Amp and speaker hook up - Polaris RZR Forum - RZR Forums.net
This is a discussion on Amp and speaker hook up within the Lighting, Stereo and Electrical forums, part of the Technical category; Hey I'm on a budget and just recently purchased the *Pyle PLMRMP3A 4 Channel Waterproof MP3/ Ipod Marine Power Amplifier along with the Pyle wakeboard ...
Old July 16th, 2012, 05:46 AM   #1
court31rzr's Avatar
Member #32221
View court31rzr's Photo Gallery(2)
Hey I'm on a budget and just recently purchased the *Pyle PLMRMP3A 4 Channel Waterproof MP3/ Ipod Marine Power Amplifier along with the Pyle wakeboard speakers i got the set for 180$ shipped to Canada and i am wondering what is the best way to mount the amp I was thinking of just making an overhead box to mount the amp but I'm open to suggestions
court31rzr is offline   Reply With Quote
Old July 16th, 2012, 09:15 AM   #2
Magicmantx's Avatar
First Name: Bruce
My RZR: 2016 Graphite XPT
Member #20584
Re: Amp and speaker hook up
I have the same amp and speakers. I mounted my amp under the hood. its been wet a couple of time and no problem . Mounted the speakers on a bar in the rear that I added.
:TX
Brunomspts@yahoo.com
Magicmantx is offline   Reply With Quote
Old July 16th, 2012, 09:31 AM   #3
court31rzr's Avatar
Member #32221
was it hard to mount did it need any extra hardware? also how do u go about wiring it to the battery, does it still run when your bike is shutoff meaning it would drain the battery im not very good in electrical haha
Old July 16th, 2012, 11:09 AM   #4
Schultz77's Avatar
Member #30987
View Schultz77's Photo Gallery(0)
You can also mount it under the dash against the "firewall". I installed two of those amps recently, and both turned out very clean.
You will need to run your power wire directly to the battery, and run the remote wire either to a switch or the key.
Schultz77 is offline   Reply With Quote
Old July 16th, 2012, 11:16 AM   #5
Magicmantx's Avatar
First Name: Bruce
Member #20584
I added afuse block wired directly to the battery so I could add additional stuff. Switched from that with additional battery and battery isolator so I can run my stereo all I want without worrying about not being able to start.
:TX
Old July 25th, 2012, 08:00 PM   #6
eerfanwv's Avatar
First Name: Jon
My RZR: 2012 RZR S LE Black White Red
Member #36924
View eerfanwv's Photo Gallery(0)
i bought the 2 speaker and amp setup. I mounted the speakers in 6'' pvc pipe endcaps, cut out the end that was not open so i could have a big enough lip to mount the speakers in. Sealed the back of the speakers with plexiglass. bought a 2nd battery and only hooked the amp/speakers to it and nothing else. (so far). it is a wheelchair gel style battery>went on a ride sunday, a lil over 8 hrs and had the speakers on the whole time, no problems< just got to put the trickle charger on her when you get home. i wired the 2nd battery to a switch so i could turn it off and on as needed. my amp is under my hood, ran wires thru firewall to 2nd battery. combined the wires in that plastic heat shield stuff and tucked them away. the speakers are mounted in the corners of the back roll bar which put the speakers at the left side of the drivers head and the right side of the passengers head.. anyways, this is just my home made project that surprisingly works very well!!
eerfanwv is offline   Reply With Quote
Old July 25th, 2012, 08:17 PM   #7
Racer61's Avatar
Member #29049
View Racer61's Photo Gallery(0)
I have a similar amp. I took a piece of black aluminum and made a tray above my head at the front of the cage and the amp sits on top. The volume control, the ipod jack and a power switch (I added) are all mounted in it. It gets plenty of air and stays dry since its right under the roof. Hope this helps.
2011 Razor XP Triangle ATV Snorkit, Superwinch, PoPo roof and brush guard, 30" Silverbacks on 14" Nukes, 4" SuperATV lift, Looney tuned exhaust.
Racer61 is offline   Reply With Quote
Old July 25th, 2012, 08:30 PM   #8
Teamnipplesdeep's Avatar
First Name: Blake
Member #37593
View Teamnipplesdeep's Photo Gallery(0)
How's this setup sound? I'm looking at basically the same thing but the 2 channel amp instead of the 4
Teamnipplesdeep is offline   Reply With Quote
Old July 25th, 2012, 08:33 PM   #9
Racer61's Avatar
Member #29049
Ive got the 4 channel and 8" bazookas mounted on the rear cage. It sounds pretty effin cool but I am disappointed in the amp. It will never produce the output it claims. It was cheap so I guess I get what I pay for. It makes plenty of noise to tick off the neighbors though. lol!!!
Old July 25th, 2012, 08:41 PM   #10
First Name: Blake
Member #37593
Good deal I was wondering what would be better the 6.5" or the 8" speakers. I guess the 8" bigger is better right? lol
Old August 10th, 2013, 01:32 PM   #11
snoopy496's Avatar
Member #59160
View snoopy496's Photo Gallery(0)
Hi Guys
Sorry to jump in on this but am desperately needing help
Just bought a Pyle PLMRMP3A kit includes speakers etc. Also got the Pyle PLCD36MRW head unit.
Head unit and speakers work ok but when I turn the volume up to 40 it switches itself off.
Then I connected the amp but when I connect the blue wire from thee amp to the blue wire from the head unit then the head unit switches off and comes back on, pulsating (flashing off and on). When I disconnect the blue wires the head unit plays but the amp is not on.
I have tried the blue wire connected to a switch and the live battery terminal and the amp still doesn't work.
Apart from taking a hammer to it can anybody help me, been at this for over a week.
snoopy496 is offline   Reply With Quote
best way to wire a amp and speakers in a rzr
four wire power to stereo hook up
how to hook speakers to rzr
how to hook up plmrmp3a amp
how to hook up pyle amp
how to hookup a bluetooth audio to a rzr
how to hookup a polaris 2012 rzr ipod
how to wire a amp and ipod wire in a polaris rzr
how to wire a stereo and amp in a rzr
how towire a amp up to a polaris ranger
plmrmp3a volume control
pyle plmrmp3a review
pyle plmrmp3a wiring
rzr amp and ipod hook up
wiring amp and speakers in rzr
Got Tow Hook? justinator General RZR Discussion 17 June 19th, 2011 08:41 PM
Front tow hook 19dan58 General RZR Discussion 12 November 2nd, 2010 02:13 PM
Where do you hook up to on the front? spencerfuse General RZR Discussion 9 September 18th, 2010 08:56 AM
Where can you hook on a tow rope? clemson726 RZR-S Specific Discussion 3 December 28th, 2009 01:23 PM
Double tow hook Johnpeq General RZR Discussion 11 March 4th, 2009 08:41 PM
