This is a discussion on RZR Replacement Tie Rods / Rack ends now available! within the LoneStar Racing forums, part of the Supporting Vendors category; Have you bent the weak hollow Tie Rod on your RZR?? If so, you have probably found out that to replace it, you need to ...
LoneStar Racing
LoneStar Racing - Mesa, AZ - 800-457-7223 |
If so, you have probably found out that to replace it, you need to purchase the whole rack and pinion in order to fix it. Well, we have a great solution for you! Our new replacement tie rod installs just like the OEM version, but its made from solid forged steel, and features a larger diameter pivot ball for longer life. Fully compatable with all long travel kits, and we also have a +8 version for the guys running our XTR kit, that doesn't require any extensions. We have plenty in stock ready for shipping, and they normally sell for $45 each, but you can take 10% off since your forum members. They also make a great trail spare, because they can be replaced on the trail with a couple tools in minutes to get you back on the trail!
Lone Star Racing forum members coupon code for 10% off : utvforum10 www.lsracing.com |
| Sponsored Links | ||
Re: RZR Replacement Tie Rods / Rack ends now available!
10% off for forum members.. $40.50 each!
Thats a great deal!!!!
+4 tie rods would be a one piece unit, correct???
No.. We have 2 versions. The OEM length, and the +8 length. For them to be the correct length for a +4 kit, you would still need to use the extenders that came with your long travel kit, or we can supply you with the +4 extenders that we make. They would have to be threaded together. But our tie rod is made from solid forged steel, instead of the thin tubing and crimped connections the stock tie rods have. So they are a lot stronger. G- Last edited by LSRGreg; July 10th, 2009 at 04:52 PM. |
G-
#9
Not specifically. But you could use ours, and get a +5 extender from someone that makes +5 Long travel kits, and it would work.
G-
#10
LSR Greg you still have any of these in stock, PM me i am in need of one and if i am gonna change one side i might as well change them both.
#11
PM sent!
#12
so i place my order @ 8:00am monday morning, and i'm not supposed to received shipment till sat,,,, hhhmmm ssssssssssllllllloooooooowwwwww ass frikin shipment, hope you arent ordering these parts and need them in a hurry.
#14
Don't think you could beat these that LSR is selling. I got some like these for 55 bucks each and still had to turn one of them down on the ball end to get full steer into the steering rack. If you think their too expensive call your dealer(while sitting)!
#15
Hey Farmerkirkie, are you talking about the tie rods or the tie rod ends for $55.00? I'm ordering the LSR tie rods but had to buy 2 new tie rods ends ($43.25 each from the Polaris dealer). Thought that was a little steep.
| Search tags for this page |
2011 polaris rzr s tie rod end,2011 polaris rzrs rack and pinion,2011 polaris tie rod end 800,how to change a rzr tie rod,lonestar racing tie rods for polaris rzr,polaris rzr lonestar tie rods,polaris rzr single tie rod replacement,polaris rzr stock tie rod,polaris rzr tie rod,replacement rack and pinion for polaris rzr,replacement tie rods,rzr 5 tie rods,rzr rack and pinion replacement instructions,rzr rack ends,rzr tie rod end replacement,rzr tie rod ends replacement,rzr tie rod replacement,rzr tierod install,what is the rzr tie rod stock length,whats the best tie rod ends for polaris rzr s
| Thread Tools | |
| Display Modes | |
| Tie rod ends? | jerrzr | General RZR Discussion | 1 | February 28th, 2009 10:06 AM |
| Long travel tie rods ends above or under | Shelton@wp.pl | Suspension | 4 | November 29th, 2008 07:22 PM |
| Replacement Tie Rods | BigSilly450X | General RZR Discussion | 0 | October 21st, 2008 10:31 PM |
| Top Ends | utvatv800 | Engine and Drivetrain | 3 | August 17th, 2008 05:51 PM |
| GEAR ONE STEERING RACK W/HEIMS on TIE RODS | BIG ISLAND KART SHOP | Suspension | 6 | March 14th, 2008 09:45 PM |
