Polaris Introduces Revolutionary New Single Seat Off-Road Vehicle - The Sportsman ACE
47K views 192 replies 110 participants last post by  rkymtm
Sportsman® ACE is Confidence-Inspiring and Fun to Ride
Minneapolis, January 22, 2014- Polaris® Industries Inc. (NYSE: PII), the leading manufacturer of off-road vehicles, today announced the company is defining an entirely-new type of off-road vehicle with the introduction of the Sportsman® ACE. The vehicle’s architecture is completely new to the industry and features a revolutionary, sit-in chassis that is nimble and comfortable to operate. The design of the new Sportsman ACE provides a confidence-inspired ride, all while being trail-capable, offering an all-new off-road experience.
“The introduction of the Sportsman ACE is part of our strategy to remain the leader in the powersports marketplace by introducing innovative products that define their categories,” said David Longren, vice president of Polaris’ Off-Road Division. “In creating the Sportsman ACE, we wanted to not only appeal to current off-road enthusiasts, but develop a vehicle that brings new customers to off-road recreation. We accomplished this by coupling an easy-to-use, nimble platform with a confident and secure ride that, together, provides drivers of all experience levels a new way to experience the outdoors.”
The revolutionary, new design combines the size and nimble handling of the Sportsman All-Terrain Vehicle (ATV), and the confidence and comfort of the RANGER and RZR side-by-sides, in a rider-centric design with a trail-capable and easily-transportable 48 in/121.9 cm width. A comfortable and confidence-inspiring centralized seating position connects the driver directly with the machine for a new off-road riding experience. To ensure a low center of gravity, Polaris positioned all the major components, including the driver, centralized between the four wheels for an incredibly responsive ride. Along with this low center of gravity, the Sportsman ACE boasts 10.25 in/26.04 cm of ground clearance and 9.5 in/24.1 cm of rear travel due to its fully independent rear suspension (IRS) outfitted with performance, twin tube shocks featuring adjustable preload. Seasoned riders will appreciate the overall vehicle performance, handling and smooth riding suspension, while novice riders will enjoy the secure riding position and the right amount of power to get them down the trail.
Powering the Sportsman ACE is an all-new 32 horsepower ProStarTM Electronic Fuel Injected (EFI) Engine featuring an internal counter-balance shaft for smooth, vibration-free power. The dual overhead camshafts and a 4-valve cylinder head work with the advanced engine management system to precisely deliver the fuel charge for impressive power and instant, predictable throttle response; while the lightweight efficient transmission captures every ounce of power to deliver it to the ground. The engine is designed to reduce internal friction which dramatically reduces noise and significantly increases efficiency making it the most fuel-efficient engine Polaris has offered. This coupled with the 5.25 gal/19.87 liter fuel tank provides the vehicle with excellent range for long trail rides.
For a confidence-inspiring and comfortable ride, the Sportsman ACE has a unique ROPS cab frame to deliver peace of mind only previously found on side-by-sides. The secure, high-backed, adjustable bucket seat is paired with an adjustable steering wheel to give the driver unmatched flexibility when it comes to comfort in the machine. It’s also equipped with a 3-point seat belt, and has side bolsters to keep the operator properly positioned in the center of the machine. The steering wheel offers 3.5 in/8.9 cm of tilt adjustment and the driver’s seat slides back and forth by 4 in/10.2 cm to customize the fit for the rider. For added comfort, an integrated dead pedal gives the driver a place to perch their left foot while the right nests in the integrated heel pocket and throttles the powerful ProStar engine. The cockpit’s flow-through design also makes ingress and egress easy, and new side nets feature a metal rod to easily secure them both for clipping and positioning the nets to the back of the vehicle while exiting. The vehicle also is equipped with powerful halogen lighting so the fun doesn’t stop when the sun goes down.
For the utmost confidence on the trail, the Sportsman ACE is equipped with the same legendary On-Demand True All-Wheel Drive (AWD) system found on all Polaris Off-Road Vehicles. The system eliminates the guesswork by automatically engaging when the rider needs more forward traction and then reverts back to two-wheel drive automatically when the AWD is no longer needed. While zipping down the trail, the driver also has assured stopping power from the linked, four-wheel disc brakes with braided stainless steel brake lines that provide optimum response and minimal fade.
For added protection on the trail, accessories such as doors, front and rear brushguards, rock sliders, and a variety of custom wheel and tire packages not only protect the vehicle but add a more customized look. To protect the driver from the elements, a Lock & Ride roof, windshield and rear panel install in seconds to offer a quick solution for all climates.
Polaris off-road vehicles have built an unprecedented reputation for helping owners get work done and the storage capability of the new Sportsman ACE is no different. With an integrated 2.8 gal/10.6 liter semi-dry, front storage compartment, and a high-capacity Lock & Ride® cargo box with rack extenders and rear tie-down rails, that also accepts the accessory Lock & Ride cargo box for additional dry storage, the vehicle can carry up to 575 lb/260 kg of gear. The Sportsman ACE is pre-wired for the installation of a winch with up to 3,500 lb/1587 kg of capacity, and the hardest-working DNA of Sportsman was further instilled with a 1,500 lb/680 kg towing capacity, for capability whether it’s time to work or play.
Polaris will also offer more than 25 accessories for Sportsman ACE including doors, winches, cabs and storage to suit their needs. The Sportsman ACE is available in White Lightning and will be in dealerships in February - US MSRP $7,499
See more photos and information over at ACEforums.net
Photo thread: http://www.aceforums.net/forum/10-a...ace-single-seat-atv-photo-gallery.html#post11
See less See more
1
#15 ·
Re: Polaris Introduces Revolutionary New Single Seat Off-Road Vehicle - The Sportsman
Custom Package Options For Your Ultimate Riding Experience
Ultimate Trail Comfort
You will never want to step out of your machine with these Polaris® Engineered comfort-focused accessories. Cab-like components shield you from the elements while audio and mirrors give your ride a fun, premium feel.
2879703 MTX® Overhead Audio Pod - $599.99
2879694 Lock & Ride® Mid Poly Windshield - $129.99
2879704 OGIO® Lock & Ride® 3-Piece Deluxe Cargo Bag 2879691 Lock & Ride® Poly Sport Roof - $229.99
2879705 Trail Bag - $69.99
2879708 Polaris® HD 2500 LB. Winch - $399.99
*SPORTSMAN ACETM Sport Doors *SPORTSMAN ACETM Sport Doors will be available March 2014
Ultimate Storage
Create the perfect storage combination with a full line of accessories for you to stow away all of your personal belongings whether you are riding for a few hours or taking a weekend trip.
2879691 Lock & Ride® Poly Sport Roof - $199.99
2879698 Extreme Front Brushguard - $229.99
2879699 Extreme Rear Brushguard - $149.99
2879704 OGIO® Lock & Ride® 3-Piece Deluxe Cargo Bag - $229.99
2879706 Overhead Storage Bag - $59.99
2879712 Rear View Mirror - $59.99
Ultimate Protection
Ride as hard as you want, wherever you want and still keep your machine safe from off-rad hazards with Polaris’ Engineered protection accessories.
2879696 Lock & Ride® Poly Rear Panel - $179.99
2879693 Lock & Ride® Full Poly Windshield - $279.99
2879870 UHMW Front A-Arm Guards - $149.99
2879710 UHMW Trailing Arm Guards - $149.99
2879700 SPORTSMAN ACETM Nerf Bars - $199.99
ADDITIONAL SPORTSMAN ACE ACCESSORIES
2879709 Polaris® HD 3500 Lb. Winch - $529.99
2879630 Glacier Pro® Plow Frame - $249.99
2880056 Trailerable Cover - $219.99
2879787 11” LED Light Bar - $599.99
Womp womp woooomp
Sent from my XT1080 using Tapatalk
#20 ·
It should be less tippy than a quad considering the riders weight is down low... Good thinking Polaris, me and all my friends have all rolled our ATVs and been hurt. I wonder how long it will take before they work on a S version, with a wider stance and longer travel and a little more hp?
#22 ·
That thing is ugly... I don't get how they have a quad with an 89HP engine and no roll cage but they put a 32HP engine in the same type of concept with a roll cage.....
#24 ·
meh, kind of a disappointment. i'm sure the engine is fast enough for something that size but it just looks fugly. maybe i'm missing the point but why make a single seat utility quad? aren't they single seat to begin with? (okay i know its a seat that you sit in versus one that you straddle)
I was really hoping for something like the Honda Odyssey or that Riot machine but with 4 wheel drive and the Prostar 570 engine. Put 10" to 12" of travel, a lower siting position, and 4 wheel drive and you'd have a fun machine.
#26 ·
My concern is not enough power for the sand. Plenty for trail riding, but maybe underpowered for the sand. Why oh why did they not give it about twice the power, closer to what the Sportsman has.
This is the beginning of a whole new category! It has to start somewhere and it's going to be a blast to modify! It's a LOT more stable than you think it would be and it's super fun to drive. VERY easy to get in and out of and very comfortable. Full review coming shortly.
#122 ·
I have to agree with this guy it's the start of something new you don't see anyone else putting there nut's out there do ya ? I think it show's a sign of things to come myself
