Brake Switch - Polaris RZR Forum - RZR Forums.net
Brake Switch
This is a discussion on Brake Switch within the Lighting, Stereo and Electrical forums, part of the Technical category; So I've determined that my brake switch is only working sometimes which makes starting the RZR a pain. I did the jumper text and when ...
Old February 12th, 2012, 09:28 PM   #1
rorhound's Avatar
My RZR: 2013 WE XP
Member #11315
View rorhound's Photo Gallery(0)
Brake Switch
So I've determined that my brake switch is only working sometimes which makes starting the RZR a pain. I did the jumper text and when jumped the brake lights work fine. I also cleaned the terminals, male and female so I assume it has to be the switch.
Anyone replace one yet? Do you just pull the top off or does the whole block have to be replaced (as in taking the brake lines off)?
2013 WE XP, Alba BB & Stage II, Pro Armor Cage, Doors, Door bags, Harnesses & Steering Wheel, HRD Racing True Suspension Seats.
2012 27'CBG Attitude
2008 GMC 2500 Duramax
rorhound is offline   Reply With Quote
Old February 13th, 2012, 06:33 AM   #2
rorhound's Avatar
My RZR: 2013 WE XP
Member #11315
Re: Brake Switch
NM, it looks like it has threads and will screw out. Find out for sure when I get the new one.
Old February 13th, 2012, 10:18 AM   #3
Feedback Score: 16 reviews
guy48065's Avatar
Member #309
Re: Brake Switch
Yeah it just threads into the block. Unfortunately this lets air in so you have to bleed the rear brakes afterward
Try to dribble brake fluid into the new switch before installing it so no trapped air works its way out later & makes your pedal spongy.
guy48065 is offline   Reply With Quote
Old June 13th, 2014, 12:39 PM   #4
783raptor's Avatar
My RZR: xp 900
Member #41363
View 783raptor's Photo Gallery(0)
Re: Brake Switch
What is the plug going to master cylinder to 2 prongs my prongs are broke off still in harness plug?
783raptor is offline   Reply With Quote
Old June 24th, 2014, 12:15 AM   #5
shado's Avatar
First Name: Eric
My RZR: 2012 570
Member #52216
View shado's Photo Gallery(0)
Re: Brake Switch
I found a problem this weekend. I was able to start my 2012 570 with out having my foot on the brake. I looked into this and found my brake lights are always on (not just the running lights). Everything had been working fine the last time I took the rzr out.
I have searched on the forum and found that if the Brake switch goes bad people can not start the rzr. I spent the last couple hours running the power lines in the rzr. I disconnected the wire completely that goes to the Brake Switch and the rzr still started with no application of the brakes and the brake lights were still on.
There are two 30 amp fuses in line to the brake switch. When one is removed there is no change, rzr still starts with no brake and brake lights on. When the second is removed there is no power at all to the rzr. The instrument panel does not even light up.
I found a post about the circuit breaker getting corroded and checked that as well. It appears to be fine with power going through it.
I also located some posts about the brake light wires getting in touch with the muffler and melting to the point they ground out completing the circuit and causing the system to act as if the brakes are always on. I checked this as well and all the wires appear to be intact.
I trying to find out what direction to go next, any ideas?
shado is offline   Reply With Quote
2012 polaris rzr xp 900 brake pressure sensor
2015 polaris rzr 900 brake start switch
brake pedal saftey switch on rzr 900xp
brake switch rzr 800
break swivh polaris rzr
location of brake pedal safety switch rzr 800
polaris 900 rzr brake safety switch
polaris rzr 900s brake light/ start switch
polarisbrakelightswitch
rzr 900 brake switch
stop light switch on polaris ranger xp
what causes no lights no 4wheel drive starts without brakes peddle pushedon rzr
what does the two 30 amp fuses behind left rear wheel on a polaris rzr run
where is brake switch on razor 2015?
where is the brake pedal sensor on a polaris rzr 900
Disabling the Foot Brake Start Switch Overlord Engine and Drivetrain 29 January 11th, 2015 10:00 PM
Polaris RZR 800 WTB rear left brake caliper and brake line andyrzr Polaris RZR Parts For Sale 3 June 8th, 2011 12:22 AM
Need: 4 wheel drive switch and headlight switch for pre 2011 RZR RZR4Crew Want to Buy 4 January 25th, 2011 11:07 PM
20-50 oil... Did everyone switch over yet? pioneer6869 Engine and Drivetrain 23 February 13th, 2010 09:20 AM
Foot Pedal e-brake or Line Lock e-brake RZRider General RZR Discussion 10 December 12th, 2009 10:04 PM
