Clutch Spacer Removal... THE RIGHT WAY! (pics)
This is a discussion on Clutch Spacer Removal... THE RIGHT WAY! (pics) within the Projects and How-To forums, part of the General RZR category; Brake it in like you stole it.It works for me!!!!!!!!!...
  #151
Old July 13th, 2009, 09:58 PM
crazywatson's Avatar
Just kidding!
First Name: steve
My RZR: red
Member #3534
Re: Clutch Spacer Removal... THE RIGHT WAY! (pics)
  #152
Old July 13th, 2009, 10:55 PM
MotoXXX's Avatar
MCX Rhino Hunter
Feedback Score: 10 reviews
First Name: Jeff
My RZR: 2008 with 2009 RZR S motor & MCX turbo
Member #4542
I was in Winchester Bay all last week from the 5th to the 12th. I think it was on the 7th or so I put on my new belt after washing it in hot soapy water, and cleaning the sheaves with rubbing alcohol. Before installing the belt I pulled the limiter out and lightly scuffed the edges of the belt with a green scotch brite pad. I performed the two heat cycles break in procedure then I put 300 pretty hard miles on it after that and it is still working great. I found that after removing the limiter I could not hit the rev limiter any more. The sand flats were rough enough that all I could do was 61 or 62 mph at 6000 rpm, any faster and I was about to swap ends... I guess it's time for some good shocks?
2008 Red Gen 3, 09 "S" motor & MCX turbo, S cage, Rigid 20" LED Lightbar, Raptor V2 35W HID Headlights, UTV TECH hood & grille vents, Pro Tek fuel tank armor, UMP intake,Progressive springs from Makintrax Suspension
Save The Riders Dunes Website
My Website...Check it out & sign my guestbook!
  #153
Old July 29th, 2009, 11:31 PM
RzR Finland's Avatar
Member #8900
View RzR Finland's Photo Gallery(0)
This mod sounds great,but how about the power in the low end?is it tested as a fact?i can hit 57mph stock,it would be nice to get a few more mph couse in wintertime we drive a lot on the ice.
  #154
Old July 29th, 2009, 11:50 PM
rjsmith's Avatar
First Name: Ralph
My RZR: 2009 RZR Red
Member #4388
No effect to low end, just increases top speed. Polaris has totally removed this spacer on all 2010 models.
1 Limey in a world of Yanks
  #155
Old July 30th, 2009, 09:31 AM
wadkins's Avatar
First Name: Jeremy
Member #5972
View wadkins's Photo Gallery(0)
i removed the clutch spacer yesterday and i picked 5 to 6 mph it is worth the 20 mins thanks guys
  #156
Old July 31st, 2009, 08:04 PM
Scout's Avatar
First Name: Rick
My RZR: 09 Sunset Red LE
Member #8729
View Scout's Photo Gallery(0)
Just completed this today, thanks for the post.
  #157
Old July 31st, 2009, 08:09 PM
moparrbust's Avatar
My RZR: 2008
Member #8071
View moparrbust's Photo Gallery(0)
I just did the spacer removal when I installed my DDP clutch setup and new belt................can't wait to take it out for a spin on Sunday.
2008 RZR Lamborghini candy blue with complete clear bra
  #158
Old August 11th, 2009, 01:43 PM
RZRCRZY's Avatar
My RZR: 2008 Gen 3
Member #839
View RZRCRZY's Photo Gallery(0)
I have had my spacer out since Sept 2007 when I installed the EPI stage II clutch kit. My EPI belt has over 600 very hard miles on it with no signs of wear. I only had the RZR a week before removing the spacer so I can't say for sure if it lost any low end, but when riding with other RZR's I do not seem slower off the line. Great post!!!
  #159
Old August 12th, 2009, 08:33 AM
STEELERZR's Avatar
First Name: RYAN
My RZR: 2008 RZR
Member #8738
View STEELERZR's Photo Gallery(0)
Can you still use the stock belt.
  #160
Old August 12th, 2009, 08:51 AM
mnrzr-s's Avatar
First Name: Jon
My RZR: 2009 LE Nuclear Sunset
Member #7165
View mnrzr-s's Photo Gallery(1)
Yep!
  #161
Old September 1st, 2009, 06:16 PM
wish's Avatar
First Name: Doug
My RZR: 09
Member #9387
View wish's Photo Gallery(0)
Thumbs up Re: Clutch Spacer Removal... THE RIGHT WAY! (pics)
Thanks alot. I had heard about all the horror stories about this. Following your(THE RIGHT WAY) it was pretty easy. Thanks for taking the time and pics and showing THE RIGHT WAY
  #162
Old September 10th, 2009, 09:22 PM
dewdley's Avatar
My RZR: 2009 RZR Stealth Black
Member #7156
View dewdley's Photo Gallery(0)
Any word on how the belt made out after removal of spacer?
  #163
Old September 10th, 2009, 10:06 PM
mnrzr-s's Avatar
First Name: Jon
Member #7165
No problems! The 2010 RZR doesn't even come with a spacer. The only reason I wouldn't recommend removing the spacer is if you don't want to go faster
  #164
Old September 19th, 2009, 02:32 AM
EasTTeX's Avatar
My RZR: 2008 RZR first generation project
Member #8752
View EasTTeX's Photo Gallery(18)
Hmmm...Let me try to find a way to slow my rzr down, I know, I'll put the danged old spacer back on that I cut off...dammit. Cut it off be done and don't look back, you'll just see your buddies. Nice job on the pics -n- stuff Maybe I should order another spacer to keep on hand : )
  #165
Old September 23rd, 2009, 11:15 AM
mister's Avatar
Member #4899
View mister's Photo Gallery(0)
I removed my spacer and tried it last night. I had done some acceleration runs from 0-50 mph before I removed the spacer, so I did again after I removed the spacer to make sure I still had my acceleration. It still accelerated great, no change. I then did a top speed run up the road, I easily hit 60 mph. I turned around and flew down the road and hit 62-63 mph.
2009 Polaris RZR (red)
>Polaris/FMF pipe and Header
>Dynojet Power Commander 3
>ATVDOC airbox
2010 Polaris RZR Walker Evans LE
>Factory UTV Skids
>Warn 3,500 lb. winch
>Polaris/FMF pipe
polaris clutch removal
polaris rzr clutch
rzr clutch spacer removal
polaris clutch removal too
How to take a clutch off of a polaris rzr
clutch spacer
polaris rzr clutches
polais rzr clutch
polaris rzr clutch removal
polaris razor s spacer removal
clutch for polaris rzr
HOW 2 C A PIC OF A SPACER
polaris rzr ebs clutch
Spacer in Main Clutch of Polaris RZR
seatbelt bolts
rzr clutch removal tool
how hard is it to change plastic sleeves on a polaris clutch
polaris drive clutch removal
polaris ranger clutch removal
how to install polaris rzr throttle spring
Clutch Spacer cbowtie Engine and Drivetrain 11 January 24th, 2009 05:33 PM
clutch spacer mod rafael_250r RZR-S Specific Discussion 4 November 13th, 2008 11:04 AM
clutch spacer removal rugman General RZR Discussion 2 October 28th, 2008 08:39 PM
getting rid of clutch spacer for more MPH? norcalsvx Engine and Drivetrain 41 September 20th, 2008 06:54 PM
Clutch spacer removal question JB408 General RZR Discussion 3 September 18th, 2008 05:22 PM
