turn signal kit - Polaris RZR Forum - RZR Forums.net
turn signal kit
This is a discussion on turn signal kit within the Lighting, Stereo and Electrical forums, part of the Technical category; looking for good led kit want to keep factory rear lights and insert blinker bulb in it also any input thanks...
Old May 8th, 2012, 11:11 AM   #1
greged's Avatar
Member #39983
View greged's Photo Gallery(0)
turn signal kit
greged is offline   Reply With Quote
Old September 13th, 2012, 03:44 PM   #2
bow_hunt's Avatar
Member #44898
View bow_hunt's Photo Gallery(0)
Re: turn signal kit
I want to do the same... I would think someone could give some suggestions for a street legal kit or blinker kit? I think a toggle switch would be better than a stick sticking out from the steering column
bow_hunt is offline   Reply With Quote
Old September 13th, 2012, 04:14 PM   #3
utrzrdog's Avatar
My RZR: 2015 RZR 900 XC
Member #32138
View utrzrdog's Photo Gallery(0)
Re: turn signal kit
Polaris
Here is a great place to get a kit. Not cheap but a simple and clean install.
utrzrdog is offline   Reply With Quote
Old September 13th, 2012, 04:17 PM   #4
Clayton4971's Avatar
First Name: Carl
My RZR: 2012 S LE
Member #36446
View Clayton4971's Photo Gallery(0)
I got mine from Ryco Motor Sports excellent quality very bright and easy to install. If I had to do it again I would buy the same thing again . I wanted a couple extra LEDs later called and no problem . I actually think they are better than some cars on the road . Had them installed about four months now.
Clayton4971 is offline   Reply With Quote
Old September 13th, 2012, 04:30 PM   #5
bow_hunt's Avatar
Member #44898
Re: turn signal kit
I just pulled up the link shown above and it just send me to a website with 'We have the following kits available for your Polaris ATV and UTV' but it does not list what I am going to get or show any pictures for examples
// anyone else have any suggestions for a turn signal kit? Or street legal kit. I see a few on ebay
Old September 13th, 2012, 04:35 PM   #6
First Name: Carl
My RZR: 2012 S LE
Member #36446
When you go to the link that Scott posted then click on the Polaris and it will give you the info for the kit . It's the same one I got not cheap but you get what you pay for.
Old September 13th, 2012, 04:42 PM   #7
bow_hunt's Avatar
Member #44898
Re: turn signal kit
Oh, you actually have to click on the 'RZR all years' then it brings it up. It is a 'street legal kit' not just a blinker kit. Yeah a little expensive but not to bad as long as the quality is there. // Anyone else have any other suggestions.
Old September 13th, 2012, 04:53 PM   #8
utrzrdog's Avatar
Member #32138
Re: turn signal kit
I have used others and this is by far the best and cleanest install. Remember you get what you pay for.
Old September 14th, 2012, 07:37 AM   #9
greged's Avatar
Member #39983
Re: turn signal kit
vics light kits
Old September 14th, 2012, 08:07 AM   #10
Doolin2's Avatar
Member #31195
View Doolin2's Photo Gallery(0)
Re: turn signal kit
Not exactly what your looking for,but I have the small LED kit on my 800 50" and love it.
Also this site has a ton of info on it.
EZ Turn Signal Kit Polaris Ranger XP HD RZR Crew Diesel, Yamaha Rhino, Can-Am Commander, Honda Big Red MUV, Kawasaki Mule Teryx, Arctic Cat Prowler WildCat, any side-by-side UTV
Doug
Doolin2 is offline   Reply With Quote
Old October 3rd, 2012, 01:44 AM   #11
shaver's Avatar
My RZR: 09 razor camo
Member #13500
View shaver's Photo Gallery(0)
Re: turn signal kit
alright, but is there a kit that also has hazard switch, for dusty trail riding?
shaver is offline   Reply With Quote
Old October 3rd, 2012, 05:05 AM   #12
Doolin2's Avatar
Member #31195
Re: turn signal kit
click the link and scroll down to see them working.
You will see the hazards working and a picture of the switch.
http://www.eztsk.com/SMLEDTurnSignalKit.html
Doug
Old October 4th, 2012, 02:04 AM   #13
shaver's Avatar
Member #13500
Re: turn signal kit
Nice. Thank you. When i"m ready i"ll get this set up...
Old July 25th, 2016, 05:39 PM   #14
knoweigh's Avatar
Member #104337
View knoweigh's Photo Gallery(0)
Re: turn signal kit
Old thread I realize however, I went with a full LED kit entirely seperate from factory lights. A couple thoughts on why I went the route I did:
1. while it is possible to rig up the factory lights to do what we need, it can be complex (even for an experienced 12v guru like me)
2. unless there's a significant mounting issue, I prefer to have my turn signals completely seperate from my tail lights. Having them seperate gives me more redundancy in terms of lighting on the machine.
As I couldn't find exactly what I was after, (at least for under $200) I set out on a journey to build what I wanted.
Being in the 12v RV and Marine industry for years, I have access to many 12v goodies.
I ended up designing the full system which you'll see below with a couple switch options.
I prefer the column mounted design as it is far easier to actually use. (I also made a toggle switch kit, and have the rocker switches available too which is what I did in my toyota buggy)
Having used all 3 switches, the column mounted unit is by FAR my favorite. And not just any column mounted switch......there are ridiculous plastic type column switches all over the internet that are just plain trash IMHO. The plastic brackets can and do easily brake right off when bumped. I sourced a full metal body switch. The thing is incredibly tough. Case and bracket and lever/stick are metal. No trash, this thing is stout! And to top it off, it has an indicator on the end of it (which I converted to LED) that flashes to indicate you have a signal on.
Anyhow, that's the route I went and I'm extremely pleased with it. For the money, you can't go wrong. Some kits out there with a column switch like this are more than twice the amount and the switch isn't near as robust. Should fit polaris RZR and Ranger general, can am commander maverick and about any other side by side or UTV where you have enough realistate to drill a 3/4" hole to mount the LED's. And if you're afraid of drilling into your plastic....don't be. See pics below from an install. Looks factory IMHO. Clean and neat.
MCS Adventures - Turn Signal Kits
ID:	291497   Click image for larger version
ID:	291513   Click image for larger version
ID:	291521   Click image for larger version
12' xp900 SA fr +Arms & Rear radius rods, SATV HD tie rod kit, ws ultra 10, kenwood amp, kenwood 10" box in bed, 1k seats, 1k rubber on 14" hiper sw dbl BL front Single BL rear
knoweigh is offline   Reply With Quote
Old July 31st, 2016, 06:53 PM   #15
TN8ball's Avatar
First Name: Drew
My RZR: 2016 RZR 4 900
Member #110209
View TN8ball's Photo Gallery(0)
Re: turn signal kit
Nice kit and great price! Does that light on end of stalk always stay on?
TN8ball is offline   Reply With Quote
led turn signal kits for rzr
polaris ranger turn signal light kit
polaris rzr best blinker kit
polaris rzr blinker kits
polaris rzr led turn signal kit
polaris rzr turn signal kit
polaris turn signal kit
rzr blinker
rzr blinker kit
rzr turn signal kit
rzr turn signals
turn signal kit for polaris rzr
turn signal kit for rzr
turn signal kit rzr
www rzr does it 2ecdywqaaasazx was cydwoq tx ez cvsdhg ch xc6x tx zsa dax xt ra ex bb nu a
Turn signal kit ? Clayton4971 General RZR Discussion 0 April 5th, 2012 06:02 PM
Turn signal questions? lugnut General RZR Discussion 4 September 8th, 2011 06:51 AM
LED turn signal issue GstRdr General RZR Discussion 3 August 10th, 2010 09:29 PM
Turn signal question DEERHUNTERBOB Lighting, Stereo and Electrical 3 December 19th, 2009 07:20 PM
Turn Signal Flasher swanney Lighting, Stereo and Electrical 1 January 28th, 2009 06:51 PM
