iPod, Amp, Speaker How To and Help? - Polaris RZR Forum - RZR Forums.net
This is a discussion on iPod, Amp, Speaker How To and Help? within the Lighting, Stereo and Electrical forums, part of the Technical category; I'm a newbie here and have been looking around but haven't been able to find a lot of information on iPod setups for the RZR. ...
Old October 13th, 2011, 01:18 PM   #1
RUSigX's Avatar
Member #31082
View RUSigX's Photo Gallery(0)
I have a 2010 RZR LE and I'm looking for the best cost effective setup to hookup an iPod. I already have 4 really nice 5 1/4" Polk speakers but really only planned on using two of them. I would need an enclosure for the speakers and some kind of amp with an iPod hookup.
I've seen some marine Pyle amps but I was thinking that Pyle was junk, am I wrong? I just want something that sounds pretty good but I don't want to throw a ton of money at it. Some of the roof speaker enclosures are so expensive.
Any suggestions? Thanks in advance!
RUSigX is offline   Reply With Quote
Old October 14th, 2011, 02:20 AM   #2
glamisdunes*****
dev's rzr's Avatar
First Name: devin
My RZR: 08 rzr
Member #5605
View dev's rzr's Photo Gallery(2) Send a message via AIM to dev's rzr
Re: iPod, Amp, Speaker How To and Help?
me too ?
[/SIGPIC]
dev's rzr is offline   Reply With Quote
Old October 14th, 2011, 04:51 AM   #3
Feedback Score: 5 reviews
whaffner's Avatar
First Name: Wayne
My RZR: '08 green rzr 800
Member #16284
View whaffner's Photo Gallery(0)
http://www.rzrforums.net/projects-ho...-speakers.html
whaffner is offline   Reply With Quote
Old October 14th, 2011, 05:38 AM   #4
dfrulla1's Avatar
First Name: Dennis
My RZR: 08 800
Member #29331
View dfrulla1's Photo Gallery(0)
Super atv dot com has a speaker box for 50 bucks or less that will fit ur speakers. autotoys dot com has a 150 watt mini amp with optional ipod cable also around 50 bucks to ur door. This amp drives my 2 way jbl marine speakers really well. Hope this helps.
dfrulla1 is offline   Reply With Quote
Old October 14th, 2011, 06:49 AM   #5
Capt903's Avatar
Member #23149
View Capt903's Photo Gallery(0)
Wal-Mart has a cheap speaker box with speakers for like $ 25-$30 bucks. I bought the box with the intentions of changing out the speakers it came with and putting my marine seaworthys in there place but I decided not to because they didnt look bad at all. On my 4, it wedged right in on the back side of the roll cage perfectly. I bought one of those sharks motorcycle amps and it was JUNK so i bought a Pyle and been happy with it and it was cheap !!
Capt903 is offline   Reply With Quote
Old October 14th, 2011, 05:18 PM   #6
dfrulla1's Avatar
First Name: Dennis
My RZR: 08 800
Member #29331
What does the walmart box look like? Shaped like that is?????
Old October 14th, 2011, 07:13 PM   #7
Mr. Impulse
Mr. Impulse's Avatar
My RZR: 2013 Custom Jagged X
Member #21458
View Mr. Impulse's Photo Gallery(1)
Mount the speakers in a 6"pvc cap for an enclosure, or my decision was I Just installed the shark stereo in mine. Will post some pics in a day or two. Google shark stereo. $125ish for an amp with built in radio,usb,sd card, and Ipod ipod/iphone input, and full waterproof speakers. Cheap and pretty loud. in the end, cheaper than me buying all the stuff to do my own. Good luck.
Mr. Impulse is offline   Reply With Quote
Old October 14th, 2011, 08:00 PM   #8
505sfastest's Avatar
Member #27725
View 505sfastest's Photo Gallery(0)
just got done with my wetsounds setup sounds bad ass!!!!!!!!!
505sfastest is offline   Reply With Quote
Old October 15th, 2011, 07:15 AM   #9
dfrulla1's Avatar
First Name: Dennis
My RZR: 08 800
Member #29331
If someone wants to use PVC caps, use flat caps vs dome ones. You can cut a 5 1/8 hole for 6 1/2" marine speakers. If you think you will need to extend it a bit with a piece of pipe STAY AWAY from schedule 40. You have to buy a whole stick for over a hundred bucks. Go with 30-34 sewer pipe and fittings which are different(green pipe). You can get some pipe lying around at a site or from a plumber buddy etc. I am a residential builder and it took me over a month to get a free 4' piece of 6" schedule 40!
Old October 15th, 2011, 09:05 PM   #10
RUSigX's Avatar
Member #31082
I checked out the Shark Stereo and it looks pretty good for the price. Does it come with a cord for an iPod or do you need to buy that separately? Where did you mount the amp, speakers, etc? I'm assuming you go the 250W model, did you get black or chrome?
Old October 16th, 2011, 04:51 AM   #11
jbr31's Avatar
First Name: Brandon
My RZR: 2010 rzr s pearl white
Member #14741
View jbr31's Photo Gallery(0)
if you only want an i pod hook up you could check out poly planar kits.
jbr31 is offline   Reply With Quote
Old October 16th, 2011, 08:57 AM   #12
dfrulla1's Avatar
First Name: Dennis
My RZR: 08 800
Member #29331
Ipod to rca with power and ground wire for charging I assume is what you need. Autotoysdotcom
Old December 13th, 2011, 04:34 PM   #13
1Rzr800's Avatar
First Name: Charlie
My RZR: 2015 Rzr 900s WL
Member #23017
View 1Rzr800's Photo Gallery(0)
I went with the Pyle PLMRKT4A 4-Channel Waterproof MP3/iPod Amplified 6.5-Inch Marine Speaker System from amazon.com..seems to work good for a entry level system but i am adding a Pyle 600w marine amp and 10" sub. i used 6 inch schedule 40 plumbing pvc pipe for my enclosure. You can buy the amp from amazon to cheapest place i found. it comes with a aux cable that plugs into any headphone jack
ID:	41185   Click image for larger version
ID:	41186   Click image for larger version
ID:	41187   Click image for larger version
1Rzr800 is offline   Reply With Quote
Old December 13th, 2011, 05:21 PM   #14
1Rzr800's Avatar
First Name: Charlie
Member #23017
[QUOTE=MOUNTAINEER221;807539]http://www.youtube.com/watch?feature=player_detailpage&v=7Ztu0Ob4KO4this set up isnt hard either. polk audi pa-330 amp used off ebay for bout 60 bucks. u can get pyle marine 7.7 speakers ive used them they arent bad. the pyle amps are total junk. ive seen several blow and are way over rated on the power. u can use the i-plug kit to connect amp to ipod ( bought mine at advance auto parts) 14 bucks. a pelican case for the mp3 if you mud bogg like us and your set.
Are you using a aftermarket battery? if so which one?
Old December 13th, 2011, 05:27 PM   #15
rzr mechanic
MOUNTAINEER221's Avatar
First Name: DOUG BOWEN
My RZR: 2012 ORANGE MADNESS
Member #3480
View MOUNTAINEER221's Photo Gallery(0)
no all stock on the battery. i have two pa-330 amps in this thing and ride alot of nite rides and have never had a battery light come on yet. so fat so good.
MOUNTAINEER221 is offline   Reply With Quote
amp and speakers in rzr
best 6 inch speakers
connect ipod to rzr speakers
cost of doug bowen radio rzr
how to hook up marine speakers to a mini amp
how to hook up speakers for ipod to 800 rzr
how to install pyle ipod amp into rzr
polaris rez i phone speaker
polaris rzr 4 800 subwoofer build your own
polk 330 amp set up
pyle marine speakers and amp polaris rzr
rzr ipod
utv ipod to amp setup
what kind of amp is best for a polaris rzr 4
whats best rzr audio iphone into amp
Ipod Speaker bag for Sportsman Xp-Work on a RZR? Speed 1B General RZR Discussion 3 April 2nd, 2011 10:44 PM
Ipod Holder HivoltageRZR Lighting, Stereo and Electrical 28 October 15th, 2009 08:16 PM
ipod recommendations?? docbones Lighting, Stereo and Electrical 23 March 27th, 2009 03:35 PM
ipod rockstar Want to Buy 3 February 7th, 2009 04:01 AM
Ipod to Amp Jeffro Lighting, Stereo and Electrical 15 August 5th, 2008 09:15 PM
