Go Back   RZR Forums.net - Polaris RZR Forums, Events, Discussion, Classifieds, and More! > Members > Members Rides
Members Rides Post pictures, or a description of your RZR here
Transformation
Old August 25th, 2008, 03:04 PM
Iron Mike's Avatar
Iron Mike Iron Mike is offline
My RZR: 2008 RZR
Transformation
Here are some before and after pics of my RZR during the lifting process. I also installed snorkles while I had the bike apart. I have a few more mods planned and will update as I go along. The bucket gives a reference for the change in height.
Last edited by Iron Mike : August 25th, 2008 at 03:12 PM. Reason: Pics not loading
Re: Transformation
Old August 27th, 2008, 06:20 PM
ret25yo ret25yo is offline
Re: Transformation
are planning spacers or anything to widen it out for safety reasons?
Re: Transformation
Old August 27th, 2008, 08:10 PM
08800rzr's Avatar
08800rzr 08800rzr is offline
First Name: joe
My RZR: 08 green
Re: Transformation
looks good big difference
Re: Transformation
Old August 28th, 2008, 05:30 AM
Iron Mike's Avatar
My RZR: 2008 RZR
Re: Transformation
Yes. I tried 1" in the front and the inner lug of the tires still hit the lower sway bar joint on both sides @ full turn so I have ordered 2" for the front and I will move the 1" to the rear.
08' RZR, 29.5x10x12 Swamp Lites all around, 3" Extreme Lift, 3" lower lift, Rock Sliders, Brush Guards front & back, 4,000 lb Warn Wench, Dual Gun scabbards, extra lights up front and on top for those night rides & STK Motorsports Snorkels.
Re: Transformation
Old August 28th, 2008, 07:26 AM
DCRZR's Avatar
DCRZR DCRZR is offline
RZR NOOB
First Name: Blair
My RZR: 08 RZR
Send a message via MSN to DCRZR
Re: Transformation
nice ride. Whats the over all hieght?
Re: Transformation
Old August 28th, 2008, 01:39 PM
Re: Transformation
sounds goods keep us updated with pics
Re: Transformation
Old August 29th, 2008, 06:53 AM
Iron Mike's Avatar
My RZR: 2008 RZR
Re: Transformation
Just under 6'-8" to the top of the lights. 6'-1 1/2" to top of the roll cage at the rear loop. Depending on which trails we are riding and the clearance, I just loosen the light bar clamps and roll the whole assembly down to get it out of the way.
Re: Transformation
Old October 13th, 2008, 05:03 PM
greene RZR greene RZR is offline
Re: Transformation
Do you have any stability issues with cornering. Or any other problems. Looks great !!! I am going to get some sort of lift because of the trail I take through the woods to the hunting camp is nothing but rocks scraping under the bottom of the rzr hope fully this will help.
Re: Transformation
Old October 13th, 2008, 07:47 PM
bizkitbroke's Avatar
bizkitbroke bizkitbroke is offline
Re: Transformation
What lift did you get?
Re: Transformation
  #10 (permalink)
Old October 13th, 2008, 09:25 PM
Cordachine's Avatar
Cordachine Cordachine is offline
Look'n 4 da deep stuff!
First Name: Don
My RZR: Red 08 Gen III
Re: Transformation
I am also curious about this lift. Who and How high?
08 Popo RZR and 02 Sportsman X 500 HO (mudder) (dead)
RZR mods: 30" Mudzillas on 14" SS108, 3000lb Winch, K&N Air Filter, 3" Xtreme Lift Kit, HL springs, Custom snorkle, Deluxe front and rear bumpers, Rock slider nerf bars, Sport roof, FMF pipe, 1 1/2" Wheel spacers!
Re: Transformation
  #11 (permalink)
Old October 14th, 2008, 06:10 AM
Iron Mike's Avatar
My RZR: 2008 RZR
Re: Transformation
It is different but I think that is caused more by the tall sidewall and low air pressure (8 lbs) of the tires vs. the actual lift kit itself. After riding a few times I got used to the way it handles and I am not experiencing any problems. I do have to admit that the fear of tipping is still there though.
Re: Transformation
  #12 (permalink)
Old October 14th, 2008, 06:13 AM
Iron Mike's Avatar
My RZR: 2008 RZR
Re: Transformation
Extreme 3" on the top and 3" spacers on the bottom. Check out the Lift Kits forum and I have some pics posted there showing the components.
Re: Transformation
  #13 (permalink)
Old October 14th, 2008, 06:16 AM
Iron Mike's Avatar
My RZR: 2008 RZR
Re: Transformation
Hi Don, like you I have the Extreme 3" and I also added 3" spacers @ the bottom of the shocks for a total of 6". So far it has worked great and it cured my clearance problems where we ride.
Re: Transformation
  #14 (permalink)
Old October 14th, 2008, 02:58 PM
Cordachine's Avatar
First Name: Don
Re: Transformation
Where did you get the spacers and how much angle does it put on your joints?
Re: Transformation
  #15 (permalink)
Old October 14th, 2008, 03:35 PM
Iron Mike's Avatar
My RZR: 2008 RZR
Re: Transformation
I bought them on Ebay, they look like an upside down pyramid and have an extra hole to relocate to lower connection point of the sway bar in the front. The CV joints are pretty well bent out of shape. I'm sure that it is just a matter of time before one lets go and then I will upgrade them all to heavy duty like Gorilla or something compairable. Until then, I just do not go too hard on the throttle and so far no problems. It still moves really good on the flats and I have had it in deep mud, water over the hood (by accident) and I can still climb over downed trees, rocks and the like. I just don't hammer it too hard, instead I just let the bike work for itself.
Remember to add spacers depending on your tire height. I have 2" in the front and I went ahead and put 1 1/2" on the back. The rears were not needed but I had them and figured the added stability would come in handy since my son drives it on occasion.
I hope this helps you out.
Mike
