HID kit
Old December 18th, 2007, 11:27 AM
RGERBER's Avatar
RGERBER RGERBER is offline
First Name: RUSTY GERBER
My RZR: 2008 GENERATION 1
HID kit
I have my HID kit for the front headlights connected to the factory plugs - no relay, am I ok. also have a Optima yellow top battery - the directions said to use 70 amp battery or a relay. i din't know anything about relay's so went with the battery is this going to be ok.
Re: HID kit
Old December 18th, 2007, 12:31 PM
07fj 07fj is offline
Re: HID kit
Most of the kits have you change a fuse (headlight 15 to 20 or similar). Check the directions and see if it recommendeds one or not. Otherwise you are probably alright.
Rog
Re: HID kit
Old December 18th, 2007, 12:58 PM
RZRider's Avatar
RZRider RZRider is offline
First Name: Al
My RZR: 08 Red
Re: HID kit
What is the current draw of your HID set up?
My RZR Project
Keep It Wet and Dirty!
Re: HID kit
Old December 18th, 2007, 01:03 PM
RGERBER's Avatar
Re: HID kit
how would i know that
Re: HID kit
Old December 18th, 2007, 01:12 PM
RGERBER's Avatar
Re: HID kit
this is what i have
eBay Motors: Polaris RZR HID Factory Replacement Light Kit (item 110206220819 end time Dec-22-07 11:17:05 PST)
Re: HID kit
Old December 18th, 2007, 02:19 PM
Re: HID kit
RZrider It will be less than 3 amps a piece for 35watt HID's after 10-12 seconds.
Rog
Re: HID kit
Old December 18th, 2007, 05:44 PM
RZRider's Avatar
First Name: Al
My RZR: 08 Red
Re: HID kit
O.K. so it's 7.6 amps while operating but the original draw during start up will be what takes the weak link down before its time.
I asked the seller for max draw and he responded with I'll send a relay for the same price.
Without knowing the max draw, my guess is it's a good idea to use one.
Re: HID kit
Old December 18th, 2007, 06:31 PM
RGERBER's Avatar
Re: HID kit
now if i only knew how to install one?
Re: HID kit
Old December 18th, 2007, 07:00 PM
RZRider's Avatar
First Name: Al
My RZR: 08 Red
Re: HID kit
Give me am e-mail adress and I'll send you a quick drawing.
Re: HID kit
  #10 (permalink)
Old December 18th, 2007, 07:10 PM
RZRider's Avatar
First Name: Al
My RZR: 08 Red
Re: HID kit
Found this, it'll help you out.
86 will come from the head light switch or the positive lead at your headlight.
87 will come from the battery (fused of course).
85 is ground, you can get it from the chassis.
30 will go to power your HID light system
Check the size of the wire being used on the HID system and go a size larger. EX. If they are using 14 gauge, use 12 or even 10 gauge from the battery to your relay (lower the number, thicker the wire).
Re: HID kit
  #11 (permalink)
Old December 19th, 2007, 06:38 PM
HawkEng HawkEng is offline
Re: HID kit
SO, how does it work? Is it brighter than stock by much? Was it worthgt the $$$
Re: HID kit
  #12 (permalink)
Old December 20th, 2007, 08:57 AM
dgal dgal is offline
Re: HID kit
Yes,how much brighter?
FOR SALE:Gen 2 Red RZR.Nerf bars,sport top,winch,14 rims with 26inch Goodyear MTRs.Afco shocks,Prerunner front bumper with 7 inch HID,HID headlights,,and EPI clutch mod.stereo and still original battery with a chargeguard installed to monitor
Re: HID kit
  #13 (permalink)
Old December 20th, 2007, 09:16 AM
RGERBER's Avatar
Re: HID kit
yes, it was alot brighter. I still am no done with it so it has only been tested in the garage.
Re: HID kit
  #14 (permalink)
Old December 20th, 2007, 01:14 PM
Re: HID kit
Thanks.What about the 50 watt HID replacement bulbs from Polaris?
Re: HID kit
  #15 (permalink)
Old December 20th, 2007, 03:30 PM
RGERBER's Avatar
Re: HID kit
Thanks.What about the 50 watt HID replacement bulbs from Polaris? never heard of those, mine are 35 Watt HID bulbs and ballast. with the new Optima battery in they work great.
Thanks RZRider for the pic, but am am wanting about 6 relays and a fuse box made up. thats the way to go. i want to run 6 toggles on my dash like Marty Moe has
