2013 Polaris RZR 570 Specs - Polaris RZR Forum - RZR Forums.net
This is a discussion on 2013 Polaris RZR 570 Specs within the Polaris RZR News forums, part of the RZRForums.net category; Key Features: NEW! Trail Limited Edition with Electronic Power Steering (EPS), Engine Braking System (EBS) and Versatrack Turf Mode NEW! Flow-through seatbelt tongue for easy ...
Go Back   Polaris RZR Forum - RZR Forums.net > RZRForums.net > Polaris RZR News
Polaris RZR News News involving the Polaris RZR and site news will be posted here. News in this section will be posted to the front page. Only RZRForums.net staff may start new threads in this section.
Old July 30th, 2012, 09:01 PM   #1
4Nines's Avatar
My RZR: 09 RZR S
Member #5322
View 4Nines's Photo Gallery(1029)
Key Features:
NEW! Flow-through seatbelt tongue for easy adjustment
2013 Model Year Specifications
ENGINE
Engine Type: 4-Stroke DOHC Single Cylinder
Displacement: 567cc
Fuel System: Electronic Fuel Injection
Cooling: Liquid
DRIVE TRAIN
Transmission/Final Drive: Automatic PVT P/R/N/L/H; Shaft
Drive System: On-Demand True AWD/2WD
Engine Braking System/Active Descent Control: Available on Limited Edition
SUSPENSION
Front Suspension: Dual A-Arm with Anti-Sway Bar 9" (22.9 cm) Travel
Rear Suspension: Dual A-Arm, Anti-Sway Bar 9.5" (24 cm) Travel
BRAKES
Front/Rear Brakes: 4-Wheel Hydraulic Disc with Dual-Bore Front Calipers
Parking Brake: Park in Transmission
TIRES AND WHEELS
Front Tires: 25 x 8-12; Ancla
Rear Tires: 25 x 10-12; Ancla
Wheels: Stamped Steel
DIMENSIONS/CAPACITIES
Wheelbase: 77" (196 cm)
Dry Weight: 970 lb (440 kg)
Overall Vehicle Size (L x W x H): 107.5 x 50 x 69 (273 x 127 x 175.2 cm)
Ground Clearance: 10" (25 cm)
Seat Height: N.A.
Fuel Capacity: 7.25 gal (27.4 L)
Bed Box Dimensions (L x W x H): 20 x 40 x 9 (51 x 102 x 23 cm)
Front/Rear Rack Box Capacity: N.A./300 lb (136.1 kg)
Payload Capacity: 740 lb (335.6 kg)
Hitch Towing Rating: 1,500 lb (680.4 kg)
Unbraked Trailer Towing Capacity: N.A.
Hitch/Type: Standard/1.25" Receiver
FEATURES
Cargo System: Lock & Ride
Lighting: Halogen, 50W
Electronic Power Steering: Available on Limited Edition
Instrumentation: Digital Gauge, Speedometer, Odometer, Tachometer, Tripmeter, Hour Meter, Clock, Gear Indicator, Fuel Gauge, Hi-Temp/Low-Batt Lights, DC Outlet
COLORS
Colors:"Indy Red
Other colors on L.E.s
4Nines is offline   Reply With Quote
Old July 30th, 2012, 09:05 PM   #2
“Super Genius”
zrated's Avatar
First Name: John Galt
My RZR: 2014 RZR XP41K Boondocker Turbo
Member #1606
View zrated's Photo Gallery(0)
Re: 2013 Polaris RZR 570 Specs
So... What's different?
zrated is offline   Reply With Quote
Old July 30th, 2012, 09:36 PM   #3
Mojeeper's Avatar
My RZR: 2011 800S
Member #40696
View Mojeeper's Photo Gallery(0)
Turf mode! That makes me want one...
Mojeeper is offline   Reply With Quote
Old July 30th, 2012, 09:47 PM   #4
sjf323's Avatar
Member #2328
View sjf323's Photo Gallery(0)
Versatrack Turf Mode what exactly is this. They also added it to the xp 900.
sjf323 is offline   Reply With Quote
Old July 30th, 2012, 09:58 PM   #5
Mojeeper's Avatar
My RZR: 2011 800S
Member #40696
Limited slip rear end.. Instead of the spool that in them now.
You'll be able to turn shorter now without tearing up the grass. Moreless..
Old July 31st, 2012, 12:19 AM   #6
soapy's Avatar
My RZR: 2017 rzr 1000S
Member #24680
View soapy's Photo Gallery(2)
Looks like the price will be $11,999 for the LE. $2000 more for power steering, electric braking assit and turf mode plus graphics. It also adds glove box and high/low beam headlights. Good deal for the added stuff I guess if it is things you will use. FOr the extra 2 K I think I would get Fox shocks, aftermarket power steering and put it on the regular 570.
soapy is offline   Reply With Quote
Old July 31st, 2012, 08:57 AM   #7
B-Ray's Avatar
First Name: BR
My RZR: Polaris
Member #30355
View B-Ray's Photo Gallery(0)
The Engine Braking System/Active Descent Control is what I like. Power steering is not needed in my opinion.
B-Ray is offline   Reply With Quote
Old July 31st, 2012, 09:24 AM   #8
olddognewtrick's Avatar
First Name: Jim
Member #18785
Very, very interesting. Like the whole idea of it, not hot on black, but the graphics are nice.
Throw on some after market aluminum rims and some 26" bighorns and a descent skid system and it should be good to go.
And, I will never buy another one of these without EPS, it is impossible to really know the difference unless you experience it.
2011 Pursuit Camo
olddognewtrick is offline   Reply With Quote
Old July 31st, 2012, 01:56 PM   #9
Robb's Avatar
My RZR: 2015 RZR XP 4 1000
Member #30785
View Robb's Photo Gallery(0)
Thumbs up Re: 2013 Polaris RZR 570 Specs
Agreed !
2011 RZR-4 RG LE EPS :RIP 09/2014
2012 RZR 800 LE EPS w / Walker Evans :SOLD
2015 RZR XP 4 1000
Robb is offline   Reply With Quote
Old July 31st, 2012, 02:23 PM   #10
jazz53's Avatar
Member #37464
View jazz53's Photo Gallery(0)
Did they move to a wet sump same as the 900?
I also thought I read somewhere it now has Hi/Low beam and glovebox?
Does Engine braking mean different clutch?
jazz53 is offline   Reply With Quote
Old July 31st, 2012, 03:16 PM   #11
GIXXERGUY6's Avatar
First Name: Ron
Member #6010
View GIXXERGUY6's Photo Gallery(0)
This is a limited slip diff or an unlocking diff?I see having issues with the non live axle in the back...IMO
GIXXERGUY6 is offline   Reply With Quote
Old July 31st, 2012, 08:30 PM   #12
Banshee84's Avatar
First Name: Andy
My RZR: RZR S
Member #7051
View Banshee84's Photo Gallery(7)
Very nice machine. $12,000 over priced!
Banshee84 is offline   Reply With Quote
Old July 31st, 2012, 09:16 PM   #13
Mojeeper's Avatar
My RZR: 2011 800S
Member #40696
I think it's an unlocking diff.. Rangers have had them for years.
Old August 1st, 2012, 05:32 AM   #14
dinolord's Avatar
Member #42073
View dinolord's Photo Gallery(0)
Correct. Unlocking rear diff. Works very well on the ranger.
LMM Duramax(FS). Mach 1(FS). 2 Arctic Cat projects. RZR 570.
dinolord is offline   Reply With Quote
Old August 1st, 2012, 09:55 PM   #15
B256's Avatar
Member #43165
View B256's Photo Gallery(0)
Hi, I am a bit new to side x sides. The new RZR 570 LE on the polaris web site says that it has EPS,EBS, versatrack and I think poeople on this site have said that the new 570 LE has the better seat belt, high / low head light beam. What I was wondering is that on the photos it also looks like it also has different shocks and wheels, if it does different shocks and wheels does anyone have any info on this? Thanks
B256 is offline   Reply With Quote
13 rzr 570 specs
2013 polaris 570 rzr specs
2013 polaris razor 570 hp
2013 polaris rzr 570
2013 polaris rzr 570 horsepower
2013 polaris rzr 570 specs
2013 polaris rzr s 570 specification
2013 polaris rzr specifications
2013 polaris rzr specs
2013 rzr 570 specs
gfuel guage not working on 2013 rzr 570
polaris 2013 rzr 570 specs
polaris rzr 570 ebs or not?
specs for polaris rzr 570 2013
what is front and rear gear ratio 2013 rzr 570 le
Polaris RANGER MRZR™ 2 Specs 4Nines Polaris Defense Vehicles 12 October 29th, 2012 06:29 PM
2013 polaris victory line up video FJK General RZR Discussion 3 August 2nd, 2012 03:46 AM
What would you like to see polaris do in 2013? onebadyj General RZR Discussion 54 June 20th, 2012 08:43 PM
Polaris RANGER MRZR™ 4 Specs 4Nines Polaris Defense Vehicles 2 May 25th, 2012 11:12 AM
Totally Custom 2008 Polaris RZR "S" Specs But Much Better For Sale snowmantoo Polaris RZR Parts For Sale 1 January 30th, 2010 09:40 AM
