought my RZR a few days ago, and after much searching and looking around, found a few threads on the subject. They all has similar content, but none of them had really clear-cut instructions for those people a little unsure about what they're doing. As you probably know, the clutch spacer is known to increase the top speed of the RZR by 4-5 MPH, up to around 60-62mph. I asked the dealer service center about this mod, and the service tech was ALL FOR IT... in fact he wanted me to report the results! He said it should in no way affect the warranty, but mentioned the only thing that may take the abuse is the belt... which isn't warrantied anyway, and EASY to replace! So here we go! I took a few pics of the important steps along the way, to help those that are debating it. THIS IS A PIECE OF CAKE!!! If you at all mechanically inclined, you'll have no trouble! The method I chose to take, is probably the most effective, reliable, and safest way to do it. No hammer/chisel... No hot blade... and the parts are saved if you want to replace. I chose the "remove the clutch cover" method... It didn't take any longer than the other methods, and if anything is probably EASIER! Total time: 25 minutes start to finish Difficulty (1-5): 2 The first few steps I didn't take any pictures, because I'm going to assume that if you're trying this, you have a "little" mechanical common sense. First remove the seats... and the black plastic cover that hides the transmission set-up... Then you'll see the tranny-cover which has a black tube coming out of the top... simply losen the hose-clamps, remove the two black push-fasteners that hold the vent-pipe in place, and remove that tube all together... you're left with the following... You'll see the cover, and the open hole where the pipe once was... I circled the screws you need to remove in red, there's around 8 or so total. In blue, I circled the 2 bolts and 2 screws you need to remove on the seat-belt mounting bar... This will come right out to make everything easy. ![]() After you remove the cover... you can see the exposed clutch and CVT assembly... Here's the spacer you're looking for, in the clutch... ![]() Some people break it with a chisel and hammer... or melt it with a hot blade... but I prefer to do it properly, and keep the stock spacer intact, in case you ever want or need to re-install it. The next step, is to simply un-bolt the 6 bolts that I circled below... don't worry there's NO pressure on the plate yet, it's being held by the center bolt... ![]() Now you have the clutch cover, with just the center bolt holding it in place... take the 5/8" socket again, and loosen the center bolt, while holding the cover... take note as to how much force is needed to release the bolt, as you want to apply similar torque when you are replacing it... don't worry, it doesn't spring off hard, it's VERY LIGHT pressure (have your wife or girlfriend hold it, if you're scared)... ![]() ![]() After that, just slide the bolt out, making sure not to lose the plastic sleeve that the bolt sits inside... and remove the spacer! ![]() After that, re-insert and re-tighten the center bolt, ensuring everything lines up correctly... apply around 50 ft/lbs, which is NOT very hard... you can crack the magnesium cover if you go crazy. Like I said, similar to the pressure you used to remove that bolt, and just a "tiny" bit extra when going back in. Now just reverse all the steps, and you're done... should only take 20-30 minutes, and all parts are intact! Probably the safest and easiest way to do this... Hope this helps the newcomers, and people still unsure about it. It was literally MUCH MUCH easier than I thought it was going to be! |
#205
This was the first mod I did to my '08. 55 mph with the spacer in, I gained anywhere from 10 -12 mph by removing the spacer. Top speed according to the speedo depending on the terrain is between 67 - 68 mph.
#208
dragon fire racing says to not remove the spacer. that it puts it into an overdrive gear or something like that.....is that true. says it right on their website under clutching
08 rzr 800, Elka's all corners,hid's,hid front acc lights ,trail armor steering stabilizer, viper elite 4000 winch, clutch kit,dragon fire duel exhaust,dragon fire intake,dragon fire fuel programmer,upgraded throttle spring,Polaris rear acc rack,fox racing steering wheel,dragon fire racing seat belts,pro armor a-arm guards, tusk UHMW 3/8 skid plates,one inch wheel spacers,all balls wheel bearings front and back,Polaris shoulder and under dash storage bags,rear frame gusset,maier scooped black hood,regulator relocate kit. i once wrestled a giraffe to the ground with my bare hands!! |
#209
The new RZR's don't have the spacer, and 1000's have removed it on 08's and 09's with thousands of trouble free miles. I'd say it's OK to remove.
#210
I'd love to take mine out and I'm def not looking to start fight. I am curious if it actually gives it a taller gear ratio......what do you guys think?
| Visitors found this page by searching for these keywords: |
polaris clutch removal,polaris rzr clutch,rzr clutch spacer removal,polaris clutch removal too,How to take a clutch off of a polaris rzr,clutch spacer,polaris rzr clutches,polais rzr clutch,polaris rzr clutch removal,polaris razor s spacer removal,clutch for polaris rzr,HOW 2 C A PIC OF A SPACER,polaris rzr ebs clutch,Spacer in Main Clutch of Polaris RZR,seatbelt bolts,rzr clutch removal tool,how hard is it to change plastic sleeves on a polaris clutch,polaris drive clutch removal,polaris ranger clutch removal,how to install polaris rzr throttle spring |
| Thread Tools | |
| Display Modes | |
| Clutch Spacer | cbowtie | Engine and Drivetrain | 11 | January 24th, 2009 05:33 PM |
| clutch spacer mod | rafael_250r | RZR-S Specific Discussion | 4 | November 13th, 2008 11:04 AM |
| clutch spacer removal | rugman | General RZR Discussion | 2 | October 28th, 2008 08:39 PM |
| getting rid of clutch spacer for more MPH? | norcalsvx | Engine and Drivetrain | 41 | September 20th, 2008 06:54 PM |
| Clutch spacer removal question | JB408 | General RZR Discussion | 3 | September 18th, 2008 05:22 PM |
