RPM Optima Battery Holder |
December 20th, 2007, 03:12 PM
First Name: RUSTY GERBER
My RZR: 2008 GENERATION 1
This is a review on the RPM battery holder selling on EBay or the RPM site
I ask for mine powder coated, I didn’t really pay attention to how good the coating was, but there was no noticeable flaws.
After you remove the old battery and holder and zip tie a few wires and cables that run along the bottom out of the way this slides right into place. The Optima Yellow top battery fits in the new RPM holder very nicely.
The screws needed come with the holder. I choose not to use the screws for the bottom plate to bolt to the cross member, and I did use 2 spacers to lift the battery tray up about 1” off the bottom, my concern was a rock going thru the skid plate and damaging the battery. I just used 2 spacers and put them where the new tray bolts go into the stock tray bolt locations.
All and all I am more than pleased with my purchase.
Re: RPM Optima Battery Holder |
December 20th, 2007, 08:11 PM
First Name: Al
My RZR: 08 Red
Nice to know. I used the factory Ranger XP unit before the Optima units were made but so far I don't have a need to go larger, we'll see hoe long that lasts. LOL
February 10th, 2008, 10:00 PM
First Name: Ronnie
My RZR: '08 Green RZR
Works good. I made the cut, moved some wires and stuck in the box. It bolted right up and holds the battery good.
May 8th, 2008, 03:01 AM
anyone have pics of what had to be cut out of a 2nd gen to make it fit?
May 8th, 2008, 10:26 AM
My RZR: gen2
I would like to see that to, please
May 8th, 2008, 06:47 PM
First Name: Steve
I bought the holder and installed Optima Yellow Top for no important reason, other than for reliability and longetivity. Small batts seem to wear out sooner, and I want to install HID light. If I don't drive it for a while, I don't have to worry about a dead battery. Now, I can drive electrical stuff with an inverter, if I want to, with total confidence.
May 8th, 2008, 09:01 PM
akpa18
First Name: Vern
My RZR: 800
I must of had a different RZR. That box would not fit into mine at all. I tried it every way possible, and I really am not a dumb ass. I ended up cutting the stock box out like you mentioned but then I had to turn the battery "left to right" instead of front to rear just to get it to fit. I then welded the box to the frame and built some gussets off the frame to support the sides. I wonder in different generations have something different going on with the battery box??
May 10th, 2008, 12:22 AM
My RZR: gen2
What gen do you have.
July 2nd, 2008, 11:00 PM
I used the Extreme Metal Products battery tray for the Optima
July 13th, 2008, 08:22 PM
Here are a couple of pictures
July 16th, 2008, 12:12 PM
First Name: Dusty
My RZR: Red 08 w/Polaris Winch, Brush Grds, 14" Polaris wheels, PIAA Lights, HID Head Lites, Soft Top
Has anyone tried the battery box offered on All-Terrain Sports Center, shopasc.com They also have overhead set-ups too.
July 17th, 2008, 01:58 PM
I just built my own. I took a piece of 2" strap metal bent it into a L One leg was 10" the other 13" Then screwed it into the lower back frame brace and the upper forward brace that the seat sets on. I had to cut the stock box out. Then bolted a plastic battery box I got at Wal-mart to the brace I made. I also had to do some trimming to the box I got to make it fit. Then set the battery in and made a couple of spacers to use the factory battery strap. I did have to use different holes though.
If someone can tell me how, I will post pics.
08 Red Rzr: ITP 14" 212's, 26" Bighorns, 1.5" wheel adapters, Xtreme 3" lift, Viper Max 4500lb winch with amsteel rope, Custom snorkels, Custom mounted Ammo Cans, Polaris: Pre runner bumpers, cargo net, cargo rack, over head bag, plastic top, rock sliders, and billet steering wheel, Fender flares, front and rear lights, Custom amp/switch box, MTX wakeboard speakers.
July 17th, 2008, 02:03 PM
I almost forgot. I also had to move the starter solenoid and the grounds on the frame brace. I just turned the solenoid bracket around and mounted the grounds under the bolts on it.
August 7th, 2008, 11:19 AM
Here is a pic of the setup.
