Winch Electrical - Polaris RZR Forum - RZR Forums.net
post #1 of 11 Old August 2nd, 2011, 02:52 PM Thread Starter
El Dorado's Avatar
First Name: Steve
My RZR: 2008 RZR
Member #23622
View El Dorado's Photo Gallery(2)
Winch Electrical
Hello.. new to forum but a lurker for a bit. I have an 08 RZR 800. I put a Warn 2500XP winch on and hooked it up like I have done many times with other installs. I wired the hot line to the battery and the ground to the frame. My solenoid is located near the battery behind the drivers seat. The winch works just fine until I step on the brake! I moved the ground to the battery (upgraded large battery) and the same thing happens. I am not an electrical dummy, but how can the brake circuit stop the winch when it is hooked direct to the battery?
I know most of you use larger winches but I do not do mud and will only use it for a plow mount or to pull rocks while I am prospecting... hence the need to step on the brakes when doing those pulls.....
Thanks for any help from a great forum!
El Dorado is offline
post #2 of 11 Old August 2nd, 2011, 03:45 PM
Banned
itsruf's Avatar
First Name: Mark -
Member #16159
Re: Winch Electrical
The winch contactor s/b key switched? How did you do that?
The winch contactor s/b grounded. Diid you gnd that lead to the same battery terminal gnd post?
Just throwing this out sir.
As far as the brake...have you connected anything else on the machine? Connected other wires.
itsruf is offline
post #3 of 11 Old August 2nd, 2011, 05:04 PM Thread Starter
El Dorado's Avatar
First Name: Steve
My RZR: 2008 RZR
Member #23622
Mark
The winch does work only when ignition switch is on. This is the way it is currently wired. The black lead on the solenoid goes direct to the frame for a ground.
post #4 of 11 Old August 2nd, 2011, 05:19 PM
razor4298's Avatar
My RZR: XP900
Member #27430
View razor4298's Photo Gallery(0)
on the ground did you physically scrape the paint away the size of the grounding ring? Dont use self tappers use nut and bolt to fasten ground. Dont use existing bolt for a ground point.
razor4298 is offline
post #5 of 11 Old August 2nd, 2011, 06:34 PM
rzrback fan
aquacure's Avatar
First Name: Aqua
My RZR: 2008 Green
Member #4250
View aquacure's Photo Gallery(0)
Is that the complete diagram? Did you not tie into a hot wire that works off the key switch? When I first put my winch on my 08 it was doing the same thing and it was cuz i used that spare wire under the dash, for some reason it cuts the power when you hit the brake. I believe it was orange and white maybe.
2008 Black Herculinered
2" rubberdown lift
4000 lb Viper winch (green amsteel cable) Motosport Alloy Black Tork rims : 27" outlaw MST : "S" flares
Trail Armor boot guards : MudATV snorkel
Ipod>Amp>overhead speaker box
Benz silencer (like it quiet) : Gorilla axle
aquacure is offline
post #6 of 11 Old August 2nd, 2011, 07:23 PM
im4seven's Avatar
First Name: Jim
My RZR: 2009 Nuclear Sunset
Member #3702
View im4seven's Photo Gallery(0)
Did you use the orange wire under the dash for the switched hot? If you used anything else that might be the problem. Not an electrical wizard, and I don't have a wiring diagram in front of me, but the brake is tied into the starter circuit. Maybe the wire you tapped in to goes dead when you step on the brake, or reverses polarity? Just guessing.
im4seven is offline
post #7 of 11 Old August 2nd, 2011, 07:37 PM Thread Starter
El Dorado's Avatar
First Name: Steve
My RZR: 2008 RZR
Member #23622
OK, orange wire under dash. That could be something I can try. Are you saying the orange wire should be the wire that carries current to the winch solenoid? In other words, (Its' a Warn System) the red wire to the solenoid should actually be this orange wire or are we talking one of the switch wires from the solenoid..... That I could understand......I will be putzing with that tomorrow am and report back......Thanks
post #8 of 11 Old August 2nd, 2011, 09:25 PM
GJRonK's Avatar
First Name: Ron
My RZR: 2011 800 EPS Graphite
Member #24461
View GJRonK's Photo Gallery(0)
I'm confused. Are you supposed to use the orange wire under the dash or not? If so, what should it power? And should there be a fuse on the wire that connects to it?
Thanks.
GJRonK (who's about to hook up his winch)
GJRonK is offline
post #9 of 11 Old August 2nd, 2011, 09:41 PM
chipper's Avatar
First Name: Chip
My RZR: 2011 RZR
Member #15196
Feedback Score: 5 reviews
Looks like you have the red + hooked to the starter silinoid. It needs to be hooked directly to the battery and so should the black -. I could ne looking wrong but that's what I'm thinking.
chipper is offline
post #10 of 11 Old August 3rd, 2011, 10:18 AM
guy48065's Avatar
Member #309
Feedback Score: 16 reviews
The power lead for the solenoid switch (rocker switch--small wire) should be connected to the orange wire under the dash. That wire isn't shown on your diagram. Love to know what you have it connected to for the winch to die when the brakes are on
guy48065 is offline
post #11 of 11 Old August 3rd, 2011, 12:13 PM Thread Starter
El Dorado's Avatar
First Name: Steve
My RZR: 2008 RZR
Member #23622
OK.. finally figured it out. Thanks for the help in directing me to the Orange wire. I pulled out the wiring diagram and noticed that two orange wires actually come out of the fuse box. I had it hooked to the wrong orange wire..... The wire it was hooked to was the orange wire that goes to the Start Diode... my bad
Once again thanks for the help......
170 Electrical Issue jlibla RZR 170 Specific Disccusion 6 September 22nd, 2011 05:26 AM
Electrical Help! codydotcom Lighting, Stereo and Electrical 1 July 24th, 2011 08:01 AM
No Electrical Power Brjm General RZR Discussion 5 January 3rd, 2011 06:59 PM
winch electrical questions evomedic08 Lighting, Stereo and Electrical 2 September 30th, 2010 08:39 PM
Winch electrical problems Johnpeq General RZR Discussion 4 July 13th, 2009 08:24 PM
